The Tale of Two Towers - TC's Supermicro Shenanigans
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Two towers bathed and ready for some goodness that involves a couple cheap score Supermicro workstation boards. One is a X7DWA-N, the other is an X8DTI-F.
    This thread is a double build log for the two...
    More later.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: The Tale of Two Towers - TC's Supermicro Shenanigans
    Gee, isn't everybody building workstations around here it seems*!
    Looking forward to the build pics...
    *I'm guilty as charged too, I'll be up to two supermicro builds and a tyan by the middle of next week
    sigpic
    (Insert witty quote here)
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      yep, even im at it! its just that time in the world where all us geeks instinctively upgrade.
      Follow the white rabbit.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        Ok, may have to add a third tower to this.....but for now, I'll just give the cliffs notes, as I'm still in the parts collecting stage and preparation.
        The reason for the possible 3rd case....pair of paxville's and 12gb RAM...
        I'll just give the cliff's notes on the case modding...this is mod 1, as this case was bought from a member here about 10 years ago, its a 90's chenming case back when everyone thought that if you didn't have 8 HDD's in your system that your system sucked....well that isn't needed today.... The cages didn't interfere with the motherboard, but they did get in the way...
        The trays in question that the cages latch into...
        Pop rivets drilled out:
        Trays removed... If I ever needed to replace the trays, I could simply pop rivet them back in. Nothing was permanently altered with this mod.
        ...and trays gone, and case washed.
        For a HDD, I'm probably doing a single SSD, as this system will be a workstation. All critical data will be stored on a server elsewhere on the network, so it will be mounted in a 5.25" bay holder with a fan.
        Ok, now for mod 2. I've had e-ATX boards in this case before, but this one didn't want to line up right, as the 8-pin ATX connecter was hitting the case, making the standoff's unalign to the board by about 1/16"
        This was a bit much for a dremel, this case is very thick gauge steel, it'd have eaten wheels like crazy, so I used my pneumatic angle grinder with a man size cutoff wheel in it.
        Section cut out.
        Test Fit:
        Connecting the PSU (A special thanks to Ratdude for this PSU)
        Motherboard fitment perfection!
        More to come later....
        Team : 49813
        Join in!!
        Team Stats
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          You're welcome... I had NO use for the PSU so I'm glad you have a use for it.
          I've cut that thick steel with a dremel, that much properly done would take one thick wheel at most. But an angle grinder works too.
          I have a near clone of one of those cases, but she's beat to hell and IMHO since mine has a fan vent behind the HDD caddy this mod wouldn't have worked nearly as well.
          sigpic
          • JuniperSprouts
            Solder Soldier
            • Aug 2010
            • 119
            That big black full tower looks great!
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              Today's setback...scored a pair of X5660 6-core Xeons....one was bad... Second bad Xeon I've ever seen in 20+ years in the field. Bummer. Ohh well, only about a week or so setback, I'm sure they'll warranty it.
              Team : 49813
              Join in!!
              Team Stats
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                the bad CPU was replaced for the X8 and I scored 32gb of FB memory for the X7 for 75 bucks shipped!! I put the 32gb in my office machine (same motherboard), and took its 16gb for use in this one. Still need to grab some DDR3....
                Team : 49813
                Join in!!
                Team Stats
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  give the 771 to larry so he can finally have a properly working problem free workstation :P
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    And what bug crawled up your ass this time?
                    sigpic
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      i'm just kidding
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16956
                        A strange box showed up from Germany today, containing a Supermicro X6DAI-G2 in new condition. After the currency conversion, the board cost me about $65 shipped....which was a MEGA steal!! They're near impossible to find, and to score one that cheap in new condition, yea!! Thanks Larry!! I tested it, it does work. I also scored 16gb of 2-rank 4gb sticks for it for $44 shipped (I LOVE how cheap FB/ECC/REG memory is these days). The 4gb DIMM size is 'unofficially' supported for this chipset, but I've seen lots of guys do it in their precision 470/670's (same intel 7525 chipset) with no issue. This chipset can only run 8 ranks of memory no matter what, how you populate it is up to you....but anything more than 8 ranks will not be seen.
                        I ordered some Dynatron copper heatsink/fans for these, as the Dell ones are typical proprietary sillyness. I gave RD my aluminum ones, as I don't think they'd be adequate with dual core processors.
                        Anyway, this project continues...
                        Shows 8 CPU's, thats 4 cores + HT.
                        More later.
                        Team : 49813
                        Join in!!
                        Team Stats
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          ^ You're welcome.
