Windows 10 issue
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Windows 10 issue
    Anyone help with a window 10 issue,I've got on boot up either 'windows symbol' with spinning wheel,then nothing or on boot again 'no boot device'.
    I've hooked up the drive to a external and seems ok showing all the files pics music downloads etc,not cutting out,so can it mean some thing is missing from windows file system ?
    Help much appreciated
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Windows 10 issue
    "no boot device" is an issue somewhere between the physical level of the HDD and the SATA controller of the MOBO. Sandy Bridge CPU? SSD or HDD. All these things matter!
    Follow the white rabbit.
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      How Do you check the physical level ? Of the hdd?
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        Run a SMART test. Use the HDDs makers tools.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Looks like a sick drive, a bad SATA cable or a loose SATA connection...
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
            • 31094
            or a failing psu
            • DynaxSC
              ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
              by DynaxSC
              I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
              Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
              Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
              The behaviour is also really very strange, i.e.:
              • The disk shows always up in BIOS - so it is recognized, so far so good
              • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
              02-23-2025, 01:33 PM
            • claws77
              FX553VE-DM318T(FX553v) not POSTING
              by claws77
              Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
              Gpu - nvidia geforce 1050ti
              Ssd orion o700
              Hdd hgst721010A9e630
              See images
              What's not working right?
              The system does not even POST, display is black,
              LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
              When did the problem happen?
              My laptop had dual boot setup, ubuntu and windows 10.
              It already had a moklist error, that would occur when i tried to boot ubuntu.
              05-17-2025, 04:09 PM
            • abajor
              Alienware Area-51 R2 Boot Loop issue.
              by abajor
              I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
              It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
              To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
              Right now I'm trying to dig through the PDF schematics and Board...
              03-08-2024, 10:08 PM
            • mr.malcom
              HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
              by mr.malcom
              this is a very strange Problem:
              Notebook hang instantly on Boot. BIOS is accesable.
              Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
              Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
              i have tried:
              - only one RAM Stick, another working RAM, both RAM channel
              - BIOS Flash to newest Version F.50, BIOS Reset
              - Memtest86 hang instant at Test 2
              - HP UEFI Diagnostic wont find...
              02-26-2022, 05:19 AM
            • Safio
              Asus Rog Strix g15 g512LI BOOT ISSUE
              by Safio
              Hello
              My asus rog strix g15 g512 keeps repeating the "Republic of Gamers" animation and won't power on. Anyone know what could be wrong with it?
              i tried to install new system on it but it is same issue , does the same thing when i try to boot from usb or externals hard drive, flashed bios still same issue , if its a hardawre issue please share your experience
              thank you
              06-08-2024, 08:43 PM
