I have an 18 volt drill battery charger and the transformer is open, I only have a 24 volt transformer to replace it with, Will that work with out overloading the regulator .
					18 volt drill power supply.
Re: 18 volt drill power supply.
Pictures of what we are dealing with will help.Never stop learning
First, it's entirely possible that the transformer's thermal fuse has blown but only due to a temporary condition. Put the transformer on a heat resistant (fire-proof) surface, put a new thermal fuse on, and test for overheating. Using it in a hot area, bits of drilled material or dust clogging inadequate vent slots in the charger casing, it happens... clean it up and drill some more vent holes if the transformer seems okay with a new fuse.
However, an 18V drill doesn't necessarily have an 18V transformer. 18V is just the nominal voltage of either 15 NiCd or NiMH cells in series, or 5 Li-Ion cells in series. The actual voltage the pack attains at full charge is closer to 21V.
Plus, transformers are typically rated for AC voltage, so if you have one rated for 24VAC, after bridge rectification it could be as high as 32V. Right off the bat you're going to want to check the smoothing capacitor to see if it's even rated that high, and get the part # marketing off the regulator and/or charger IC, assuming it has one (exact make and model drill and charger might help) and consult their datasheet(s) to see what voltage range they can accept, and how they work might be demonstrated by one or more example circuits.
Look at the example circuits and see if what's in the charger seems roughly if not exactly the same to some extent. You'd be looking at what the max voltage ratings are for any components that see the max voltage, or the heatsinking for any that drop voltage.
Now that I've written this much, I realize I'm probably wasting my time since the topic was started over 10 days ago and two prompt replies but nothing more from the original poster.
Anyway, if it's a dumb (trickle) charger then transformer voltage being right is VERY important. If it's a rapid charger then the transformer is capable of higher current and assuming you want the replacement transformer to fit in the charger casing good, going with a higher voltage than the original will tend to either be larger or lower current. Both "might" be worked around, or either might be a problem.
We're all about repairing things but have you considered picking up a used charger on an auction site or locally oriented sites like Craigslist or garage sales, pawn shops, etc?
Anyway, first thing to do is the first thing I mentioned. Get a multimeter, take the HV (AC) transformer wrapper off, cutting it if you can't peel it from the end, and measure whether the thermal fuse is open or conducting, a continuity or resistance measurement. There should be markings on it telling the model # for cross reference or the trip point temperature.
Do not use a replacement with much higher trip point temperature and rated for at least as much current, though the current on that transformer winding is going to be quite low. It's likely that most commonly available thermal fuses are capable of that much current.Comment
Assuming...7 Photos -
			by sam_sam_samThis is the switching power supply that is used in this project
https://www.ebay.com/itm/164440680270?var=464055952700
Here is the BMS protection board
https://www.ebay.com/itm/38688703079...iiBFn%2B3x1VjJ... -
			by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
			by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
			by sam_sam_samI would be open to a 24 volt @ 5 amp switching power supply that can be adjusted down to 21 volts permanently and the over load protection is still functional and low voltage cutoff 15 volt or higher if necessary
I would rather not have to use a buck converter to get the voltage that I need
So is anyone else that has successfully modify one for a slight lower voltage had good results willing to share with me the safest way to accomplish this task
I googled for a 21 volt switching power supply and did not find very much information for switching power supply... - Loading...
