Laptop or Keyboard?
  • stevo1210
    • Oct 2006
    • 4156
    Laptop or Keyboard?
    Hi Everyone,
    Just got given an older Acer 5738ZG laptop today. Owner spilt a glass of red wine on the keyboard. When he took it here, it started up but would beep continuously during post - I assume the keyboard keys may be stuck internally cause of the red wine.
    Laptop still starts up no issues - works fine with external USB keyboard. Cannot see any spill to the motherboard.
    I removed the keyboard and gave it a good rinse down with distilled water and isopropyl alcohol - then sun dried. Plugged it back in and keyboard is completely dead - does not work at all. Doesn't do the stuck key beep thing anymore however.
    So before I start sinking cash into it (otherwise we will bin it) - dead keyboard or dead motherboard? Could the wine spill have ruined the keyboard and motherboard keyboard circuitry???
    Thanks.
    • 31291
    Re: Laptop or Keyboard?
    been there, done that.
    keyboards are only about $15 new on ebay.
    if you dont want to risk it without being sure, bust the keyboard open and use a bit of wire to short the matrix for a few keys to see if they register on the screen.
    • diif
      • Feb 2014
      • 6978
      • England
      Its possible but unlikely. Have you've stripped the laptop down and checked inside ?
      • stevo1210
        • Oct 2006
        • 4156
        Yup, have cleaned out the insides of the laptop. It looks nice and clean in there.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Yeah, replace the keyboard.
          sigpic
          (Insert witty quote here)
          • playit
            ps/2 port keyboard dead ? p5ql pro / ethernet cable light
            by playit
            my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
            my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
            few years back ps2 mouse stopped working, but ps2...
            12-23-2024, 06:05 AM
          • unick
            Laptop HP 850 G2 Keyboard error after Windows 11 update
            by unick
            Hello
            i have following problems on HP 850 G2 laptop and 840 G2 laptop. After win11 update 24H2 the keyboard and touchpad stop working. I delete the keyboard from device manager and restart : work. If i shut down the laptop and restart after 5 min the problem apear again: no keyboard and no touchpad active. I have used also hp driver from oficial sit but no luck. I have modified with regedit " i8042prt Start REG_DWORD with 1, but no suscces. Any ideea?
            09-15-2025, 07:47 AM
          • Hondaman
            Laptop external keyboard?
            by Hondaman
            Can I use an external keyboard with a modern (as of this post) laptop from, say, Dell?
            I am worried about durability because I am a cheap, frugal person. I suspect an external keyboard would extend the life of the laptop. I have always been a desktop person, since my AMD 386DX-40, and I really don't know about laptops (though the current Dell products look like they are fanless, which eliminates a big failure point).
            (Also I prefer the "clicking" "Unicomp" keyboard, which is still made an hour or two away from me in Lexington KY, using the same equipment...
            10-30-2023, 12:04 PM
          • max-power
            Dell E6540 laptop completely dead after dssasembly
            by max-power
            Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
            that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
            After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
            03-24-2025, 08:49 AM
          • SimsonS53
            Asus RoG Strix GL553V - Keyboard Dead
            by SimsonS53
            Good day,
            it just so happen that I got my hands on a Asus RoG Strix (GL553VD ~2017),
            in absolute mint condition. But with a "dead" keyboard.
            I checked all the obvious stuff:
            Condition of the connectors, there is absolute ne evidence of liquid damage or mechanical stress. As mentioned, absolute mint condition, as it was actually never used.
            All keys have no function at all, and doesn't work in the UEFI.
            So I don't think it's an software/driver related issue.
            I also set the UEFI to defaults to verify it's no software issue.
            07-23-2023, 10:19 AM
