Linux Installation to USB
  • nkeck72
    Enthusiast
    • Oct 2015
    • 21
    So I have the old D505 laptop, and have determined that the latest Linux I can install on it is Fedora Core 5. Finding installation media was no problem, but I need to be able to install it to USB. Every time I try to install, drivers load, media checks out OK, asks for my keyboard type and then I get "no valid devices were found on which to create new filesystems." This happens in both the graphical and text-mode installers.
    My prblem is that if it thought the USB hard disk was nonexistant it wouldn't have loaded the usb-storage driver at startup and would have told me before graphics mode even started to give the path to a hard disk controller driver.
    Do I have to create the partitions manually, or is there even a way to get the installer to work? And if there is a way to get it to work, is it an easy fix?
    Cheers!
    "It won't take long if you take it one byte at a time." - me
    "WHOSE IDEA WAS THIS?" - too many people to count
    "Go back to the depths of SourceForge from whence ye came."
    All my software crap: https://www.github.com/nkeck720
  • SteveNielsen
    Retired Tech
    • 2327
    Re: Linux Installation to USB
    I would try a different distribution of Linux designed for lower end hardware, like Lubuntu. I don't think that machine is going to like FC5 even if it would install.
      • 31002
      the fedora installer needs a gig of ram to operate for a start.
      btw, if you have a decent bios on that thing, see how it mounts usb media.
      is it simulating something else? or is it using EHCI ?
      • nkeck72
        Enthusiast
        • Oct 2015
        • 21
        The only clue to how it mount USB media is an option to turn USB emulation on or off.
        I may try Lubuntu, as suggested by SteveNielsen. The only requirement I have is that it has to install to USB media, I do not have an internal HDD for this laptop.
        Cheers!
        • SteveNielsen
          Retired Tech
          • 2327
          You can install Lubuntu to a USB drive. There are instructions online for that. What do you hope to do with the laptop? It's going to be pretty slow.
          • nkeck72
            Enthusiast
            • Oct 2015
            • 21
            It is going to simply be a development machine, no more no less. I just need a feasible OS (and Windows 95 is just too old.).
            Cheers!
              • 31002
              turn off any "emulation",
              the linux kernel will bypass bios routines once it runs.
              • Longbow
                • Jun 2011
                • 623
                Anything can be installed to a USB. At this point, you can't partition and format the drive due to the way you have the USB mounted. OSDisc sells USB flash drives pre-loaded, but even then your bios has to be able to boot from USB. A similar situation exists when you are making a boot CDROM.
                Is it plugged in?
                • nkeck72
                  Enthusiast
                  • Oct 2015
                  • 21
                  The drive can be formatted and partitioned under DOS and Win95 though. My only other option is to turn emulation off and not have it mounted at all.
                  Cheers!
                    • 31002
                    if you are using a boot-cd/dvd,
                    turn the emulation off, and boot the disc with the usb stick plugged in.
                    linux *will* find the stick.
                    after it has done the install and wants to reboot, you can re-enable the emulation if it wont boot.
                    • nkeck72
                      Enthusiast
                      • Oct 2015
                      • 21
                      Installed Lubuntu, it works like a dream! Thanks for your help on the issue.
                      Cheers!
                      • DynaxSC
                        ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                        by DynaxSC
                        I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                        Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                        Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                        The behaviour is also really very strange, i.e.:
                        • The disk shows always up in BIOS - so it is recognized, so far so good
                        • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                        02-23-2025, 01:33 PM
                      • ivtec
                        install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
                        by ivtec
                        Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
                        01-17-2025, 12:54 PM
                      • duwane
                        A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                        by duwane
                        Hi All.
                        Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                        The issue:
                        Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                        10-26-2022, 07:02 AM
                      • Benass
                        Surface Laptop 3 Not Detecting SSD - Need Help!
                        by Benass
                        Hey everyone,
                        I'm having an issue with my Surface Laptop 3, and I could really use some help. I've tried everything I can think of, but my laptop just won't detect any new SSDs I install. Here's a rundown of the situation:
                        Problem:
                        • My Surface Laptop 3 isn't detecting any new SSDs, including a Sabrent Rocket 2230 256GB NVMe SSD and a Dogfish 256GB M.2 2230 NVMe PCIe Gen 3.0 x4 SSD.
                        • Both SSDs work fine in other laptops, so I know they are functional.
                        • The laptop does detect a Forsee 64GB SSD from my Steam Deck, and I can successfully install Windows on it.
                        What I've Tried:
                        1. Compatibility
                        07-22-2024, 11:26 PM
                      • japlytic
                        DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                        by japlytic
                        In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                        Tried (only with keyboard/mouse connected):
                        • BIOS + database update
                        • Using latest Windows 11 image built with official image creation tool
                        • Previous setup version for Windows 11 installer
                        • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                        • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                        • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                        06-19-2025, 04:59 PM
