i am having problems with so many microsoft mice, this is generally units in the timescale around explorer 4.0 and the comfort optical 3000 etc and after. so many just with intermittent working buttons. any solution or just junk them. its a pity cos we have some microsoft keyboards and mouse from years back which are still working fine and heavily used every day.
Microsoft Mouse Quality down
Tags: None
Re: Microsoft Mouse Quality down
Half working left button switches are common on 2-3 years old Logitech mices too: I repaired mine once by following the guide on overclockers.com and I think the same procedure can be applied on MS products.
Beware: open the switch gently, using a flat screwdriver if necessary, and don't move the little copper plate used for contact: if you lose on your floor it or don't remember the exact position, I'd be near impossible to correctly reposition it. On wireless mices don't detach power cables too: solderings are too small to be welded again.
ZandraxHave an happy life.Comment
Mine is just fine...2 years strong now. Wireless mouse, never had any troubles, just gets laggy when the batteries go down. Came with my microsoft keyboard with a fingerprint scanner on it.Comment
Originally posted by arnesonI got four dead rats yesterday. Threw them all away.
Set the trap, ten minutes later, whap,, that's one, snap, snap snap,
got the whole rat family.
That's a big help, huh?
.Mann-Made Global Warming.
- Dr Seuss
I got an explorer 2.0 that recently started to have a really finnicky right click and the scroll wheel is horribly stiff but the thing has been living on a single set of AA batteries for almost half a year now.Find Nedry!
Check the Vending machines!!
<----Computer says I need more beer.
I have an ORIGINAL intellimouse explorer optical, back from about 1998, still works today. It was made in Japan I believe. Today, all made in china, and that's quite evident. I had a wireless intellimouse explorer, it sucked. response time was terrible, batteries would die twice a week (not rechargeable, used AA's), and one day, it just quit. It was about 3 months old when it died. Went logitech, and never looked back.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
I have an 8 year old Logitech ball mouse. Left button switch went bad 3 years ago and I just replaced it with another one from some crappy mouse someone gave me. Took me about 10 minutes to repair - 9 of which were me trying to figure how to desoldier the button since I was still learning how to solder. It worked great untill last year the right button switch started to act out. Maybe when I get time I'll try the overclockers.net guide.
@ Willawake: I guess if you have nothing better to do you can swap the non-working buttons from one mouse with working buttons from another. Should take a few minutes per mouse, though, I don't think it would be worth the hassle. Maybe try and sell them.Comment
Yup, I love the Intellimouse Explorer 3.0 but the new ones have crap buttons
I replaced 2 under warranty (retailer asked me to just throw the old ones away, didn't even want em back)
But after those two failed he asked me if I wanted something else so I picked a Logitech in the same price range, didn't like it's feel as much tho
Elfa had the cure tho, 35-701-24 will buy you new buttons, they are very easy to replace
They are much stiffer then the originals but I replaced mine about a year ago and still going strong (Knock on wood)
And since the retailer asked me to not send in the faulty mice I now have several"The one who says it cannot be done should never interrupt the one who is doing it."Comment
For those interested I had to replace some buttons on some of my mice awhile back here is the Digikey link.
If you want to maintain the same pressing force you want the 150 gram buttons here:
http://search.digikey.com/scripts/Dk...?name=SW500-ND
Here are the 75 gram lighter pressing force buttons.
I bought these first paying too much attention to the lead spacing and actuator type. But I actually liked the lighter pressing force.
http://search.digikey.com/scripts/Dk...?name=SW503-ND
For a buck and change per button you don't have to cannibalize any more mice.
I use a Razer Deathadder since I do alot of gaming an optical mouse with 1800 DPI resolution for around 30 bucks plus two programmable hot key buttons on the side. The software is very user friendly too I can set the polling rate and DPI of course mine are all at max.
Whenever I use anyone elses mouse that came with their computer they feel incredibly sloppy by comparision.Last edited by Krankshaft; 10-19-2008, 05:58 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
Originally posted by KrankshaftFor those interested I had to replace some buttons on some of my mice awhile back here is the Digikey link.
Whenever I use anyone elses mouse that came with their computer they feel incredibly sloppy by comparision.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
I've opened a bunch of different mice from name brands to crappy Chinese knockoffs and they all use the same button type with the same pinout.
I have an old Dell branded Logitech optical mouse and yes when I opened it the buttons above fit fine.
