Sd card picture recovery
  • vinceroger69
    • Mar 2012
    • 6714
    Hi a relative has deleted some pictures by mistake on her camera is there any free sd card data recovery software that you guys know of thats good, i have saw a few online but there only trial versions or limited to 2mb of recovery have you guys used any good free software in the past? many thanks
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Sd card picture recovery
    Yes, http://www.cgsecurity.org/wiki/PhotoRec I've personally used it many times.
    • vinceroger69
      • Mar 2012
      • 6714
      Thanks again diif for your help i appreciate it.
      • diif
        • Feb 2014
        • 6978
        • England
        You're welcome Vince.
        • vinceroger69
          • Mar 2012
          • 6714
          diif slightly of topic im after a set of speakers for my own laptop im using its a toshiba equium A300d-16c harman /kardon ive saw some on ebay but there stupid money the cone etc is torn on this and unrepairable i dont want too spend too much on this laptop so the cheaper the better any ideas?
          • diif
            • Feb 2014
            • 6978
            • England
            Are they so you can watch YouTube videos a bit louder then one of the clip over the top of the laptop soundbars will do, something like http://www.ebay.co.uk/itm/Isotech-US...-/161989169404
            They are better than laptop speakers but my sensitive ears do not like them for music and I get a headache after a few minutes but then I get this with any poor quality sound.
            I personally have a Kenwood amp and a pair of JBL Control One hooked up to my PC, they are magnetically shielded so no risk of damaging anything delicate.
            I do like my music though and the stereo in my front room has three amps and nine speakers.
            There are also the 2.1 speaker sets I see, two speakers and a sub. They give better sound than the soundbars due to the bigger speakers but aren't so portable.
            I think it comes down to what do you want them for and budget.
            • vinceroger69
              • Mar 2012
              • 6714
              those ones in the ebay link look ideal for now as portable too and untill a pair of speakers turns up on ebay etc or even a parts laptop cheap its certainly not worth spending loads on it as i reflowed this laptops gpu last year fault but hey still works great.
              • diif
                • Feb 2014
                • 6978
                • England
                Yeah, they're not to bad, definitely better than stock laptop speakers.
                • junktv
                  • Nov 2010
                  • 3065
                  Another one is recuva from the same company that does malwarebytes.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Thanks for the info they also do ccleaner too which is quite good.
                    • junktv
                      • Nov 2010
                      • 3065
                      Ah crap it is ccleaner not malwarebytes. But yeah it's saved myself and a few other i know a few times.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        I use malwarebytes too myself have it on all of my pcs but had a issue with a mates pc yesterday where malwarebytes found nothing wrong all clear etc but adwcleaner found 12 issues and sorted the malware issue out straight away.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          I've seen Zeus the banking malware evade both Sophos and Microsoft's enterprise endpoint software. In fact it evaded a regular scan and was only found my Malwarebytes in safe mode.
                          It had been on the laptop for 4 years.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            thats maybe why malwarebytes did not pick some stuff up then i will try in safe mode next time.
                            • kalgari
                              • Oct 2018
                              • Lithuania
                              Check this guide as well: https://howtorecover.me/recovering-p...otorec-android. I suppose PhotoRec is really the best free software for recovering pictures.
                              • Hondaman
                                • Sep 2008
                                • 1062
                                Try GetDataBack from Runtime Software. They have different versions for FAT and NTFS. I have used it to recover .MOV (QuickTime) files off my dash cam's memory card as well as JPEGs from the SD card in my Canon S3IS.
                                • JJAAMM
                                  by JJAAMM
                                  Problem
                                  07-06-2023, 06:01 AM
                                • Kemer
                                  Graphics Card mounting frame
                                  by Kemer
                                  Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                                  As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                                  I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                                  What worries me right now is the possibility that...
                                  09-14-2024, 08:57 AM
                                • Tr0ll
                                  by Tr0ll
                                  Original T-con:
                                  First replacement T-con:
                                  10-07-2023, 07:48 PM
                                • bajdik
                                  HP 15-dc1020nc OMEN picture only on external USB video card
                                  by bajdik
                                  I bought broken HP 15-dc1020nc OMEN laptop.
                                  Power on without screen.
                                  On the board was damaged one mosfet on the GPU power line.
                                  I change this ic but still the same. I think, that the GPU is damaged.
                                  So I bought for 150 USD new Nvdiia chip. Still no picture.
                                  After that, I fixure out the laptop boot into windows (welcome sound). I put external USB graphics card and the laptop works great. In device list, no GPU is listed. I'm not sure if that laptop has integrated intel gpu disabled or not.
                                  Any idea? On the alisaler.com is bios for board and gpu, but is not...
                                  04-28-2023, 02:50 AM
                                • FZG
                                  EVGA Nu Audio Sound Card - Not Working
                                  by FZG
                                  I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                                  The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                                  I found...
                                  03-07-2025, 11:44 AM
