Got a VP6 yesterday with missing BIOS chip. Put a chip on the board but the POST card doesn't show any signs of booting. The caps (mostly Tayeh, but also found two 470uF 25V Robycon ZL-s - probably someone has already replaced some caps?) have no signs of damage. Does anybody have any suggestions on what to pay special attention when doing further research?
Abit VP6 common failures?
first it should be recapped.
do any inductors show signs of overheating?
vcore present and correct?
sure you have the correct bios?
i have had several vp6's with bad flashes caused by lockup from bad caps.
sounds like it at least has a chance.
if it is over your head tc or i can likely fix it. -
agreed. Check all the above, and it should show some signs of life if voltages are present, and the BIOS has a valid image on it.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
That looks like an interesting project to tackle.
Wish I could get a component list for the VP6."Its all about the boom....."
Guns kill people like spoons made Rosie O'Donnell fat.
We now return you to your regularly scheduled drinking.
"Fear accompanies the possibility of death.....calm shepherds its certainty"
Originally posted by TopcatAWD is just training wheels for RWD.Comment
by JDCI've worked on more than a few of these boards and the outlined parts in red seemed to be the most common. These board vary in parts, especially the number of relays on them. The part numbers listed in the title are examples.
These boards (like most appliance boards nowadays) have a kind of protective shellac coated on them. I use professional strength Good Off on solder joins to remove what I can so I can get good contact with my meter leads.
A schematic exists showing what each relay is responsible but I don't have that handy right now.... -
by Dev GooseHi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
What Happened
The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand... -
by FoetussHi all
Hope this is in the correct place.
I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
Could use some double checking to see if I'm not doing something stupid
Pictures of the boards are attached.
What I will be replacing with what : (planned)
Soltek Golden ::
4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...2 Photos-
Channel: General Capacitor Questions & Issues
by J_TI have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
Sorry, I am not experienced hence a basic question.
by davidk35Hi,
So i got above mentioned laptop. Which shows only some little signs of life.
When i turn it on, 3 buttons lit up and stays like that forever (ESC, Caps Lock and Num Lock), they dont blink, they are just lit all the time. Fan does not spin, and there isnt any heat from CPU.
What ive already done:
-Flashed both bios chips 16 and 8 mb.
-Tried adding another stick of ram
-Check if backlight is faulty.
So any ideas?
Thank you09-03-2025, 06:34 AM - Loading...
