more win10 stuff
    • 31291
    Re: more win10 stuff
    the *only* stuff i cant run on linux is stuff using the usb & parallel port with custom drivers.
    if someone writes a linux wrapper for that the way they did for wifi then that's the end of my xp laptop.
    and i hope it happens soon, because i'm growing tired of running malware bytes on it every time i want to install or update something!
      • 31291
      well well well.
      this shit's worse than expected!!
      http://localghost.org/posts/a-traffi...-of-windows-10
      • Agent24
        I see dead caps
        • Oct 2007
        • 5095
        • New Zealand
        #183
        Originally posted by stj
        well well well.
        Anyone want to install Win 10 and do some independent verification of his claims? I wouldn't be surprised if it's true, but on the other hand, their questionable source is a good point.
        -David VanHorn
          • 31291
          well the source gives the destinations for the data,
          so it probably wouldnt be hard for anybody with a win10 setup to just search the drive for plaintext of the url's - it's a start.
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            #185
            Someone needs to patch a hosts file together just for Win10.
            http://arstechnica.com/information-t...-to-microsoft/
            Follow the white rabbit.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              No, we must just wise up the world to not use this intrusive coding disaster.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
                • 31291
                hosts file wont work, neither will any other software running on the o.s. because the o.s. is running under it at a higher level.
                you need a router that supports firewall / blacklists such as openWRT.
                  • 31291
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    And don't use Windows if you haven't got to.
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      #190
                      Steve Gibson ran a Win10 podcast in SecurityNow last week, worth watching.
                      It's episode 519 and the Win10 talk starts at 1:02:00 if you want to skip forward to it.
                      https://twit.tv/shows/security-now/e...utostart=false
                      https://www.grc.com/securitynow.htm
                        • 31291
                        Re: Win7 updates for upgrading to Win10
                        i wonder if it's creating hidden stuff.
                        i dont know about 7, but on xp and 98' you could create invisible folders & files simply by starting the filename with a % or $ or something.
                        the only way to see them was by booting Linux.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #192
                          Its $ and it works on Win7 and 8.
                          Select "show hidden files folder or drives" reveals it. No need for Linux.
                            • 31291
                            then $ is NOT it, because what i'm talking about was hidden even from dos.
                            it was REALLY hidden.
                            and one of the things it was used for was to create a cache of all pages visited by IE
                            i discovered this years ago after wondering where over 300meg of my HD space had gone!
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              #194
                              The standard dir command won't show hidden files, folders or drives if they are set to hidden.
                              Sounds like the index.dat file you are referring to.
                                • 31291
                                no, it was hundreds upon hundreds of html files in a cache folder with a % or something on the front.
                                totally invisible without Linux.
                                it was NOT using the usual "hidden" or "system" flags.
                                  • 31291
                                  it really is too bad that "fuckmicrosoft.com" is no more, because it had a list of all this stuff!
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    #197
                                    %appdata% is revealed when system files are set to show.
                                    • goontron
                                      5000!
                                      • Dec 2011
                                      • 4108
                                      • US
                                      #198
                                      Here is a list of some "phone home" domains from a new Windows 10 system:
                                      vortex.data.microsoft.com
                                      vortex-win.data.microsoft.com
                                      telecommand.telemetry.microsoft.com
                                      telecommand.telemetry.microsoft.com.nsatc.net
                                      oca.telemetry.microsoft.com
                                      oca.telemetry.microsoft.com.nsatc.net
                                      sqm.telemetry.microsoft.com
                                      sqm.telemetry.microsoft.com.nsatc.net
                                      watson.telemetry.microsoft.com
                                      watson.telemetry.microsoft.com.nsatc.net
                                      redir.metaservices.microsoft.com
                                      choice.microsoft.com
                                      choice.microsoft.com.nsatc.net
                                      df.telemetry.microsoft.com
                                      reports.wes.df.telemetry.microsoft.com
                                      services.wes.df.telemetry.microsoft.com
                                      sqm.df.telemetry.microsoft.com
                                      watson.ppe.telemetry.microsoft.com
                                      telemetry.appex.bing.net
                                      telemetry.urs.microsoft.com
                                      telemetry.appex.bing.net:443
                                      settings-sandbox.data.microsoft.com
                                      vortex-sandbox.data.microsoft.com
                                      survey.watson.microsoft.com
                                      watson.live.com
                                      statsfe2.ws.microsoft.com
                                      corpext.msitadfs.glbdns2.microsoft.com
                                      compatexchange.cloudapp.net
                                      cs1.wpc.v0cdn.net
                                      a-0001.a-msedge.net
                                      statsfe2.update.microsoft.com.akadns.net
                                      sls.update.microsoft.com.akadns.net
                                      diagnostics.support.microsoft.com
                                      corp.sts.microsoft.com
                                      statsfe1.ws.microsoft.com
                                      pre.footprintpredict.com
                                      i1.services.social.microsoft.com
                                      i1.services.social.microsoft.com.nsatc.net
                                      feedback.windows.com
                                      feedback.microsoft-hohm.com
                                      feedback.search.microsoft.com
                                      rad.msn.com
                                      preview.msn.com
                                      ad.doubleclick.net
                                      ads.msn.com
                                      ads1.msads.net
                                      ads1.msn.com
                                      a.ads1.msn.com
                                      a.ads2.msn.com
                                      adnexus.net
                                      adnxs.com
                                      aidps.atdmt.com
                                      apps.skype.com
                                      az361816.vo.msecnd.net
                                      az512334.vo.msecnd.net
                                      a.rad.msn.com
                                      a.ads2.msads.net
                                      ac3.msn.com
                                      aka-cdn-ns.adtech.de
                                      b.rad.msn.com
                                      b.ads2.msads.net
                                      b.ads1.msn.com
                                      bs.serving-sys.com
                                      c.msn.com
                                      cdn.atdmt.com
                                      cds26.ams9.msecn.net
                                      c.atdmt.com
                                      db3aqu.atdmt.com
                                      ec.atdmt.com
                                      flex.msn.com
                                      g.msn.com
                                      h2.msn.com
                                      h1.msn.com
                                      live.rads.msn.com
                                      msntest.serving-sys.com
                                      m.adnxs.com
                                      m.hotmail.com
                                      preview.msn.com
                                      pricelist.skype.com
                                      rad.msn.com
                                      rad.live.com
                                      secure.flashtalking.com
                                      static.2mdn.net
                                      s.gateway.messenger.live.com
                                      secure.adnxs.com
                                      sO.2mdn.net
                                      ui.skype.com
                                      www.msftncsi.com
                                      msftncsi.com
                                      view.atdmt.com
                                      • kaboom
                                        "Oh, Grouchy!"
                                        • Jan 2011
                                        • 2507
                                        Keep those P3-class systems for filtering! I know from setting up a certain PITA system that "certain" entries in the hosts file are *ignored.*
                                        When does the M$ arrogance end???
                                        :FDISK:
                                        "pokemon go... to hell!"
                                        EOL it...
                                        All style and no substance.
                                        guilty,guilty,guilty,guilty!
                                        guilty of being cheap-made!
                                          • 31291
                                          they really are pissing people off now!
                                          http://askubuntu.com/questions/65501...ir-doesnt-help
