Creative Audigy 2 ZS
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    My sounds been crackling in all 5 channels for a while now. It only does it when the house is warm. It gets worse as the temperature goes up. I first thought it was a transistor in my 5.1 speaker system but it's quiet when the computers not running. So I assume it's the sound card. I bought it used in 2006 off of e-bay. It's worked fine with my old system until now. Bad caps? Have you heard of this problem? What can you recommend for an Asus P5Q-E with windows 7? Thanks.
    sigpicThe Sky Is Falling
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Creative Audigy 2 ZS
    I have exactly the same card and have experienced crackling occasionally. Recently i deiced I'd had enough and gave my computer a bit of a clean.
    i found residue on my sound card around a cap. I could not determine if it was the cap that had leaked or something has got spilled on my PC. I replaced the cap and I've had no crackling since.
    I'll dig out the photo i took.
    The Asus Xonar DG is a good quality reasonably priced sound card available in PCI and PCI-E.
      • 31298
      pull the card out, clean the contacts and put it back.
      and pull the jacks out, and clean the sockets with ipa on a cotton-bud.
      the socket contacts tarnish.
        • 31298
        shit design, putting caps between regulators to get cooked.
        if i owned one of those, i would replace those 22uf caps with tantalums.
        • rhomanski
          nowhere man
          • 5157
          • U S of A
          Thanks guys, I'll try that first. I wonder if the Asus will work with such an old motherboard?
          • diif
            • Feb 2014
            • 6978
            • England
            I can't see a reason why it wouldn't.
            • rhomanski
              nowhere man
              • 5157
              • U S of A
              Cool. That's great. I'll keep it in mind if the other stuff doesn't help. Don't know when I'll get to it though. I've been so busy lately. So many broken things around here.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Temperature dependent sure sounds capacitor related...
                Did you see this thread?
                https://www.badcaps.net/forum/showthread.php?t=3543
                • rhomanski
                  nowhere man
                  • 5157
                  • U S of A
                  Interesting, there's a lot in there. Mine doesn't pop when it's around 70 in the house. Pops a little at 75. Pops so much you can hardly hear anything when it gets up to 80 in here. Nothing was changed when it started, so I would blame hardware and not software.
                  • Bungz
                    • May 2013
                    • 133
                    I will chime in with Asus DG's are superb cards for peanuts.
                      • 31298
                      i doubt it's caps related.
                      caps actually work a bit better when warm.
                      i would strip the machine down, clean out all the dust and rebuild it.
                      i had a 24/7 tower case that used to get unstable after 4-6months if i didnt do that every 3 months.
                      it got a lot better after i fitted a bank of fans to create positive air pressure and put filters on the fans btw.
                      • rhomanski
                        nowhere man
                        • 5157
                        • U S of A
                        update:
                        I cleaned everything and no change. It all looks good so I would blame caps or solder. I put a Soundblaster Zrx in my new build so I ordered a Soundblaster Z for this old system. Works great with windows 7. I never could get the Audigy 2 Zs to work right with 7. I threw away the microphone that came with it. It sounds great and even in a hot house no pops. I can enjoy my music again. Thanks for the advise everybody.
                        P.S. Does anybody need an Audigy 2 ZS, slightly used, only driven to church on Sundays?
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          I had this problem too.
                          Did you have the front panel option? If so, turn down the front pane's mic knob... as that was the issue in my case (same card).
                          sigpic
                          (Insert witty quote here)
                          • rhomanski
                            nowhere man
                            • 5157
                            • U S of A
                            No RD, nothing was plugged into the card except the sound system in the back. Only volume was on the speaker control head. Before I upgraded to windows 7 it worked fine. When I finally got it to work again, the back left channel would not work. Never could get it to work. I suspect it's the software but maybe another bad cap? Eventually last summer it started crackling and just kept getting worse and was definitely temperature related. The new card even sounds clearer, I can hear a lot more subtle sounds in the music or even just the noises in games.
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Strange, I am not having issues with mine under 7x32 (I am also using Daniel K's drivers, FWIW).
                              sigpic
                              • rhomanski
                                nowhere man
                                • 5157
                                • U S of A
                                I downloaded Creative's software from their website. I could have gotten the wrong one I suppose. It is an old card though, 2003 I think. It has a SNR of 97 db if my memory serves. The new card has 116db SNR.
                                • ChaosLegionnaire
                                  by ChaosLegionnaire
                                  09-13-2022, 09:02 AM
                                • sir_anthony
                                  Samsung UE55D6200 Crackling Sound
                                  by sir_anthony
                                  Hello, TV has a cracking sound from the speakers, sound from the headphone jack is ok.
                                  with new speakers the sound is just as bad.
                                  UE55D6200
                                  BN44-00457A Power Board
                                  BN41-01587E Mainboard
                                  What exactly can I check, what could be the cause?
                                  How do I repair the error?
                                  I can't find a circuit diagram on the internet
                                  thanks greetings from austria
                                  08-08-2024, 08:16 AM
                                • i_am_patch
                                  Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                                  by i_am_patch
                                  Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                                  04-30-2024, 08:20 PM
                                • LEECH666
                                  Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                  by LEECH666
                                  Good day ladies and gentleman!
                                  I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                  This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                  I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                  01-19-2024, 05:46 PM
                                • Woxx
                                  Nintendo switch - clicking/crackling sound when pwr on
                                  by Woxx
                                  Hey there, maybe someone can shine some light here.
                                  I have a Nintendo Switch that doesn't power on. When I press and hold the power button I hear a crackling, fast ticking electric-like sound. Does anyone have a idea of what it could be?
                                  I have disconnected everything that I can. Done some measurements, reading 17,2 Ohm as lowest on the CPU caps.
                                  I would highly appreciate your thoughts.
                                  Br
                                  Elias
                                  02-13-2024, 02:01 PM
