Does this motherboard have a prayer?
  • gwozdz
    • Feb 2009
    • 10
    My nephews Emachines power supply (Bestec 250w) went and took along with it the motherboard. The cpu tests fine in another similar motherboard. When this happens is there any chance that by replacing the caps it will work again or with this type of failure is it likely that other bad things on the motherboard were damaged? An inspection of the board does not show any visible signs of damage.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Does this motherboard have a prayer?
    Chance yes. But only a chance.
    Bestec 250w are known to burn out motherboard chipsets.
    If the board doesn't at least boot to a BIOS screen then odds are against you and you are better off replacing it.
    Mann-Made Global Warming.
    - Dr Seuss
    • Toasty
      • Jul 2007
      • 4171
      Deo volente.
      In nomine Patris,
      et Filii,
      et Spiritus Sancti,
      Amen
      veritas odium parit
      • glovecaps
        by glovecaps
        11-25-2024, 04:23 PM
      • Archimedes
        HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
        by Archimedes
        Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
        Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
        Fans are spinning. Blindly could install windows11 and got the device manager...
        07-30-2024, 05:14 PM
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
        ASUS P5GC-MX motherboard recap
        by momaka
        Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
        This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
        So here is what the motherboard looked like with its original caps:
        CPU VRM area up close…...
        01-27-2021, 11:59 PM
      • dhenion
        Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
        by dhenion
        I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
        The original board was:
        ASUS X510UNR REV 3.0 A
        The replacement board is:
        ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
        It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
        01-30-2024, 01:45 PM
