Socket 939
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Socket 939
    I was just browsing looking for a MOBO SK939 and I'm not able to find one.
    I can find some MOBO for sk 478, few for sk 754 but none for socket 939.
    I'm just curios why it is in this way, was AMD socket 939 a bad/unlucky processor line?
    Ok Intel sells more CPU than AMD, but sk 478 is older than sk 939 AFAIK ... but seems easy to find MOBO for older socket or it's just me?
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Socket 939
    socket 939 had some issues, and was very quickly replaced by AM2. It was AMDs shortest-lived socket. I'm using a 939 system at my part-time job, and have had no problems. We also have a 939 processor just sitting in a box because of a lack of boards.
    Ludicrous gibs!
    • Scenic
      o.O
      • Sep 2007
      • 2642
      Re: Socket 939
      for me it's the other way around... got a board but no CPU
      one of those (in)famous Asus A8N-SLI thingys (those with the always broken southbridge fans)
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Re: Socket 939
        Yep, we had a A8N-SLI... I think it toasted, and that's where the spare proc came from.
        Another big limitation was that they only supported DDR, NOT DDR2!
        Ludicrous gibs!
        • Scenic
          o.O
          • Sep 2007
          • 2642
          Re: Socket 939
          but thats based on the CPU, because those had the memory controller built in (like the new Core i7 crap)
          i don't like the idea of an integrated memory controller at all...
          • Gianni
            • Jul 2008
            • 681
            • Italy
            Re: Socket 939
            Thanks for explanation... now it's clear.
            Ciao
            Gianni
            H. J. Brown
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              Re: Socket 939
              Why? No northbridge needed (except for integraded graphics,) and everything connects directly to the processor. One of the main reasons why AMD 64's were so much faster than pentium 4's.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                Re: Socket 939
                core i7 is certainly not crap its just expensive at the moment
                • agraham
                  • Jan 2009
                  • 24
                  Re: Socket 939
                  eBay has 448 939 boards available right now
                  http://computers.shop.ebay.com/items...QQ_sacatZ99245
                  • DynaxSC
                    ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                    by DynaxSC
                    I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                    Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                    Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                    The behaviour is also really very strange, i.e.:
                    • The disk shows always up in BIOS - so it is recognized, so far so good
                    • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                    02-23-2025, 01:33 PM
                  • Isabella91
                    Possible to convert eMMC Socket to a micro SD Card socket?
                    by Isabella91
                    I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
                    Read/Write a Micro SD Card from an eMMC Socket.
                    I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
                    Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
                    Not to remove...
                    01-14-2024, 05:10 PM
                  • warsztat
                    Acer AN515-57-577G JDIMM1 socket not working.
                    by warsztat
                    Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
                    11-18-2024, 09:13 AM
                  • danielgerman681
                    ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                    by danielgerman681
                    Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                    08-27-2025, 01:17 PM
                  • AJ847.63e
                    LGA 1700 Socket Replacement Tips & Tricks
                    by AJ847.63e
                    Hi All,
                    Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
                    I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
                    07-24-2025, 06:57 PM
