Windows 10 issue
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Windows 10 issue
    Anyone help with a window 10 issue,I've got on boot up either 'windows symbol' with spinning wheel,then nothing or on boot again 'no boot device'.
    I've hooked up the drive to a external and seems ok showing all the files pics music downloads etc,not cutting out,so can it mean some thing is missing from windows file system ?
    Help much appreciated
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Windows 10 issue
    "no boot device" is an issue somewhere between the physical level of the HDD and the SATA controller of the MOBO. Sandy Bridge CPU? SSD or HDD. All these things matter!
    Follow the white rabbit.
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      How Do you check the physical level ? Of the hdd?
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        Run a SMART test. Use the HDDs makers tools.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Looks like a sick drive, a bad SATA cable or a loose SATA connection...
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
            • 31201
            or a failing psu
            • DynaxSC
              ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
              by DynaxSC
              I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
              Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
              Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
              The behaviour is also really very strange, i.e.:
              • The disk shows always up in BIOS - so it is recognized, so far so good
              • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
              02-23-2025, 01:33 PM
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
            • claws77
              FX553VE-DM318T(FX553v) not POSTING
              by claws77
              Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
              Gpu - nvidia geforce 1050ti
              Ssd orion o700
              Hdd hgst721010A9e630
              See images
              What's not working right?
              The system does not even POST, display is black,
              LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
              When did the problem happen?
              My laptop had dual boot setup, ubuntu and windows 10.
              It already had a moklist error, that would occur when i tried to boot ubuntu.
              05-17-2025, 04:09 PM
            • abajor
              Alienware Area-51 R2 Boot Loop issue.
              by abajor
              I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
              It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
              To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
              Right now I'm trying to dig through the PDF schematics and Board...
              03-08-2024, 10:08 PM
            • 0xx
              2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
              by 0xx
              Hi folks,
              My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
              What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
              I assumed that Windows Update was interrupted due to closing...
              09-14-2025, 03:46 PM
