wd discontinues its green drive lineup
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    Originally posted by eteknix
    Western Digital has had several lines of hard drives for the past few years. Today, the lineup shrinks a bit as the WD Green brand gets folded into the WD Blue lineup. This move is apparently aimed at reducing consumer confusion when shopping for hard drives.
    Even with Green drives gone, WD still has a decent number of different colors. There is the Black which is aimed at enthusiasts, the standard consumer Blue, the NAS centered Red and the surveillance oriented Purple. The biggest difference between the Green and Blue drives was the slower spindle speed of the former. While the Blue advertised 7200rpm, the Greens had a range between 5400rpm and 7200rpm but really stuck to about 5600rpm most of the time. The biggest selling points of the Green drives were the reduced power consumption and price compared to the Blue. Of course, this came with a performance penalty due to the slower spindle speed.
    By removing the Greens and slotting the Blues in its place, WD is offering a small speed boost to the most budget users. For now, Green drives will be sold under the Blue brand, so be sure to check which specific model you are getting to ensure it's actually a ‘Blue'. In some ways, this change has long been coming. Rival Seagate long consolidated their consumer lineup with the 7200.14/Barracuda lineup which offered the power savings of the Greens but had slightly better performance compared to the Blue.
    Source: http://www.eteknix.com/western-digit...es-favor-blue/
    this happened about two months ago, so be careful when buying blue drives in future. u could end up with a slow laggy and unreliable hard drive!
    bet they also did that as a strategic move since their green drives are dropping like flies, nobody wants to buy them and they actually do not save power. because they are so slow, they spend most of their time at max load fulfilling data requests. also due to their high failure rate, u spend more time and power trying to recover data from them too!
    the parkgate issue with green drives did not help matters either as many ppl were annoyed with the head parking on their green drives which were too aggressive.
    the green line has developed a bad rep so it makes sense for them to quietly drop the green line and sneak it into the blue line.
    imo dropping the rpm to save power is a bad move. tests have shown while it does reduce idle power consumption, it didnt reduce load power consumption much which is the state in which the green drives spend most of their time at since they became so slow.
    they should have done what hitachi did with their p7k500 series back in 2007. hitachi tweaked their drive to use 40% less power during load and that made the drive faster (than the green) without slowing it down so much like killing the rpm. i'd say the japanese always get their stuff right. pity ppl dont see that the japanese are actually right all the time.
  • UraBahn
    Scrapheap Hound
    • Nov 2004
    • 165
    Re: wd discontinues its green drive lineup
    Eh, good riddance I say. All green drives are a waste of money as they really don't save any power (in fact, once you force-bludgeon their overly-aggressive and performance-stymieing "power reduction" settings off, they're even less efficient than regular mainstream 7200 drives, even though they spin at 5900 rpm. Complete rubbish!) Good to know that Worthless Drives is integrating the reprehensible Green line into their mediocre Blues - now I have a reason to avoid the Blue line completely!
    I don't plan on ever buying any WD drive that's not a VelociRaptor, as that's pretty much the only drive from them that's worth anything anymore.
    The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
    I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
    • japlytic
      • Oct 2005
      • 2086
      My younger sister's WD Green HDD failed as well (no backup!)
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8293
        I've got a few of the green WD drives. Out of 7, one failed 2 weeks after the warranty expired (one year), and another one out of old age 7-8 years (it was used as a C drive!). The rest are still spinning. I am also glad, that they are gone. Wouldn't have bought another one as they are slower then molasses at 0C. You can almost measure the performance with a calendar.
        • Uniballer
          • Jul 2013
          • 334
          They are not "gone". See Green to Blue Details. Apparently they make so much profit on the green drives that they are just "painting them blue" to try to increase sales.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Wow. What BS.
            Green drives are such shit. The latest 1TB Blue (WD10EZEX) is very good, but Seagate's ST1000DM003 is a few bucks cheaper and performs the same. Both are quite reliable.
            • diif
              • Feb 2014
              • 6978
              • England
              http://m.theregister.co.uk/2015/10/2..._becomes_blue/
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I have just one 2TB "Green" drive... it is slow... Alas I don't really have anything to compare it to other than an SSD (ha!), but even with Linux/systemd on it, it takes a while to boot. The drive light is basically pegged on the whole boot duration.
