No SSE2 - No YouTube with Linux!
  • bigbeark
    • Jan 2010
    • 661
    I recently loaded Lubuntu 15.04 onto my ASUS A7N8X2 machine (Athlon XP 2400). I was surprised that YouTube crashed immediately. Turns out Adobe Flash no longer supports CPUs that don't have SSE2. You can go to the Mozilla page and enable HTML5 which gives you video, but the quality is crap.
    Apparently there are "Extensions" that you can enable on an "about" page.
    If anyone is still using socket A and has done this workaround, did it work and were the results worthwhile?
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: No SSE2 - No YouTube with Linux!
    Crash player on linux... why???
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      I retired all my non-SSE2 machines including my AthlonXP 2200+
      Found out about this SSE2 need while installing on Gentoo as it checks CPUflags during installation. I was using Flash 10.x for a while as a workaround but eventually just chucked the whole setup after upgrading to Core2 CPUs...
        • 31090
        who cares - use this.
        https://sourceforge.net/projects/ytd2/.
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          I loved those Athlon Xps... Too bad... But nowadays even a Pentium 4 3GHZ or more with Hyper Threading can't browse smoothly unless there is a GPU capable of hardware acceleration.
          • bigbeark
            • Jan 2010
            • 661
            Success! Link http://www.linuxveda.com/2015/04/02/...firefox-linux/ shows you how to fix this.
            Type about:config into the address bar, hit enter and follow the directions.
            Toggling the media-fragmented fields caused my system to crash, so I reset those to false (default).
            I can now browse youtube at 1900x1200 and the CPU usage is way down. Flash always showed 95% usage, HTML5 is 60%. Big improvement!!
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              aside from doing it just to see if you can do it...why? Or is this your only computer?
              • bigbeark
                • Jan 2010
                • 661
                Why not?
                i am not a PC power user. Most of what I do is browsing, no gaming. Most of the video I watch is not HD. If I want to do video streaming I can watch the big TV upstairs.
                I have all kinds of hardware that meets my needs. I can use it or throw it out.
                • BC_TechForum_drb
                  Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                  by BC_TechForum_drb
                  Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                  Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
                  Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
                  2/ Figure 1 Gfx-D500-B Front Facing
                  3/ Figure 2 +5v supply (zoom-in)
                  Intro:
                  While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
                  12-07-2023, 09:55 PM
                • shamaltech
                  Asus Laptop Restart when loading YouTube !
                  by shamaltech
                  I have an Asus X510UN laptop.
                  It has a weird problem that it restart everytime while I'm loading the YouTube.
                  This happens only when the laptop plugged into charger.
                  When using battery power,it works fine and YouTube works without restarting.
                  Tried with Installing new Windows,changing SSD and also Flashing the BIOS.
                  Any help?
                  03-05-2025, 02:30 PM
                • tranquility
                  Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                  by tranquility
                  i want to repair an Onkyo TX-NR809 receiver.
                  symptoms:
                  on power on, display appears and i hear one click. enue functions is given.
                  - no hdmi output
                  - audio output not tested, but i think it is not there
                  - usb sticks are not recognized
                  if i read out the chips with display+standby button + tone+
                  both dts show only ????
                  chip is D830K013BZKB4
                  things i have done:
                  - reflow of the dts chip without taking off and reballing
                  - changed the aluminium caps without the big one with 25v because i dont...
                  Yesterday, 01:04 AM
                • tsavpyn
                  Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                  by tsavpyn
                  Dear all,
                  I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                  Now I have a problem that I am unable to dump my BIOS into bin file.
                  My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                  I searched for FPT but there is no Linux version and none of them work.
                  I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                  I would really appreciate it if anyone...
                  05-28-2024, 11:18 PM
                • mr.malcom
                  HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
                  by mr.malcom
                  this is a very strange Problem:
                  Notebook hang instantly on Boot. BIOS is accesable.
                  Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
                  Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
                  i have tried:
                  - only one RAM Stick, another working RAM, both RAM channel
                  - BIOS Flash to newest Version F.50, BIOS Reset
                  - Memtest86 hang instant at Test 2
                  - HP UEFI Diagnostic wont find...
                  02-26-2022, 05:19 AM
