BIOS for HIS GeForce2 MX400
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    One of these I've acquired, looks fine cosmetically, but doesn't work with two different motherboards
    I suspect its BIOS has been corrupted
    Can anyone provide a BIOS file for HIS GeForce2 MX400 64MB AGP, or any comparable graphics card ?
    It's an SDRAM card, judging by its HY57V281620HCT-H memory chips
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: BIOS for HIS GeForce2 MX400
    Does anyone have this card, or similar, and could make a copy of its BIOS for me ?
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      I may have found what I need here ...
      http://www.nodevice.ru/searchres1_p1...4mb+winxp.html
      ... but can't navigate the hoops necessary to jump, in order to download
      Could a Russian speaking member help me out please, and download the three 0.03 Mb BIOS files (TV-out not required)
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        I dont' see one for HIS
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          Nothing special about the card - I suspect the first file there might do the trick for me
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            Found some files to try - watch this space
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              I might be out of luck with this
              Its BIOS chip is SST 27SF010
              NVFLASH tells me Nvidia card not detected
              Uniflash doesn't seem to support 27SF010
              And it's soldered direct, not socketed - so no easy options
                • 30997
                http://www.flashrom.org/Flashrom
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  Originally posted by stj
                  Thanks for the suggestion, but SST 27SF010 isn't shown as supported
                  Nevertheless tried "flashrom -p gfxnvidia" after installing Flashrom in Ubuntu 12.02
                  Got "Error: No supported PCI device found"
                  Seems like the only way would be desolder the SST chip, and sub in a preprogrammed 39SF010 or 39SF512
                    • 30997
                    i think the 27sf series isnt really flash.
                    the prefix makes me think it's an eeprom.
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      That's why I had a sinking feeling, when I first peeled the BIOS label off
                      The chip does have MTP on it, which I believe is Many-Time Programmable - as you've said, EEPROM
                      Chances are the previous owner tried to update its firmware - and NVFLASH erased the chip, then couldn't reprogram it
                        • 30997
                        probably,
                        eeproms like that are usually bulk-erase and program.
                        not sector based like flash.
                        maybe it needs a VPP higher than 5v
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          If it's EEPROM there is a good chance it requires a 12v Vpp, indeed.
                          A working TV? How boring!
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
                          • Bloodhoundje
                            HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                            by Bloodhoundje
                            I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                            I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                            After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                            I have desoldered the bios chip (GigaDevice...
                            03-16-2024, 03:12 PM
