Supermicro C9X299-PG300F bios dump
  • nissimezra
    • 178
    Device Desktop motherboard
    manufacture: Supermicro
    motherboard: C9X299-PG300F
    S/N: ZM187S026581
    Problem: Black screen.
    Description
    The customer reported a message: usb device over current status detected.
    I tried to download the bios from the manufacture, It has a bin file but didn't work. I'm not sure if the bin file design to be programmed directly to the chip or maybe I need to extract the body
    I programmed this bin file but didn't work.
    https://www.supermicro.com/en/suppor...99-PG300F/BIOS
    All power rails are present
  • hoaca388
    Badcaps
    • Jan 2022
    • 12346
    S/N: ZM187S026581
    Description
    You just need to use the *.bin file directly after extracting.
    • nissimezra
      • 178
      Many thanks
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • bondminer009
        Need Bios for Latitude 7650 (No Original / dump bios file)
        by bondminer009
        Good Evening,
        Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
        Thank You
        Salam,
        Three
        11-12-2024, 07:48 AM
      • joshAU
        BIOS file for N550JK (original dump attached)
        by joshAU
        Hi all.
        I'm looking for a BIOS file for an Asus N550JK.
        I have a Asus R552J, which I believe is identical to the Asus N550JK.
        I downloaded the latest BIOS (210) for the R552.
        It is named N550JKAS.210.
        The BIOS file is however only 6mb in size.
        I've read the chip with a CH341A programmer and verified the file.
        That file is actually 8mb in size.
        I'm wanting to remove the BIOS password from this unit.
        It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
        08-09-2022, 08:06 PM
      • adelage
        Merge ECS Z77-H2 bios cap file with original dump
        by adelage
        I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
        03-11-2025, 03:07 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