                The warranty just ran out on the drive (2 years), so knock on wood it continues to survive...
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3264
                  • Singapore
                  sry to rain on your parade but most likely it won't. looking at comments around the web, the green drives are notorious for failing just as the warranty expires.
                  i first bought the 1.5tb green when it first came out. failed within a few months of use as a backup drive. replacement worked well but sold it off a few months before the warranty expired.
                  also had another 1.5tb green in an elements external drive. drive would hang and freeze in the middle of copying/moving files. was also a pain to defrag. kept hanging and freezing until it eventually developed bad sectors. an even bigger major pain was transferring the data off it due to the slow usb2 interface. then sent it in for rma after transferring the data off. came back from rma as a 3tb external drive. sold it off for slightly below the price of the 1.5tb elements when i bought it.
                  so it looks like i was lucky in that i had mine fail before the warranty expired. feel sorry for those guys that had their drive fail after the warranty expired.
                  i also had a samsung ecofail green drive (hd154ui). utter crap. failed 3 times each time after a few months of use. never had such a failure prone drive. sold it off after the third time it came back from rma.
                  thus i determined no more green crap for me. they do not save power. instead they waste more power instead when they fail and u have to perform data recovery on them.
                  i also utterly despise the parkgate crap wd put on the green drives. utterly brainless feature the way they set it up...
                  • cruzinforit
                    Rin is my waifu
                    • Apr 2015
                    • 22
                    I actually have 3 of the green drives in use right now. All 3 are in 24/7 operation in my server alongside 3 3TB Toshiba 7200s. I check the SMART data on them regularly, and so far so good. The oldest one has 34k hours on it at this point. I do have my storage server in a Flexraid snapshot Raid-over-filesystem setup in case I lose one. I did lose a green drive once, but it was within 48 hours of purchasing it the bad sectors started to appear. I purchased it retail so it was a quick replacement at the store. Note that I did perform the wdidle tool to disable headpark on all of them. (Funny story, my pfsense firewall runs a WD Scorpio blue, which I also used wdidle on, and it did in fact disable the head park on that as well!)
                    • fzabkar
                      • Mar 2009
                      • 772
                      http://www.theregister.co.uk/2015/10...d_hgst_merger/
                      The good news is that HGST has executed a "reverse buyout" of WD.
                      A person who was close to the corporate action in Western Digital and HGST said: "All key positions are with HGST people; it's a reverse buyout. First HGST took Coyne's money to buy themselves (probably with a clause that Milligan is becoming CEO) and then they watched WD dismantling itself."
                      Hopefully Hitachi's superior products will replace WD's, unlike the case of the Seagate/Samsung merger where Seagate replaced Samsung's 3.5" technology with its own.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        drives that die shortly after installation were probably mishandled.aka newegg packaging.
                        there were big bad batches of everything during the flood crisis including wd greens.
                        i have several 2tb greens in dvr's 24/7/365 with no issues.the turds are the 1.5tb seagate barracuda lp.without exception these all died in under a year.every damm one of em!
                        the replacements from seagate were standard barracudas.those are ok with a few failures over the last 2 years.this is in a group of over 100 dvr boxes.
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          Barracuda LP? *shudder* those are terrible. Slow and unreliable.
                          • goodpsusearch
                            Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
                            by goodpsusearch
                            Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
                            First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
                            05-05-2024, 02:04 PM
                            HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                            This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                            09-12-2024, 02:00 PM
                          • federalhouse
                            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                            by federalhouse
                            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                            **Background:**
                            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                            **What I've Tried So Far:**
                            1. I accessed
                            08-01-2024, 07:03 PM
                          • reformatt
                            Intel iMacs, 3rd party SSD failures and Fusion setups
                            by reformatt
                            I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                            As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                            So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                            12-18-2024, 10:34 PM
                          • perfm2
                            HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
                            by perfm2
                            So I've worked on dozens of HP and Dell laptops and have never encountered this before.
                            Steps taken in my usual process.
                            Reset security settings in the BIOS
                            Ensure existing HD comes up into the OS
                            Shut down the laptop and disconnected the main battery
                            Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
                            Replace battery connector and close up the laptop
                            Insert my USB drive with my Windows 10 image I've...
                            03-21-2023, 08:45 PM
