Dropped computer
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro -
Re: Dropped computer
Yup. The primary cap is an NCC SMQ, which is fine. It's a totally different story with the CapXon on the secondary. If it's a newish PSU, then they probably haven't failed yet, but bear in mind that they do have a very poor reputation.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
yea, if the caps fail in the psu i will most likely just recap it. I also believe ive solved this issue... I reseated the everything and then updated the bios and it seems to be working fine now.Comment
by nicktasiosI recently picked up a Quadra with a Apple Multiple Scan 17 Display. The Quadra was not working, it clearly had corrosion from leaking caps so I replaced them and luckily it chimed and worked properly.
The next problem to tackle was the screen. Sometimes it turns on and off multiple times before finally turning on, and then it sometimes turns purple. After waiting some time, without doing anything, it regains all colors. Another symptom is that it sometimes seems to momentarily blink.
Also, not sure if this is related, but sometimes, after experiencing these problems,...-
by gsmtechnohi,
if it can help, attached scan for
ACER ASPIRE 1 A114-31
MB : DA0Z8GMB8d0
https://ibb.co/0VmNtHp
https://ibb.co/MkrGYCG...-
02-24-2023, 05:49 AM -
by Urizentitle says it all
I've a Pixma mg2550s printer/scanner All In One
when I try to scan but there's no ink cartridge it gives an "error code 2,140,21"
scanning requires no ink so it's obvious this is a scam basically an artificial block they put in place for $ reasons
so how do I bypass this? is there a hack? maybe a fixed firmware
nb. got this new Pixma at a bargain price but I defo wont be buying another Canon product if there's no fix for this "feature" -
by Jembanggood day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
MacBookPro 2012 15” A1398.
No visual damage was found.
Mac was inside of suitcase and it was inside of a bag.
Mac boots up,I can hear the chime,but the screen is totally black,not even “light” black. Caps lock light doesn't work.
I tried SMC,PRAM reset, didn't work.
Reconnecting screen display by unplugging those two things didn't work. I used this video
Reconnecting battery didn't work.
I also tried SMC,PRAM reset while the battery was disconnected and Mac was getting... - Loading...
