New build.
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    New build.
    Got ahold of an old skulltrail board still in the box with two QX9775 processors. Intel D5400XS motherboard. The processors are supposed to pull 150 watts each. I plan on running two opticals and four harddrives. One video and one audio card. I don't plan on using a huge video card. I have a Sigma power supply that's 600 watts I recapped with all nichicons. Do you think it would be good enough or should I go and find 1000 watts or maybe a 1300 watt. I'm planning on water cooling the processors as well. The case will probably have about 6 fans in it. What's recommended?
    sigpicThe Sky Is Falling
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: New build.
    dont waste your time and effort water cooling that. this board isn't overclocking friendly....good dynatron copper sinks + air flow is all you need. @ 150w per CPU with all the extras, a 600w PSU isn't going to cut it there. 800w or higher.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Compgeke
      • Feb 2014
      • 524
      Re: New build.
      You'll need an 800+ for sure, especially for a video card.
      Honestly though, if it were me I'd throw the Skulltrail setup on ebay for $300-$350 then go with an X58 board and 6-core Xeon such as an X5670. Together can be had for under $200 and it's faster single core and almost just as fast multicore while only being a 95W chip.
      Example: $70 HP Z400 board (it's plain ATX) http://www.ebay.com/itm/381267231831 + $90 Xeon X5670 http://www.ebay.com/itm/331594852564
      • c_hegge
        • Sep 2009
        • 5219
        Re: New build.
        600W should be enough for his setup IMO. He said he doesn't plan to use a huge graphics card. The two CPUs may pull 300W, but I can't see the rest of the system using more than the other 300W.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Re: New build.
          Originally posted by c_hegge
          ...but I can't see the rest of the system using more than the other 300W.
          it will easily if all the RAM slots are filled. FB memory is a power hog.
          Team : 49813
          Join in!!
          Team Stats
            • 31154
            Re: New build.
            why not use more than one psu?
            i used to build server towers with one psu for the boards and another for all the drives when a big psu was 350w
            • rhomanski
              nowhere man
              • 5157
              • U S of A
              Re: New build.
              I guess I'll go with this one. http://www.newegg.com/Product/Produc...82E16817371060 . I was just wondering if I could get away with a smaller one because I have a bad habit of going too big and then going home.
              Motherboard's on it's way TC. The new in box price from Amazon is $2,500, so that's what I insured it for.
              • c_hegge
                • Sep 2009
                • 5219
                Re: New build.
                That's a nice PSU. It's even made by Delta.
                • rhomanski
                  nowhere man
                  • 5157
                  • U S of A
                  Re: New build.
                  Yeah, I guess I should go big because I don't know what the future will hold for this one. I may add more and more to it over time. I put a 1000 watt in the last one and this one has two processors not just one. I'll hang onto the 600 to use in the old system, it has a 600 in it now but it will need recapping eventually. I'll just swap them out.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    Re: New build.
                    you realize that PSU has only one 8-pin CPU power connector, and that motherboard has two? (one for each processor)
                    The benchmarks of these Core-series can't compete with haswell, or even sandy bridge, requiring a much lower PSU and has greater capability
                    how much did you pay for it?
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Re: New build.
                      Wrong. That PSU does have two CPU connectors. One is 8 pin only, the other is 4+4 pin. see http://www.jonnyguru.com/modules.php...Story&reid=287
                      you paid $2500 for this motherboard & CPU's? Are you insane? The benchmarks of these Core-series can't compete with haswell, or even sandy bridge, requiring a much lower PSU and has greater capability
                      A pair of X9775s gets a passmark score of 8355 - http://www.cpubenchmark.net/cpu.php?...682&cpuCount=2. That's actually faster than a Core i5 4690 (which gets 7612). But yes, you are right about the power consumption, and a core i7 4790K would be faster again and cheaper.
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        Re: New build.
                        you could of gotten a i7 LGA 2011-v3 3.33ghz 6-core and an Asus SLI board for much cheaper, with a passmark score of about 13k. Probably $500-600 total
                        • rhomanski
                          nowhere man
                          • 5157
                          • U S of A
                          Re: New build.
                          I got them cheaper than that actually, but mostly I got them for their rarity and novelty. I already have a six core. I was intrigued by the hybrid server/workstation aspect. It is a hobby you know? I've got 4 cyl., 6 cyl., and v-8 cars, I enjoy them all. This board was the first to do SLI and crossfire. I plan on filling all the memory. Wonder if I should go bigger? Hmm.
