Dell Dimension 300? Is there such a computer?
  • AKBessy
    • Feb 2007
    • 131
    I was looking at an ad for a Dell Dimension 300 for sale (2002 model) and can't find this. Has anyone heard of a 300?
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Dell Dimension 300? Is there such a computer?
    i think it's supposed to be a Dimension 3000, as this model number exists
    http://compreviews.about.com/od/budg...Dimens3000.htm
    • zandrax
      Hit and miss
      • Dec 2007
      • 1157
      • Italy
      Scenic, the 3000 you linked is a 2004 model: I think AK is referring to a X300 model, being X a number. E.g. a Dimension 2300 or a 4300: get pictures to compare it.
      Zandrax
      Have an happy life.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • SwedishDiesel
        Dell Dimension PSU Compatibility - B110 PSU in 4550
        by SwedishDiesel
        Howdy folks,
        I've risen from the grave to ask more questions about old obsolete Dells.
        I've acquired a Dell Dimension 4550 which is in need of a PSU - I've several PSUs from Dell Dimension B110s, and I'm wondering if one of them could be used. The PSUs and the 4550 use a 20-pin connector and a 4-pin connector.
        The issue is, I've been told that Dell really likes using proprietary hardware, and there were concerns about damage being caused by an incompatible supply. Because of this I'm assuming it's not just a simple plug-and-play and that there's more...
        12-18-2022, 06:58 PM
        Dell Dimension 8200 Schematic
        LA-1221...
        10-04-2024, 07:48 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
