Linux Installation to USB
  • nkeck72
    Enthusiast
    • Oct 2015
    • 21
    So I have the old D505 laptop, and have determined that the latest Linux I can install on it is Fedora Core 5. Finding installation media was no problem, but I need to be able to install it to USB. Every time I try to install, drivers load, media checks out OK, asks for my keyboard type and then I get "no valid devices were found on which to create new filesystems." This happens in both the graphical and text-mode installers.
    My prblem is that if it thought the USB hard disk was nonexistant it wouldn't have loaded the usb-storage driver at startup and would have told me before graphics mode even started to give the path to a hard disk controller driver.
    Do I have to create the partitions manually, or is there even a way to get the installer to work? And if there is a way to get it to work, is it an easy fix?
    Cheers!
    "It won't take long if you take it one byte at a time." - me
    "WHOSE IDEA WAS THIS?" - too many people to count
    "Go back to the depths of SourceForge from whence ye came."
    All my software crap: https://www.github.com/nkeck720
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Linux Installation to USB
    I would try a different distribution of Linux designed for lower end hardware, like Lubuntu. I don't think that machine is going to like FC5 even if it would install.
      • 31294
      the fedora installer needs a gig of ram to operate for a start.
      btw, if you have a decent bios on that thing, see how it mounts usb media.
      is it simulating something else? or is it using EHCI ?
      • nkeck72
        Enthusiast
        • Oct 2015
        • 21
        The only clue to how it mount USB media is an option to turn USB emulation on or off.
        I may try Lubuntu, as suggested by SteveNielsen. The only requirement I have is that it has to install to USB media, I do not have an internal HDD for this laptop.
        Cheers!
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          You can install Lubuntu to a USB drive. There are instructions online for that. What do you hope to do with the laptop? It's going to be pretty slow.
          • nkeck72
            Enthusiast
            • Oct 2015
            • 21
            It is going to simply be a development machine, no more no less. I just need a feasible OS (and Windows 95 is just too old.).
            Cheers!
              • 31294
              turn off any "emulation",
              the linux kernel will bypass bios routines once it runs.
              • Longbow
                • Jun 2011
                • 623
                Anything can be installed to a USB. At this point, you can't partition and format the drive due to the way you have the USB mounted. OSDisc sells USB flash drives pre-loaded, but even then your bios has to be able to boot from USB. A similar situation exists when you are making a boot CDROM.
                Is it plugged in?
                • nkeck72
                  Enthusiast
                  • Oct 2015
                  • 21
                  The drive can be formatted and partitioned under DOS and Win95 though. My only other option is to turn emulation off and not have it mounted at all.
                  Cheers!
                    • 31294
                    if you are using a boot-cd/dvd,
                    turn the emulation off, and boot the disc with the usb stick plugged in.
                    linux *will* find the stick.
                    after it has done the install and wants to reboot, you can re-enable the emulation if it wont boot.
                    • nkeck72
                      Enthusiast
                      • Oct 2015
                      • 21
                      Installed Lubuntu, it works like a dream! Thanks for your help on the issue.
                      Cheers!
                      • DynaxSC
                        ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                        by DynaxSC
                        I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                        Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                        Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                        The behaviour is also really very strange, i.e.:
                        • The disk shows always up in BIOS - so it is recognized, so far so good
                        • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                        02-23-2025, 01:33 PM
                      • Stanley1843
                        Windows 11 disk no boot
                        by Stanley1843
                        I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
                        I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
                        DISM /Online /Cleanup-image /Restorehealth
                        The DISM.... command shows me the error 87.
                        sfc /scannow
                        chkdsk
                        bootrec /FixBoot
                        bootrec /ScanOs
                        bootrec /RebuildBcd
                        For some reason it writes(Total identified installations 0) like there no...
                        10-18-2025, 04:41 AM
                      • ivtec
                        install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
                        by ivtec
                        Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
                        01-17-2025, 12:54 PM
                      • mkdj
                        Acer Swift won't boot after a Linux install
                        by mkdj
                        Dear all,
                        I have an issue with an Acer Swift laptop which won't boot (Acer Swift SF113-31-C7UK)
                        History and symptoms:
                        A friend of mine tried to install Linux on this laptop. After the installation, the PC did not reboot. When pressing the power button, backlight is working, capslock is working. But screen stays black.
                        What I have done so far:
                        As I suspected a BIOS issue, I tried to clean the TXE region, following the winraid guide for CSE TXE 3.1. I managed to do all the steps, including the steps involving the signing process with OpenSSH. The...
                        10-30-2025, 04:31 AM
                      • duwane
                        A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                        by duwane
                        Hi All.
                        Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                        The issue:
                        Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                        10-26-2022, 07:02 AM
