Gigabyte 7300GS complete overhaul and modding
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    #41
    Re: Gigabyte 7300GS complete overhaul and modding
    if u're interested in that video card, here are a few listings for it on ebay: one and two. albeit they are working ones. hard to find one faulty tho if it has such low tdp with a fairly adequate cooler.
    • hikaruichijo
      • Aug 2015
      • 123
      • Spain
      #42
      Originally posted by momaka
      Still save that video card, though. The HD4850 and HD4870 video cards have much higher chances of working after a reflow. I've heard the Radeon HD2000 and HD3000 series are like that too.
      By the way, I have a curious question about your GeForce 8800 GTS: what resistance do you get for the GPU V_core to ground and RAM Vdd/Vddq to ground? (Also, what is the lowest resistance your multimeter can measure?)
      I am getting 0.2 Ohms for GPU V_Core and around 24 Ohms for RAM Vdd/Vddq supply. Just checking, because I reflowed my 8800 GTS twice now, and it's still dead as a rock. Can't even post the PC with a PCI/AGP card to view the 8800 GTS' BIOS.
      I've tried twice to reflow the 4870 and it did'nt change, still boots but with garbage on the screen.
      You ask in the right time about the 8800 because it died yesterday and I'm going to reflow it tomorrow I can measure what you need today and tomorrow after the reflow.
      but like I said I'm not so good at electronics and I didn't find where I should measure what you need.
      I attach two photos of my card.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        #43
        I had one 4850 do that. Eventually, I got it going, though. But it still artifacted a little bit afterwards under high stress with game benchmarks. So I think a reball may be the next thing I try on it. I haven't done reballing in a very long time, so I think of this as a good opportunity to try it again.
        Anyways, you can try reflowing yours again at a slightly higher temperature. And keep reflowing until it dies if it doesn't work. After all, a video card with artifacts is hardly any better than a dead one, so if it dies from reflowing, I don't think it would be a big loss.
        Ah, my bad luck must have gotten to your 8800 GTS too.
        Below in my post is a revised image of your pictures that shows where you can find the RAM Vdd and GPU V_core. You can measure the resistance there (when the video card is not powered) and voltages (the the video card is powered).
        • hikaruichijo
          • Aug 2015
          • 123
          • Spain
          #44
          I've reflowed it today and it's still alive, V_core to ground 1.3-1.4 omhs and V_ram to ground 25-26 omhs, the same before and after the reflow. V_core 1.27 and V_ram 1.89.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            #45
            Thanks.
            I'm getting very similar readings for the resistances (1.2-1.4 Ohms for the GPU and around 28 Ohms for the RAM), so at least that's good. If I remember correctly, the RAM was showing correct voltage too (around 1.9-2.0V) as was the GPU, though I don't remember what. Still dead as a rock, though. I'm wondering if I should reball it or if that's just beating a dead horse.
            (Plus, I don't have any stencils, so putting the new balls on there is going to be fun for sure. )
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Yes, I can confirm that at least the Radeon HD4850 cards have a really high success rate of working again after either reflow/reball. Got 3.5 out of 4 fixed already (5 more awaiting). They also seem to drop like flies, though.
              I suspect the Radeon 9800 Pro is like that, too, because back in 2007, I wanted upgraded video for my PC and I get random video corruption, even the BIOS screen! So I reseated the video card and it goes away, at least briefly.
              I did see stuff change on the screen when I moved the Radeon 9800 Pro around in the AGP slot... Looked like a perfect candidate for a reflow! But, being a rookie, I was hoping that an alcohol bath would fix it...
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • Drack
                Yup it's me
                • Nov 2016
                • 297
                • Venezuela
                #47
                Delidding those cards can help a lot in temps, 10c or more if the paste is dry as a bone
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  #48
                  I had an all in wonder 9800 SE die exactly like that. Having no knowledge about BGA failures I just moved it or resetted it and that would fix it for a couple of days. Finally the artifacts became permanent.
                  I still have it waiting for a repair. It could help if I knew whether gpu failed or ram ics
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    #49
                    I've seen too many ATI cards from that generation die with artifacts even when cooled. ChaosLegionnaire too.
                    Almost certain it's the GPU. And by that, it's probably not the BGA between the board and and substrate but rather substrate and core - i.e. similar to nVidia's bumpgate issue. Either that or something to do with electron migration. These older ATI video cards use leaded solder, so the BGA under the chip is definitely okay.
                    The good news is, you can often revive these cards with a bit of heat. I've actually found that I've had more success with lower temperatures of around 120-150C than at proper reflow temperatures (190-200C for leaded solder). So you don't even need to do a "proper" reflow to get these cards going. The bad news is.... it won't last long - not with the stock cooling, at least.
                    Anyways, all these old ATI flip-chip cards are doomed. I suspect up to the X1x00 generation. HD2x00 and newer started becoming more robust. If you want a reliable AGP GPU, go with Radeon 8500 or 9000. Or a GeForce 3, GeForce 4, or GeForce 5 (FX5200-FX5600) card. Those do NOT use flip chip and are actually pretty reliable.
                    • jiroy
                      • Jun 2016
                      • 2416
                      • Lebanon
                      #50
                      +5
                      Add to that a newer problem in some Nvidia VGA cards with the famous 'VGA driver stopped functioning and recovered"..
                      I think the critical question here ,Momaka , Is there reliable and new chipsets somewhere according to your knowledge ?
                      • DynaxSC
                        GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                        by DynaxSC
                        I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                        General test conditions:
                        - Tested with Core i5 6500 and Core I7 6700K - no difference
                        - Default BIOS settings, but tried also altering several memory setting - does not change anything
                        What is wrong:
                        With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                        When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                        03-21-2025, 06:23 PM
                        Thermal pad thickness for various laptop GPU / Graphics Cards
                        ASUS Dual RTX 2070 OC 8GB
                        ASUS ROG STRIX RTX 3080 OC
                        ASUS ROG STRIX RTX 3090
                        ASUS TUF Gaming RTX 3080 OC Edition
                        ASUS TUF GTX 1660 S-O6G GAMING
                        EVGA RTX 3060 Ti XC GAMING 8GB
                        EVGA RTX 3060 XC GAMING 12GB GDDR6
                        EVGA RTX 3080 FTW3 ULTRA GAMING
                        EVGA RTX 3080 TI FTW3 ULTRA GAMING
                        EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                        Gainward RTX 2080 Phoenix GS Specs
                        Gainward RTX 3070 Phoenix 8GB
                        Gainward RTX 3080 Ti Phoenix
                        GIGABYTE AORUS RTX 3080 MASTER 10G
                        02-09-2024, 08:08 AM
                        A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                        by momaka
                        More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                        And a shot of the label:...
                        01-26-2022, 03:26 AM
                      • nikovmiroslav
                        Gigabyte A5 X1 Need Bios
                        by nikovmiroslav
                        Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                        Gigabyte A5 X1
                        From motherboard:
                        S/N: 1TNH55ER1350895
                        P/N: 6-77-NH55ERQY-D02-2CGB
                        On sticker from the back of the laptop:
                        S/N: SN21351J000657...
                        Yesterday, 09:15 AM
                        Gigabyte G series G5 KF-5 Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte G series G5 KF-5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G5 KF-5 boardview and G5 KF-5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...
                        09-07-2024, 07:19 AM
