I was looking at an ad for a Dell Dimension 300 for sale (2002 model) and can't find this. Has anyone heard of a 300?
Dell Dimension 300? Is there such a computer?
Re: Dell Dimension 300? Is there such a computer?
i think it's supposed to be a Dimension 3000, as this model number exists
http://compreviews.about.com/od/budg...Dimens3000.htmLast edited by Scenic; 07-01-2008, 08:43 AM. -
Scenic, the 3000 you linked is a 2004 model: I think AK is referring to a X300 model, being X a number. E.g. a Dimension 2300 or a 4300: get pictures to compare it.
ZandraxHave an happy life.Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
Howdy folks,
I've risen from the grave to ask more questions about old obsolete Dells.
I've acquired a Dell Dimension 4550 which is in need of a PSU - I've several PSUs from Dell Dimension B110s, and I'm wondering if one of them could be used. The PSUs and the 4550 use a 20-pin connector and a 4-pin connector.
The issue is, I've been told that Dell really likes using proprietary hardware, and there were concerns about damage being caused by an incompatible supply. Because of this I'm assuming it's not just a simple plug-and-play and that there's more... -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
- Loading...
