CPU downgrade?
  • ivtec
    • Dec 2008
    • 1967
    CPU downgrade?
    Hi guys;i have here an old E machines T3958 Intel (R) Celeron CPU 2.93GHZ 1 mem ram, the CPU just burned due to the Bestec Crappy Power supply,
    now i changed the power supp with an old HP that i have in my scrap, also i have an Intel CPU 2.00Ghz in my scrap,
    My question can i use this Intel 2.00GHZ processor in place of the 2.93GHZ and if good what will be the cons of the change in performance wise?
    Note: i have on order 2gb Mem on the way.
    • 31086
    Re: CPU downgrade?
    if they use the same socket then try it.
    check the specs on both here:
    http://www.cpu-world.com/index.html
    btw, it's unlikely that the cpu got trashed unless the motherboard got hit first.
    the cpu isnt powered by the psu, it has it's own regulator circuits around the socket.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Re: CPU downgrade?
      As long as it's the same socket and the chipset supports it. I doubt that it will fix your problem though because if the CPU is dead your mobo probably is too.
        • 31086
        Re: CPU downgrade?
        E-machines are known to self destruct because of the psu btw,
        the first thing to go is usually the usb chip.
        • ivtec
          • Dec 2008
          • 1967
          Re: CPU downgrade?
          Wow That was fast thanks .That's why i have this forum as my favorite of all,with that said.
          I had the Pc on my bench ready to swap the CPU just was waiting for your reply and went a head and swapped the Intel 2.93GHZ for Intel 2.00 GHz and you know what the PC is alive again but a little slower, hope when i get the 2 GHz of mem ram i will get better performance. thanks
            • 31086
            Re: CPU downgrade?
            test the usb function.
            and post us a foto from inside the psu so we can see all those burst caps - specially the one on the 5v standby supply near the fan!!!
            • R_J
              • Jun 2012
              • 9555
              Re: CPU downgrade?
              Looks like its a socket 478, if it is there are lots on ebay for cheap. for example Intel SL7Q9 Celeron D 340 Processor 2.93GHz/533/256 Socket 478 $14.95
              • c_hegge
                • Sep 2009
                • 5219
                Re: CPU downgrade?
                The Celeron D is a Prescott core. If it's not an Intel 865 Chipset, it won't work. I would have suggested upgrading to something like a P4 2.66 or 3.06GHz.
                • R_J
                  • Jun 2012
                  • 9555
                  Re: CPU downgrade?
                  I was just suggesting this based on the limited information provided by the original poster
                  That there are cheap processors available for this board and he should not have to live with the 2ghz one he has.
                  So DON'T buy THAT cpu. It was only an EXAMPLE
                  • ivtec
                    • Dec 2008
                    • 1967
                    Re: CPU downgrade?
                    Thanks guys; for now it's working like a champ,i lowered the Swappines from 60 to 10,(i don't know if i mentioned that this is Xubuntu 14.04) and it's better and it will better for sure when i change the Mem Ram from 1Gb to 2Gb, besides i only use this old Emachines for the web,i have 4 more better machines for my video Streaming,thanks.
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Re: CPU downgrade?
                      you can get a 3.0 P4 really cheap now, around $2 shipped. Still a decent proc and fun to OC!
                      • xaxex
                        HP ZBook 17 Mobile Workstation (not G2) BIOS Downgrade - (Pre-Spectre & Pre-Meltdown)
                        by xaxex
                        Hi, can someone please help with BIOS downgrade?
                        I have recently figured that the meltdown and spectre patches are taking toll on CPU. I know about grc tool but that will only fix the Windows/OS patches. The hardware ones, which are included in BIOS, will still be limiting CPU.
                        Currently, the laptop has BIOS version 01.47 Rev.A. I want to downgrade to 01.40 Rev.A which is from January 2018. I am pretty confident that HP had not released patches then.
                        All the latest & previous BIOS versions of this laptop are available here:
                        http...
                        09-11-2021, 01:01 AM
                      • Pawel Borowski
                        Solving Razer Blade 14 (2022) RZ09-0427 from scrap.
                        by Pawel Borowski
                        Hi folks,
                        I want to solve a Razer Blade 14 (2022) RZ09-0427 with Ryzen 9 6900HX and RTX 3070Ti from scrap, and I need your help with the diagnosis.
                        I have checked (I hope) all the voltage rails and found no shorts to GND and B+ except for the CPU VDDCR_SR rail (see the photo), which is near zero ohms to GND.
                        When plugged to PS, the laptop charges the battery, and after pressing start, it supplies voltage to all voltage rails except for CPU VDDCR_SR one and, of course, the dGPU, nothing more.
                        I have no experience in this type of repair, so please let me know if the low resistance...
                        05-05-2025, 07:37 AM
                      • quic307
                        hp officejet pro 8022e firmware downgrade
                        by quic307
                        Hello techs,
                        I need some help with printer.
                        I have the hp officejet pro 8022e and I'm trying to refill with ink the cartridges...
                        I have knowledge for laptop only and the printers arent my support.
                        Does anyone downgrade the firmware?
                        The firmware is like EC - BIOS reprogramming? or I can use other methods ...
                        Any support is perfect to me.
                        I was trying something like this.
                        Thank you in advance!!!
                        10-20-2023, 11:04 AM
                      • mitchw
                        HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                        by mitchw
                        Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                        After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                        After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                        I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                        04-29-2025, 03:45 PM
                      • dqtech
                        iMac late 2012 A1418 CPU DOWNGRADE
                        by dqtech
                        is that possible to downgrade cpu from i5 3470 to i5 2300?
                        05-02-2023, 09:54 PM
