Zorin Core-9 OS
  • bigbeark
    • Jan 2010
    • 661
    Zorin Core-9 OS
    I really wanted to like the latest Zorin release. It's thanks to them that I learned how to make photoshop work under Linux using the playonlinux package.
    I loaded some newer machines with the 64-bit version, and appreciated that it loaded pretty well every application I wanted without backfilling via Synaptic.
    On a 64-bit machine, it looks nice and works fine.
    But the 32-bit distro is a disaster. I loaded a socket A machine. It was a painful experience. The 32-bit distro for some bizarre reason comes with all the Compiz Fusion effects turned on as default. It felt like I was installing on an ancient 386 machine. Slower than a P2. After I had everything loaded, I removed all the fading,wobbling window effects, turned 'em all off. Still an unbearable pig.
    Put the Lubuntu disk in the drive, wiped out the Zorin. The difference is night and day. With Lubuntu, that machine is very quick.
    In summary, Zorin may be OK if you've got tons of ram and a modern processor, but it's just not for me.
    It does at least always display the Grub menu by default (I like).
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Zorin Core-9 OS
    Compiz is a turd that needs to die.
    Follow the white rabbit.
      • 31278
      Re: Zorin Core-9 OS
      if you have a low end machine then try Vector.
      http://www.vectorlinux.com/
      i put it on an old ibm T23 thinkpad (256meg ram, p3 cpu)
      and it runs just fine!!
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        Re: Zorin Core-9 OS
        why? Having a cube desktop that was inherited from beryl was awesome.
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          Re: Zorin Core-9 OS
          well, its full of memory leaks first off. Second is the littlest thing like switching driver versions will set it off. Its a turd.
          • Mad_Professor
            A Mech Warrior
            • Feb 2011
            • 1587
            Re: Zorin Core-9 OS
            What are you running?
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              Re: Zorin Core-9 OS
              It was back in my days of Ubuntu. 12.04. Unity. I had AMD graphics and it had major memory leaks. Something I couldn't afford with only 3gb if ram. They claim its a problem with NVIDIA. But having it with AMD/ATI just proves the claim false.
              I've moved from Ubuntu and I now rum OpenSUSE. Much better, but if the version jump doesn't fix the instability as of late I'm going to Gentoo. Its closer to what I started on; Unix.
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                Re: Zorin Core-9 OS
                Ubuntu is your problem. They like to butcher packages to make it fit their dirsto and not contribute upstream with fixes or bugs found.
                I've been having numerous issues with ubuntu, and I've moved on to fedora recently.
                I've played with compiz (or known as beryl at the time) on and off since it came to Ubuntu 8.04. quite fun.
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  Re: Zorin Core-9 OS
                  With how well Mint is doing with Ubuntu repos? fooled me! i thought they stayed close to the main branch.
                    • 31278
                    Re: Zorin Core-9 OS
                    wasnt mint going to switch to using debian?
                    • Mad_Professor
                      A Mech Warrior
                      • Feb 2011
                      • 1587
                      Re: Zorin Core-9 OS
                      Eh I stopped at LM 15 that thing was plagued with bugs even the install was broken. I heard it's all good now. BUt if it's based on ubunutu you're going have problems.
                      Actually they are moving away from rolling release going to a periodic update packs for current release and debian style schedule for new release.
                      http://www.zdnet.com/article/the-fut...d-derivatives/
                        ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                        This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-12-2024, 03:28 PM
                      • CG2
                        Janome DC3050 Sewing Machine Pedal Resistance
                        by CG2
                        OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                        Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                        04-14-2023, 07:53 AM
                      • Soulzink
                        Samsug washing machine. Power supply DC41-00189a board issue
                        by Soulzink
                        I am trying to fix a samsung washinmachine power supply main board.
                        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                        The power supply board reference is the following: DC41-00189a
                        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                        04-19-2025, 06:26 AM
                      • unimatrix93
                        How to stabilize AC voltage to CNC machine
                        by unimatrix93
                        Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                        I have a CNC machine wired to 3-phase 230V AC.
                        It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                        The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                        I contacted the electricity company but they refuse to help me solve this problem.
                        So I started to look around for some DIY...
                        03-17-2025, 05:52 AM
                      • xdever
                        820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
                        by xdever
                        I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
                        01-15-2025, 08:44 PM
