nforce 680i lt sli: Wont Install On New/Used HDD
  • speedypro
    • Feb 2013
    • 561
    As title. Bios sees hard drive but wont wont install. We've tried many type dvds and same issue. Most times the computer will just hangs on few percent; sometimes it complains no hdd is attached (this is when windows is booted from the dvd). I feel this is related to bios? No? Put this computer in the bin?
    Anyhow, if you have a bios bin for this, it'll be grateful.
    Bord here: http://www.nvidia.co.uk/object/desig...0i_lt_sli.html
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
    • 31201
    Re: nforce 680i lt sli: Wont Install On New/Used HDD
    what psu and drive are you using?
    did you try different sata cables?
    • speedypro
      • Feb 2013
      • 561
      The original psu failed so ive replaced with new: antec 620w. sata cables are ok
      • diif
        • Feb 2014
        • 6978
        • England
        Hard drive and memory check out ? Tried installing with just one stick of memory ?
        • speedypro
          • Feb 2013
          • 561
          F me! It was actually because I've missed off a molex plug to the MB! All is ok now.
          • japlytic
            DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
            by japlytic
            In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
            Tried (only with keyboard/mouse connected):
            • BIOS + database update
            • Using latest Windows 11 image built with official image creation tool
            • Previous setup version for Windows 11 installer
            • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
            • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
            • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
            06-19-2025, 04:59 PM
          • 24gsm
            MacBook Pro A1708 install macos fail
            by 24gsm
            hi to all
            i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
            after enter to recovery and format hdd 1to .
            after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
            can help please
            Serial Number: FVFXP0U0HV2J
            Config Code: HV2J
            Find My Mac: OFF
            04-16-2025, 03:57 AM
          • duwane
            A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
            by duwane
            Hi All.
            Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
            The issue:
            Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
            10-26-2022, 07:02 AM
          • tommy97
            ASUS FA507R - BLOD, cannot install windows
            by tommy97
            I have an ASUS FA507R in for repair where I’m unable to install any operating system. The laptop works fine when booted from an external Windows or Linux drive, but any attempt to install on an NVMe SSD fails.
            I’ve already tested with three different SSDs (Gen 3 and older), and the issue persists. The laptop originally came in with a faulty SSD showing 0% health....
            08-22-2025, 07:55 AM
          • TrumanHW
            MacOS: R|W Programmers like CH341x BINs..?
            by TrumanHW
            For years I tried figuring out how to R|W BINs from my CH341x programmer.
            From FTDI's pkg, Apps specifically claiming they work, I failed for ~8 years.
            I'd expect many here figured it out (easily), but in case not ...
            It's one of the few forms of "how-to" remuneration I can GIVE BACK.
            This group is both GENEROUS & literally BRILLIANT / GENIUS!!!
            This may be the easiest means to copy-paste:
            Code:
            SERIAL -to- USB - CH341 ROM (MacOS):
            Install xcode:				xcode-select --install
            Relocate
            04-08-2022, 02:33 PM