                          Also, what coolers? I don't recall receiving any... Unless you mean the X5DAL ones, which are completely different (old board-mount style, not the newer chassis-mount through-board style).
                          Glad its working for you, better than my fails lately (bad USB ports, IRQ conflict bull puckey, etc.).
                          sigpic
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16956
                            ^ You're welcome.
                            yup, those would be the ones. The chassis mount ones require a case new enough to support them/designed for that specific board....don't think any of this relic hardware qualifies....
                            Team : 49813
                            Join in!!
                            Team Stats
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Nope, the X6DAE/DA8 uses the chassis mount kind... IIRC your board in question does too?
                              sigpic
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16956
                                It can be used with either. The SM board mount backplates I have leftover from other builds fit it.
                                Team : 49813
                                Join in!!
                                Team Stats
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Well, they're brethin's now... FYI, they did have some copper in them too. One fad had a bad bearing but otherwise IMHO for that they were used with (gallatins), they're fine coolers.
                                  sigpic
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16956
                                    I never took them off the processors....the bases could have been copper. They were quite noisy....both could have used new fans, or for the adventurous, the fans disassembled and packed with grease.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      ^ the ball bearing was rattling...
                                      The center fins/base were copper... the outside ones were aluminum.
                                      sigpic
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16956
                                        The memory came today, sure enough, sees all 16gb....like I said, unofficial support for 4gb sticks.
                                        The 2gb sticks I have are just garbage modules....they gave me trouble in this board like they gave me fits in the precision 470. They're bound for the trash. No-name chips on those modules, I should have known better. The old precision 470 is probably fine....but I'm done fooling with it, and will pursue the SM build, far better platform.
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • Topcat
                                          Topcat's Supermicro X10DAI Build - Plus NVMe BIOS Mod Inside
                                          by Topcat
                                          Yes, I know I don't post this stuff much anymore....the only reason I'm posting this one is because of a NVMe adapter incompatibility; seems rather planned by Supermicro.....or I'm atleast a bit suspicious. It's plenty new enough to have a UEFI bios but a short 'happy list' of NVMe controllers that will work with this board, as if by some 'miracle', all Intel....so lets start at the beginning; we'll get back to this later.
                                          Of course the motherboard is as the thread title states; X10dai....but we'lre going to have some fun shoehorning this into a modern 'gamer case' that can actually...
                                          09-29-2024, 03:55 PM
                                        • nissimezra
                                          Supermicro C9X299-PG300F bios dump
                                          by nissimezra
                                          Device Desktop motherboard
                                          manufacture: Supermicro
                                          motherboard: C9X299-PG300F
                                          S/N: ZM187S026581
                                          Problem: Black screen.
                                          Description
                                          The customer reported a message: usb device over current status detected.
                                          I tried to download the bios from the manufacture, It has a bin file but didn't work. I'm not sure if the bin file design to be programmed directly to the chip or maybe I need to extract the body
                                          I programmed this bin file but didn't work.
                                          https://www.supermicro.com/en/suppor...99-PG300F/BIOS...
                                          02-09-2024, 08:57 AM
                                        • frans00000001
                                          Supermicro Server mainbaord x10dri-ln4+ schematic
                                          by frans00000001
                                          Good day
                                          I am looking for a mainboard schematic for a Supermicro Server mainbaord x10dri-ln4+ as the track broke off on the BIOS chip and I want to repair to use the server again. If possible can someone assist to get this schematic?
                                          08-06-2025, 05:36 AM
                                        • WatchItFool
                                          M12SWA-TF threadRipper pro SuperMicro schematic
                                          by WatchItFool
                                          M12SWA-TF AMD threadRipper pro MOBO by SuperMicro
                                          does superMicro ever have files?
                                          looking for the schematic, component list, and maybe a boardview
                                          08-04-2023, 01:06 AM
                                        • shlomim412
                                          Supermicro Server Power Distributor board
                                          by shlomim412
                                          Hello everyone
                                          working on a supermicro server PDB
                                          i attach a photo of how it looks
                                          it suddenly died and the symptom is when pressing power on it sends a brief dc voltage and imediatly shuts down.
                                          fan spins briefly and stops.
                                          the power supply connected to it is working tested for sure (tested on another good pdb)
                                          cannot find a short anywhere on the board, capacitors visually seem to be ok.
                                          standby voltage is present (5v) also vdd to the power ic chip is present (also 5v).
                                          any help would be apreciatted!
                                          thanks...
                                          02-27-2025, 04:01 PM
