Windows 10 on a toughbook
    • 31283
    Re: Windows 10 on a toughbook
    i like win2k, the best thing is you can make the CD explode in a 52speed drive. (hub micro-cracks from bad manufacturing)
    i have "blown" 3 so far!!
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Originally posted by canadaboy25
      I still prefer Windows 2000....
      right? i still have a VM around here somewhere.
      tell me how!
      Follow the white rabbit.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        If there were an x64 bit version, I'd still love it too! The only 64 bit version was for the Itanium processor.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • RJARRRPCGP
          • Jul 2004
          • 6304
          6gig!
          linux runs with only 1!!!
          Soo QFT!
          I wouldn't be surprised if even Debian Jessie still uses less RAM than Windows Vista, Windows 7 and Windows 8x!
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            Soo QFT!
            Except that its not quite true...........
            Team : 49813
            Join in!!
            Team Stats
              • 31283
              Originally posted by goontron
              tell me how!
              if you have an original 2k disk, just make a drive spin it as fast as possible - eventually you will her a loud bang and a clattering sound as the bits fly around inside the drive.
              a good way to spin one is to get a cd copier program to dump the disc to an iso file over and over again.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                What do you mean? LOL.
                Arc A770 16 GB
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  The bogus statement that windows can't run on 1gb of RAM and linux can. Neither OS will be spectacular on 1GB RAM, but its very do-able. I've put W7 SP1 on quite a few laptops with 1gb, runs fine. A good clean install, turn off all the un-needed crap, it idles around 300~400mb.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    This.
                    A modern mainstream distro of Linux will work on a PIII with 192MB RAM and a 20GB IDE HDD. It just won't be usable.
                    • canadaboy25
                      What is normal?
                      • May 2013
                      • 509
                      That's exactly what what I think. If there were a 64bit version that supported my hardware, I'd be golden!
                      My favorite part is the old boot up screen!
                      canadaboy25
                      -Sometimes the light at the end of a tunnel is an on-coming train
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Originally posted by mockingbird
                        That's its achille's heel. Though I'd imagine that the amount of XP enthusiasts who would actually need an SSD would be in the 10%. You said 'inbuilt', are you aware of 3rd party solutions for XP? I'm pretty sure this is something that has to be handled by the OS itself...
                        I ran XP on a Samsung 840 SSD a while ago for a period of about 6 months or so (and yes, it was insanely fast). I used the Samsung SSD Magician software to manually trim it once every couple of weeks. It only does Samsng SSDs, though. I think Intel may have a similar toolkit for their drives, but I don't know of anything that will trim all brands.
                        • mockingbird
                          • Dec 2008
                          • 5488
                          #32
                          What about garbage collection?
                          • c_hegge
                            • Sep 2009
                            • 5219
                            AFAIK, Garbage collection is done by the SSD itself, independently of the OS. It performs a similar function to TRIM, but when used without the TRIM command, it is slower and uses extra write cycles.
                            see http://www.thessdreview.com/daily-ne...an-ssd-primer/ for more info
                            • mockingbird
                              • Dec 2008
                              • 5488
                              #34
                              Thanks for the info. So manual TRIM... Kind of like how defrag was pretty essential back in the day.
                              Just to show XP64 is no slouch, here's IE Chalkboard Demo in Chromium 289994 (38.02125.0):
                              I'd like to see if newer systems with a fancy new OS can beat this. I'm only running a quad-core Xeon underclocked to 2.1GHZ.
                              Unfortunately, this is probably the last Chromium build that has full GPU support on XP. Later versions give a "GPU unable to boot error". This is a late August 2014 build, so it should be good for a few years.
                              • lti
                                • May 2011
                                • 2557
                                98.88 seconds on a Core i3-2330M, Windows 7 x64, and Firefox 35.0.1
                                • mockingbird
                                  • Dec 2008
                                  • 5488
                                  #36
                                  about:config, then set "layers.acceleration.force-enabled" to true.
                                  I also use Firefox primarily, but 36 Beta broke Flash, and I'm waiting for a fix.
