usb type c to hdmi only works on phone and not computer
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    I bought a new MSI gaming laptop to replace my desktop. It was important to me to have triple monitor support. I figured since it had HDMI, Thunderbolt (aka Mini DisplayPort), and USB Type C it would be easy. Well, unfortunately, the USB Type C to HDMI adapter I bought on Amazon doesn't seem to work on the computer.
    When plugged into the computer the little blue light on the adapter comes on (so I know the port isn't broken) but the monitor just says check signal cable. However, when I plug it into the USB Type C on my HTC 10 Android phone it works instantly.
    Any ideas? It's an MSI GE62VR Apache laptop with i6-6700HQ, GTX 1060 graphics, 16GB DDR4, and Windows 10.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: usb type c to hdmi only works on phone and not computer
    Tried updating the graphics driver?
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      • 31201
      try not trusting so-called usb type c or any other "universal" ports.
      the individual functions actually supported are down to the hardware maker, the drivers and the o.s.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Yep, graphics drivers up to date and windows is up to date as well :/
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          [QUOTE=shovenose;704418]Yep, graphics drivers up to date and windows is up to date as well :/[/QUOT
          I would check into the windows 10 program and see if the driver for the monitor will work. I know some drivers for window 7 will not work on Windows 8 even though they are USB 2.0 ports. perhaps the monitor manufacturer has a different driver for Windows 10 on their site.
          • diif
            • Feb 2014
            • 6978
            • England
            The manual mentions USB 3.x, DisplayPort, PCIe, Audio, and Thunderbolt 3 (Optional).
            Can you try a USB-C to DisplayPort adapter ?
              • 31201
              it actually says USB-C(level-2)
              so what is level2 ??
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                I was the understanding USB-C is the same as USB-3 is this not correct?
                  • 31201
                  it's my understanding that USB-C is just usb data but with a configurable power system allowing it to be used to (for example) charge the laptop.
                  i cant see how it can drive a monitor unless the usb controller has a direct link to the gpu.
                    • 31201
                    On September 1, 2016 - HDMI Licensing, LLC released the HDMI Alternate Mode for USB Type-C Connector Standard. This will allow HDMI enabled source devices to utilize a USB Type-C connector to directly connect to HDMI enabled displays, and deliver native HDMI signals over a simple cable without the need for cumbersome protocol and connector adapter or dongle chips.
                    HDMI Alt Mode will support the full range of HDMI 1.4b features such as: resolutions up to 4K, Audio Return Channel (ARC), 3D, HDMI Ethernet Channel (HEC), and Consumer Electronic Control (CEC). This HDMI passive cable will utilize the USB Type-C connector on the source side and any HDMI connector on the display side. Unlike the other Alt Mode display technologies (e.g. DisplayPort, MHL) which require various adapters or dongles to connect to HDMI displays, HDMI Alt Mode enables an easy connection via a simple USB Type-C to HDMI cable. This is capable of 4K 30fps - basic UHD - video delivery without any additional chips. The USB Power Delivery (USB-PD) standard enables the devices to draw up to 100W power over USB Type-C port. The USB Type-C ports which supports HDMI Alt Mode will be identified by using the HDMI logo along with the USB trident logo.
                    so - got the logo?
                    • edugimeno
                      TD Systems K50DLP8F works fine on 1 HDMI, bad on others
                      by edugimeno
                      I have this TV set that I spent a long time fixing it.
                      I finally found a shorted SMD capacitor near the plug from the PS at the main board. It was shorting one of the main voltages (can't remember which one)
                      I removed that capacitor, and as it has another one in parallel, I left it with only one, checked it and it seemed to work fine. The solder near that capacitor was really delicate as I pulled apart one trace so I prefered to not mess much with it after I had to air solder one small thread of copper
                      I didn't use that TV much at that time. Now that I'm using it,...
                      10-06-2023, 03:00 PM
                    • electronx
                      Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
                      by electronx
                      I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
                      1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
                      According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
                      If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
                      06-26-2025, 03:27 AM
                    • huzo
                      Dell 5590 no image on LCD,HDMI works ,the board works...
                      by huzo
                      The board is LA-F411P ,DELL 5590 ...
                      The screen polarises,no backlight,no image,only black screen,tried another screen,the same,so there is no backlight,but there should be an image when i shine a lamp behind the screen,but there is none...only dark screen...when screen is connected and i press F8 to turn the image over to the external monitor, the external monitor gets coloured bars ,but when i disconnect the cable from the EDP ,the HDMI picture is good...What could be the problem? I don't have another edp cable, but i measured it with meter and it comes out good...i am baffled......
                      02-16-2025, 03:08 PM
                    • amuse619
                      Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                      by amuse619
                      Hello!
                      Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                      Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                      08-14-2024, 01:22 PM
                    • SluggerB
                      Help with trying to fix phone that is not charging (Pics inside)
                      by SluggerB
                      I have two TCL A30 phones.
                      Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                      New Phone: Works fine, bought as a donor board to try and repair Old Phone
                      My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                      08-12-2024, 08:11 AM
