Win7 updates for upgrading to Win10
This is a sticky topic.
  • Xenon-Codex
    • 186
    • Finland
    #141
    Funny thing is that the other test thingy activated with a Win10 Home digital license. It's never been like that, only Win10 education all time, unless from the Fujitsu factory before the SCCM-install.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      Originally posted by grss1982
      Hi TC. Been a while since I posted here. Lurking mostly.
      So, by "creative" methods do you mean activating Windows 10 using a Windows 7 or 8 product keys? I've read that you can use an older Windows 10 installer like Build 1607 or Build 1703 which still gives the option to type a product key for activation then use a Windows 7 or 8.1. key to activate and once done just upgrade it to a latest Windows 10 build. At least this is what I've read in the interwebz.
      Long time no see! Glad you're still with us.
      Other creative measures is activation scripts....which will actually permanently activate a device with MS with HWID. Even if you format it and reload it, it will activate on its own without having to execute the script again.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • T4-BR
        T470S - TPM issue since TPM/BIOS update from Windows Update
        by T4-BR
        Many thanks for the high quality ressources available on your website.
        I'm currently facing some issues with my T470S:
        - I sat a Supervisor Password using special chars which was causing issues
        - Access to BIOS was locked but I was still able to use my PC
        2 weeks ago, I got an update of BIOS/TPM from Windows Update.
        Computer restarted and after Lenovo logo a loading bar appeared and at the end something went wrong + an error popped.
        Computer restarted one more time and I got the prompt for typing Bitlocker...
        09-26-2024, 02:50 AM
      • 0xx
        2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
        by 0xx
        Hi folks,
        My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
        What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
        I assumed that Windows Update was interrupted due to closing...
        09-14-2025, 03:46 PM
      • davidebeatrici
        Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
        by davidebeatrici
        I had 3 people contact me in a week because Windows suddenly didn't boot:
        As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
        The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
        Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
        06-17-2025, 12:59 PM
      • bogart219
        Lenovo ideapad 5 windows 11 update disable charging circuit?
        by bogart219
        Hello fellows. My Lenovo ideapad5 151al7 doesn't charge my battery, this seemed to happen right after an win 11 update, at least that is when I noticed it. I rolled back the update but it didn't matter. The laptop doesn't work off of the power adapter, which btw, I always leave plugged in and never really use the battery. New power adapter and battery, same problem. USB-c connector. The battery monitor in setup says "charger not installed", (but it is). Using a usb tester, with the battery plugged in it reads 20 volts but no current. With the battery unplugged it only reads 5 volts with...
        05-05-2025, 10:31 AM
      • Topcat
        The 2025 Operating System Thread
        by Topcat
        What OS are you running these days? I am down to 3 Windows workstations and one Windows Server on my LAN, everything that doesn't have a windows-specific need has been moved to Linux. Printing abilities with my large document centers are Linux's kryptonite; the reason for 2 of the Windows machines. The third machine still has Win7 on it, and isn't connected to the outside world. It has tons of software on it I use for diagnostics and updating various hardwares. My main rig is still Win10 Enterprise, so I had to vote Win10 in the poll...but I have overwhelmingly more linux machines than windows...
        Windows 11
        26.79%
        15
        Windows 10
        25.00%
        14
        Windows 8/8.1 or 7
        12.50%
        7
        Windows Vista (I'm a glutton)
        0%
        0
        Windows XP (I just can't let go!)
        3.57%
        2
        Windows 2000 / ME / 9x (Ok, this one is a funny, maybe!!)
        0%
        0
        Some flavor of Linux (brag on your distro in a post)
        28.57%
        16
        MacOS - OSX (Poor diluted souls!!)
        3.57%
        2
        Google Chrome/chromebox/chromebook
        0%
        0
        What's a PC? (The option for those with a phone stuck in their faces)
        0%
        0
        01-01-2025, 10:19 AM
