Norsat NewsLink laptop battery and charger
  • pentium
    • Mar 2006
    • 2778
    Re: Norsat NewsLink laptop battery and charger
    From what I hear, a stock C2D can go pretty cheap because everyone is buying ones as upgrades and tossing away their stock one.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      if only they made a desktop board for such a thing...
      sigpic
      (Insert witty quote here)
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        They do.
        Mann-Made Global Warming.
        - Dr Seuss
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          They made laptopa with deaktop p4 chops
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            No but I can eat pork chops on my lap.
            - Dr Seuss
              • 31072
              they arent desktop p4's, they are lower power versions that cost a lot more.
              i have a 1.4 in a laptop here.
              • pentium
                • Mar 2006
                • 2778
                I can debate that.
                I have seen a system that used a regular Socket 478 P4 in a laptop however the system was so cheap, it also used regular PC3200 sticks and totally lacked a battery and just had a proprietary power connector.
                Find Nedry!
                  • 31072
                  well it must have had one hell of a heatsink!
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Originally posted by pentium
                    I can debate that.
                    thats called a RIPOFF.
                    sigpic
                    • pentium
                      • Mar 2006
                      • 2778
                      If it helps any, the brand was so obscure, google could not even find it.
                      Find Nedry!
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        nope. iirc it was a p4 2.8 (400mhz fsb) with an enormous double heatsink and two big fans-and to make space for these huge heatsinks it was about 2" thick. it was cool in that it has an access panel on the bottom that let you remove the heatsinks easily and swap out the procs. but it was uncool because the mobo was bad
                          NVDC charger configuration...
                          11-05-2024, 03:28 PM
                          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                          Narrow VDC applications where the system power source is
                          either the battery pack or the regulated output of the charger.
                          This makes the max voltage to the system equal to the max
                          battery voltage instead of the max adapter voltage. Operating
                          at lower system voltage can improve...
                          11-05-2024, 04:43 PM
                        • serious_electron
                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                          by serious_electron
                          Hello Everyone!
                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                          06-28-2025, 02:57 PM
                          Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                          The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                          The bq24745 features dynamic power management...
                          10-23-2024, 02:50 AM
                        • flat-earther
                          how to prevent a connected charger from draining battery when not charging?
                          by flat-earther
                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                          So the battery is backfeeding the charger and being drained.
                          How can I prevent...
                          08-07-2025, 01:04 PM
