Ratdude's main rig V5.0
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Ratdude's main rig V5.0
    More window shopping:
    http://www.ebay.com/itm/Adaptec-ASR-...IAAOSw7ZlZny1y
    Cheapest 8 Port SAS controller with BBU. I have brackets of similar size to hack on... cheapest one with a bracket (and 8 ports/BBU) is $47, so for $27 I'll cannibalize an old 3ware 9500 or the like.
    Best part is being adaptec, my array would be a direct swap... uses PCIe 8x so might even be the same chip.
    And for RAM: From what I'm seeing the going rate for PC3-10600R DDR3 (ECC) is $10 per 4GB Module and $30 per 8GB module. F*ck. The board will cost less than the F*cking RAM!
    So If I do snare an upgrade board, it might be awhile until I can afford the RAM.
    sigpic
    (Insert witty quote here)
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Originally posted by Topcat
      The DTI doesn't have onboard audio.
      The odds of that NIC frying are pretty low....I still think its some kind of conflict with that GPU....thats when all the NIC trouble started.
      But the X8DAH+-F does.
      I don't see how a GPU conflict would do this. No option ROM. No port activity in standby. That's a failed chip or a bad enable jumper (which I've confirmed isn't the issue).
      Edit- did see this: http://www.tomshardware.com/forum/30...plug-upgrading
      I'll hard reset the BIOS and see what happens.
      sigpic
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        I think I f*cking killed her.
        Pulled the main board to look for PCB damage (resetting CMOS didn't help). Upon inspection I found 5 wrong jumpers: watchdog, and 4 for I2C over PCIe and PCI-X; all were enabled and according to manual are disabled by default.
        I also found a large bypass SMD ceramic cap that had both solder joints cracked (hanging by a thread), which was knocked off at some point. Board removal didn't go well, so it's very possible that's fresh damage. I resoldered it, which seemed to go well.
        Reassembled it, she won't even spin fans. Nothing. tried both hot swap PSU bays and two known supply modules. also tried starting it with a screwdriver to the header. Not looking good for the board.
        Suggestions for what would cause such?
        sigpic
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Looking at Supermicro AMD boards:
          http://www.ebay.com/itm/Super-Micro-...gAAOSwnF9Y7szn
          They make 6 core CPUs for those. I'd need to get RAM (or rob V4.1's 16GB or use the 8GB that used to be in it) if I went down that road. Unlike the the socket 940 version of this (what's in V3.8), NIC teaming in windows 7 is supported. Pending a benchmark check, I might put in a lowball offer on it... thoughts? Edit- the fastest 6 core one can drop in is 50 passmark points ahead of what I have (Read: a wash). However, while CPUs are cheap for these ($16 for a pair of slightly slower 6 core units!), it's only PCIe 1.0 which for my GPU could be a bottleneck (the GTX 970 ran fine on PCIe 2.0 but 1.0 is probably cutting it close).
          If I had my druthers I'd nab a H8DG___ board... those support up to 12 core CPUs and have LSI SAS built in. But they're still pricey as **** right now.
          sigpic
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            which board did you kill? the x7dwa?
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Yes.
              Not spinning fans makes me think I'm missing something. Before I go to bed I might try rigging a different PSU to see if the backplane for the PSU modules is the issue.
              Another option:
              http://www.ebay.com/itm/Supermicro-X...torefresh=true
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Boy genius here did something smart all right ... I both had the front panel ribbon backwards, and also screwedriver'd the wrong end of the header. Doh!
                No LAN activity. The controller isn't even getting warm... and it's a die'd chip with a heatsink. Even with all cards pulled and cmos fully cleared.
                Grr...
                sigpic
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  I thought those ribbons were keyed..... lol....
                  ...but if you do move to the X8 platform, nehalem/westmere processors are wonderful.
                  Fastest quad-core westmere: http://www.ebay.com/itm/352155915956
                  Fastest hex-core westmere: http://www.ebay.com/itm/192291451054
                  I went with the 3.6GHz dual quads. I just don't have anything that will tax 12 cores (or even 8 for that matter)....so I went with the extra MHz....and they're about half the price.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    I saw all sorts of westmeres for dirt cheap. Yay blade server scrapping (which is where I bet most come from).
                    sigpic
                    • dmill89
                      • Dec 2011
                      • 2534
                      Yep, at work we have a 5-year replacement cycle on servers and many other companies have similar replacement schedules, so Westmere and even Sandy-Bridge Xeons out of scrapped servers are flooding the market driving down prices.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Only if you use my adapter
                        Nope, raw pin header like all my other SM boards.
                        sigpic
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16958
                          Ok, computer basics 101.... red stripe on the ribbon is always pin # 1.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            ^and pin 1 wasn't well marked
                            Ended up passing on the board. Ended up selling for $68, but truth be told it was a money pit due to RAM required.
                            I'll keep my eyes open for another x7DWA-n board (or other capable board)... no teaming sucks, but It's not worth spending hundreds of dollars I don't have.
                            sigpic
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              New theory:
                              When I first swapped GPUs, the board did get hit in that area. While there is no visible damage, I wonder if a BGA joint failure at the NIC (which is in the area hit) could have happened... would explain why it would sometimes come and go, but usually not work at all.
                              Sadly I don't have a hot air station, so no good way to test it... but I'd like to sometime.
                              sigpic
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Apparently I never updated this thread.
                                Awhile back the remains of this system (along with a replacement X7DWA-N and an identical case) were built up into a replica of the original build... which is my wife's current rig.
                                No pics because it's literally the exact same thing other than different optical drives (maybe).
                                Posting this because I'm linking this in a new thread.
                                sigpic
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  I'm an idiot... I did post it, and it was lost in the bowels of the forum.
                                  https://www.badcaps.net/forum/showthread.php?t=74328
                                  sigpic
                                  • cheeky2
                                    by cheeky2
                                    05-25-2024, 03:27 AM
                                  • Dani_2024
                                    by Dani_2024
                                    10-28-2024, 05:06 PM
                                  • ygorsan
                                    by ygorsan
                                    🧩 Problem Summary:
                                    • I
                                    07-28-2025, 08:34 AM
                                  • Asraf Atb
                                    by Asraf Atb
                                    01-27-2025, 05:02 PM
                                  • JSin21
                                    Compatibility of main boards between different variations of samsung MU6100
                                    by JSin21
                                    Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                    I have Samsung Smart TV UA65MU6100WXXY version DA01
                                    Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                    11-27-2023, 04:54 AM
