buzzing noise from MOBO
  • gustie
    • Dec 2008
    • 76
    i used a PC recently and noticed that when you rolled the mouse wheel you could hear a high pitched noise coming from the tower
    what can this be ?
    DFI Lanparty NF2 Ultra B
    TICTAC 619XT Bios
    AMD Athlon XP-M 2600+ FQQ4C IDYHA I-Stepping
    Speeze Vulture spin 3 Heatsink and Fan
    2x Mushkin XP4000 1024m DDR500 (1:1) @ 2.5-3-2-8 1T
    GeForce FX 5700 256m
    Zalman VF900 CU GPU cooler
    Skyhawk 400W Aluminium psu
    Sharkoon Silent Eagle 1000 case fans
  • pentium
    • Mar 2006
    • 2778
    Re: buzzing noise from MOBO
    Toroid coil resonating?
    Find Nedry!
    Check the Vending machines!!
    • agraham
      • Jan 2009
      • 24
      Try disconnecting the bleeper. I get the same thing through my onboard sound system. It was annoying enough that I spent $ on a sound card even though the onboard sound had all the features I needed.
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Are your speakers close to the tower, or does it have a integraded speaker (to play music and stuff i mean,) if so, it might be that the speakers are turned all the way up, so you are hearing the noise through the sound card on your motherboard.
          master hoarder
          • May 2008
          • 12175
          My Dimension 3000 does that, but it's barely audible. I think it's normal though.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Mouse is usually on +5vsb in standby and on +5v during op by way of a switching IC.
            Some may use +5vsb only. (Not sure.)
            - USB or PS/2 doesn't matter.
            That's done so mouse or hot-keys can wake system.
            May be +5vsb or +5v problems in power supply.
            Flyback transformer for +5vsb could probably make that noise.
            Mann-Made Global Warming.
            - Dr Seuss
            • stvhop
              HP1955L Buzzing noise & interference
              by stvhop
              Hello, This is my first post so please forgive me if I miss out some vital info.
              I have a problem with my HP1955L monitor from 2005.
              The first thing to say is that it is still basically working, ie the picture is fine.
              However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
              The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
              11-07-2020, 07:13 AM
            • Orion Bardier Skylar
              Adding Bluetooth module to Woofer buzzing noise
              by Orion Bardier Skylar
              Hi, I got this Woofer,Name TBT, which damaged its Radio module, then was added a Bluetooth module from the market(history from client). Then recently was brought to me with very low sound and heating problem. I changed subwoofer Speaker which had impedance of 1.2 instead of 4ohms rms and the bass ic KA2206B. Sound is back but buzzing and hissing sound present even when muted. How can I get rid of it?
              03-06-2024, 02:35 PM
            • tony359
              by tony359
              11-28-2023, 05:18 AM
            • MegaZAC
              Onkyo TX-SR805 noise in one channel
              by MegaZAC
              Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
              Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
              There's some logic behind it. As soon as I select an input I get only left...
              04-23-2025, 10:09 PM
            • courtcircuit
              Philips HTS8000 home cinema noise problem
              by courtcircuit
              Hello
              I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
              Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
              Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
              I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
              Removed each of tyhe boards
              02-08-2025, 08:22 AM