I almost certainly thought the same thing you did. But the manufacturers seem to like these buttons for mice.
I guess it's since they give that tactile and audible sensation that we are all used to on our mice?
Here is a pic of the switches on a mouse:
http://jdc.parodius.com/logitech/mx500_mini_pcb.jpg
Just make sure when you solder the new switches in that the button is facing the right direction. It is usually silkscreened on the PCB.Last edited by Krankshaft; 10-19-2008, 08:29 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
the logitech mouse i'm using ("Premium Optical Wheel Mouse" M-BT58) uses the same buttons as in krankshafts 1st link..
from what i've seen, almost all mice use those buttons.. only older microsoft ones (like the original PS2 Intellimouse (non-optical)) used other buttons.
@topic: i went logitech and never bought anything else... those basic models last like forever.. i only buy a new mouse if its suface gets really blank... (meaning those mouse buttons and at the side where your thumb is have no structure anymore... you can actually see yourself (like in a mirror) on one of my oldest logitechs at the side where your thumb usually is.. lol)
hard to take a photo of that... but i hope you get what i mean...
almost no structure anymore... doesn't look that bad on those photos but they are actually really blank.. lolComment
@all: does it makes sense to replace something that can be cleaned with wd40?
how many of you tried cleaning it first?
scenic: i'm quite the opposite it seems: i like them to have no texture, because texture is something that all too often is just dirt...hehe...
so i would easilly pick left one in this pic
http://picasaweb.google.hr/i4004b3/MiOvi#
as it's all smooth...easier to clean...you know excatly how should it feel...
with rough surface it's always a doubt: is it mouse, or just dirt...Comment
Originally posted by i4004@all: does it makes sense to replace something that can be cleaned with wd40?
I can desolder and solder on a new switch in much less time.
By the time it starts sticking the switches contacts are probably badly worn down too. Unless the reason it's sticking is because of liquid intrusion.
If the switches weren't cheap I would give it a shot though.
IMO it's like oiling the bearings of an old case fan it's alot faster to just replace the fan and not have to worry about it.Last edited by Krankshaft; 10-19-2008, 11:26 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
i didn't see it on other forums, i got problems with a switch and applied wd40.
didn't dismantle switch at all.
when you have intermittant problem with a switch wd40 seems like a natural solution.
because one of its purposes is to clean the contacts.
offcourse, you can try other spray that cleans the contacts.
in that aspect i find it weird that the guy(in zandrax link) bends the contacts but never cleans them.
if he was working in some industrial hall with lots of giant switches he would probably use a hammer to force the switch to conduct electricity->bang..."now i'll force you to carry those electrons"...the fact that contacts oxidize doesn't matter.....
what a dumbass.
i'm not saying wd40 will fix all mice switches, but it's easiest thing to try first, isn't it?(buying the new mouse as soon as old dies aside)
i used it, and it cured my mouse switch.Comment
A while ago some idget in another forum asked: "What is the fastest mouse?".
I told him Stuart Little because Mickey drives an old Model T or something.
- Dr Seuss
What! He's still alive!Mann-Made Global Warming.
- Dr Seuss
This specification for the HP ProBook x360 440 G1 + Microsoft Office Home & Business 2019 + 15.6" Classic Briefcase & Mouse Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 440 G1 + Microsoft Office Home & Business 2019 + 15.6" Classic Briefcase & Mouse boardview and 440 G1 + Microsoft Office Home & Business 2019 + 15.6" Classic Briefcase & Mouse schematic. Our users have donated over 1 million documents which are being added to the...09-06-2024, 08:35 AM
This specification for the HP ProBook x360 440 G1 + Microsoft Office 365 Personal 1 Year Subscription + 15.6" Classic Briefcase & Mouse Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 440 G1 + Microsoft Office 365 Personal 1 Year Subscription + 15.6" Classic Briefcase & Mouse boardview and 440 G1 + Microsoft Office 365 Personal 1 Year Subscription + 15.6" Classic Briefcase & Mouse schematic. Our users have donated over 1 million documents which...09-06-2024, 08:35 AM
This specification for the HP ProBook 640 G4 + Microsoft Office Home & Business 2019 + 15.6" Classic Briefcase & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G4 + Microsoft Office Home & Business 2019 + 15.6" Classic Briefcase & Mouse boardview and 640 G4 + Microsoft Office Home & Business 2019 + 15.6" Classic Briefcase & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This...09-06-2024, 08:10 AM
- Loading...
