Dropped computer
  • SteveNielsen
    Retired Tech
    • 2327
    Re: Dropped computer
    You can't remove a partition that doesn't exist, raw disk means there's no partition. I don't think that drive is any good but I'd test it using a different utility anyway.
    http://www.seagate.com/support/downloads/seatools/
    • blasterboomer
      • Dec 2013
      • 135
      • United Kingdom
      this is what i meant by raw. Im trying seatools now
      edit: it says ATA: scanning for supported drives. please wait... its been saying that for about 5 mins so far
      • blasterboomer
        • Dec 2013
        • 135
        • United Kingdom
        It failed short DST and the long test
        • SteveNielsen
          Retired Tech
          • 2327
          Tried another SATA cable?
          • blasterboomer
            • Dec 2013
            • 135
            • United Kingdom
            i will try another sata cable soon when i get one. (should be within the next few hours) but could a faulty sata cable cause these issues and even increase the current pending sectors because it had 0 the last time i used it
            • SteveNielsen
              Retired Tech
              • 2327
              Yes, it is possible a bad cable or intermittent connection could do that. You could swap the cables between the drives and test.
              I recently had a similar problem with a drive due to the SATA data cable not making good contact at the motherboard.
              • blasterboomer
                • Dec 2013
                • 135
                • United Kingdom
                #27
                ok I rebooted the computer and the drive is now showing as formatted as ntfs ad has folders on... although accessing these folders takes forever and the surface scan and short dst fail as before
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5013
                  • New Zealand
                  #28
                  Probably that one has had a head crash.
                  -David VanHorn
                  • blasterboomer
                    • Dec 2013
                    • 135
                    • United Kingdom
                    #29
                    could it fail and still have all the files on it and showing up in explorer?
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5013
                      • New Zealand
                      #30
                      The filenames are read from the MFT which does not require much effort... if the heads are damaged they may be able to read this small amount of data fast enough but be unable to read anything else very well.
                      -David VanHorn
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        Have you eliminated the SATA cable/connections as a possible problem?
                        I think trying to copy the files you'd like to save in its current condition is going to take a very long time and probably fail with error(s).
                        If you're not concerned with the info on the drive you could zero-fill the drive then test it again. Partition, format, test again. If it then passes tests start using it for non-critical storage and see how it does.
                        • blasterboomer
                          • Dec 2013
                          • 135
                          • United Kingdom
                          #32
                          OK... just put the hdd in another pc and its all fine in there full error scan shows 2 bacd blocks but zero filled and there now gone and smart says no reallocated or current pending... maybe an issue with my mobo? as it seems to only like the os drive
                          • blasterboomer
                            • Dec 2013
                            • 135
                            • United Kingdom
                            #33
                            if i plug a hard drive in each connector on my motherboard (6 hdds) the motherboard randomly disconnects some of them and sometimes they work is this a sign of a bad sata controller?
                            • blasterboomer
                              • Dec 2013
                              • 135
                              • United Kingdom
                              #34
                              This is the results on the same hdd on a different pc
                              Im gonna try plugging my os hdd into different ports to rule out faulty ports (all of the sata cables i used were brand new and all work on my os drive in the same port)
                              • blasterboomer
                                • Dec 2013
                                • 135
                                • United Kingdom
                                #35
                                The OS drive workks in all sata ports just some ports dont work when theres more sata drives plugged in
                                • SteveNielsen
                                  Retired Tech
                                  • 2327
                                  What are the PC specs and PSU specs?
                                    • 31157
                                    check the psu caps.
                                    • blasterboomer
                                      • Dec 2013
                                      • 135
                                      • United Kingdom
                                      #38
                                      swapped with another corsair 500w psu (1 week old) same issues afterwards
                                      the motherboard is an msi 760gm-p23 (FX) with an fx6300 and 8 gigs of ram (using onboard graphics)
                                      • blasterboomer
                                        • Dec 2013
                                        • 135
                                        • United Kingdom
                                        #39
                                        Just opened my psu and the caps are smq? are these crap caps because ive never heard of them?
                                        the secondary caps are crapxon and a cap with GF on it?
                                        • Sparkey55
                                          • Jan 2010
                                          • 1523
                                          This sounds very much like at least one stick of ram is bad. could have became damaged when dropped or came loose from socket. The give away is "...accessing these folders takes forever...". Try swapping the ram next.
