Shutt down issue Win 10 Updates 1709?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys; i updated to 17.09 version and it screwed up my shutdown the normal way,i went through remote assistant with 4 CS people but none was able to fix the issue,i had this issue before when i reinstalled system win 10, and one of the MS CS assistant was able to fix issue by changing power option from Balanced to High performance setting ,but this time that fix was not successful,
    so i gave up and i had in my scrap an HDD with win 10 installed and swapped it and made updates to 1607 and now the shutdown is fixed.although when i go to updates it states that 1709 is ready to update,screw them i'm not going to click get started. i also changed setting per instructions here;
    https://www.computerworld.com/articl...nstalling.html
  • ivtec
    • Dec 2008
    • 1967
    Re: Shutt down issue Win 10 Updates 1709?
    Hi guys update on the HDD that had MS 1709 updates i just followed these instruction and rolled back to the previous version 1703 and now shutdown issue is gone,for someone that will have issues with Windows 10 Fall Creators Update have a weak to be able to roll back.
    https://www.youtube.com/watch?v=Wl0hvE9JNqY
    • TechWizard.Support
      • Aug 2017
      • 30
      • United Kingdom
      What's the issue with shutdown? I've encountered a few issues with the Creators Update where the system would bluescreen upon going into sleep mode. Changing the power plan to high performance would prevent this and act as a workaround. I was unable to identify the driver that was causing the issue and a fresh reinstall of windows seemed to fix it. Is there anything coming up in the Event viewer?
      • SuperJames
        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
        by SuperJames
        This one's a weird one, and still unsolved despite it having gone back to Dell once.
        Specs
        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
        Backstory
        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
        10-23-2023, 04:09 PM
      • kalilinux25
        Power Issue, if shutdown it wont power on again.FH5AT LA-K092P REV 2.0
        by kalilinux25
        Hi good day I have a issue of this motherboard laptop, if doing a cmos reset the the motherboard ( discharge the current inside the board) it will power on and if you shutdown
        the laptop it wont power , it will shows led light for a second then shutdown.
        Tried clean Me bios smae issue
        tried to bypass thermal protection ( remove RB7 and RB1 and jumper each pad of the DB1 )
        ive check the motherboard for corrion but no avail
        Hope someone can guide which part of the board should I focus to narrow down the issue
        FH5AT LA-K092P REV 2...
        10-06-2023, 12:49 AM
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        🛠 Original Issue
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • ugamazing
        by ugamazing
        12-17-2024, 07:05 PM
      • shahnld
        Lenovo legion 5 pro startup issue
        by shahnld
        Good day Experts
        I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
        A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
        And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
        08-24-2025, 12:31 PM
