Sd & Mmc
  • stevo1210
    • Oct 2006
    • 4156
    Sd & Mmc
    I was an ass today and managed to plug an MMC card into the SD slot of my Toshiba P25 laptop.
    It didn't detect the MMC card at all. I didn't realise that I plugged in an MMC card at the time until I ejected it and looked at the card carefully. I was in a panic frenzy at the time because I thought I killed the SD slot of my laptop.
    I went and got an SD card out of my drawer and plugged it into the SD slot and it read fine, and wrote data fine as well.
    My friend who passed me the MMC card didn't bother to tell me it was an MMC card as he thought all SD slots read MMC cards as he plugs his MMC card into the SD slot of his PC at home. I decided to give it a try on my PC and plugged in the MMC card into the SD slot and I was stunned to see it actually read the MMC card.
    Now the MMC card and SD card are similar in shape, I think the MMC is a bit thinner though. It fitted in the slot and even locked itself in there like any SD card.
    Now this is one mistake I won't repeat. The SD slot still reads my SD cards fine so should I be worrying about the thing being shorted and ruined?
    I did not smell anything or see any smoke when I plugged the MMC card in and my laptop seems pretty normal as well.
    So can someone confirm if an MMC card is really compatible with an SD slot for sure?
    Thanks.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Sd & Mmc
    """ the slightly thinner, pin-compatible MMCs can be used in almost any device that supports SD cards if the software/firmware on the devices support them. """
    http://en.wikipedia.org/wiki/MultiMediaCard
    Mann-Made Global Warming.
    - Dr Seuss
    • Harvey
      • Apr 2007
      • 264
      Re: Sd & Mmc
      Indeed - its unusual for a SD card slot not to work with a MMC card, as SD is a super set of the MC standard and is designed to be backwards compatible.
      • Harvey
        • Apr 2007
        • 264
        Re: Sd & Mmc
        ...or is that forwards compatible?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: Sd & Mmc
          It depends on which way you are facing.
          - Dr Seuss
          • zandrax
            Hit and miss
            • Dec 2007
            • 1157
            • Italy
            Re: Sd & Mmc
            Try updating card reader's drivers.
            Zandrax
            Have an happy life.
            • zatara10
              Lenovo B580 - unauthorized wireless network card is plugged in. power off and remove it
              by zatara10
              lenovo B580 change wifi card after this error "unauthorized wireless network card is plugged in. power off and remove it"
              bios dump attached...
              08-24-2024, 03:06 AM
              AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
              The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
              10-01-2024, 12:46 PM
            • sauce
              MSI DUKE RTX 2080 Ti 11G OC V371 1.0
              by sauce
              I am trying to repair this graphic card and I am quite new in this (but not a newbie in repair in general)
              If I plug the card inside a x16 pcie PC slot, the card won't power (no led, no fans, voltages : PEX, 1.8v, GPU core missing, I have only 12v on coils, 5v and 3.3v on the back on L801)
              The card stays absolutely cold.
              But I have a razer PCE164-N09 (see picture) and if I plug the card on it, the card works perfectly ! I have a picture and the drivers load perfectly too no issue on windows.
              Do you have an idea where to check...
              09-10-2025, 01:35 AM
            • totoagung2
              by totoagung2
              Totoagung2: Situs Slot Gacor Paling Gampang Jackpot di Indonesia 2024
              Hadirnya situs slot gacor gampang jackpot Totoagung2 yang menyediakan banyak sekali permainan slot terpopuler terkini yang hadir setiap tahun nya. Tentunya di Indonesia sendiri yang menjadi salah satu negara yang favorit bagi provider game slot. Banyak sekali pengembang permainan melihat negara tanah air Indonesia untuk menjadikan dan mencoba berbagai kesempatan bisnis judi online yakni games judi slot Totoagung2 terbaik dan terpercaya no 1. Hal itu juga dibuktikan dengan sangat banyaknya provider mesin slot...
              01-01-2024, 02:43 PM
            • Christos Tsiligiannis
              Marian Trace Alpha sound card repair help
              by Christos Tsiligiannis
              Hello to the forum.
              My name is Christos, I am new to the forum here and i am posting from Greece.
              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
              So i tried asking for a schematic from the company and they would not give me one. Instead they...
              11-18-2024, 05:26 AM
