Sound Blaster Issues
+ More Options
Posts
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hey guys I'm having a problem with my main pc. (less than a year old)
    Somehow the on-board audio on my Asus M5A99FX Pro R2.0 has blown out. There is always different tones of clunking (the speakers are fine) and it happens at the bios screen so Windows 8.1 is not the issue.
    I put in my old Creative Soundblaster Live SB0060 Card and installed the KX3550 driver which got the sound working when i am plugged into the black port of the card. It works fine but the KX-Mixer software doesn't work. I get the massage "Error initializing your audio card Please install drivers If you haven't rebooted after setup - please reboot now If KX Setup is currently in progress - ignore this message" I get this error everytime I boot or when I try to open the KX-Mixer software. Also my sound card has an expansion cable going to a 5.25 inch bay device. The speaker jack on that card just gives a continuous hum and nothing else works.
    Also I would like to know if there is a way to attach the front facing ports (mic and headphones) to the card for output because they are currently connected to the fried onboard controller.
    The green port on my card does nothing, only the black port works.
    So, in a nutshell, I would like to get the KX software working, get the front bay card working, get my front ports working, and finally get the other ports on my sound card working.
    My operating system is Windows 8.1 Pro 64bit which is pretty new for this sound card I know, but it's the only card I have.
    I hope someone out there has some experience with these old cards and can get me up and running or it may be a new mobo for me.
    Thanks!
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • Towncivilian
    • Jul 2014
    • 22
    • US
    Re: Sound Blaster Issues
    Try this driver instead: http://danielkawakami.blogspot.com/2...30-audigy.html
    ASUS P8Z77-V LK, i7-3790, 32GB DDR3-1600, GTX 750 Ti, 256GB 840 Pro & 2x1TB / 1x2TB, Creative SoundBlaster ZxR, FSP Aurum S 400W
    abit IP35 Pro, Q9300, 16GB DDR2-800, GTX 750 Ti, 128GB 840 Pro & 1TB WD Blue, Corsair CX430
    HP d530 CMT, P4 EE 3.2ghz (with modded BIOS for correct microcode), 4GB DDR-400, ATI 9600XT, X-Fi, 80GB Velociraptor, 500GB WD Blue, XP SP3, Sony SDT-9000 & Seagate CTD-8000 DAT drive for ripping audio DATs
    abit BX133-RAID (recapped + SMD caps installed in processor socket), PIII-S 1.4ghz Tualatin, 768MB PC133, FX5600, SoundBlaster AWE32, 40GB Deskstar, Windows 98SE
    Depeche Mode Live Wiki
    • canadaboy25
      What is normal?
      • May 2013
      • 509
      Do I have to uninstall the existing driver?
      canadaboy25
      • Towncivilian
        • Jul 2014
        • 22
        • US
        I'm not certain, but it probably wouldn't hurt.
        • canadaboy25
          What is normal?
          • May 2013
          • 509
          I downloaded it and tried to install it but it did not find any compatible devices?
          canadaboy25
          • Towncivilian
            • Jul 2014
            • 22
            • US
            My apologies. You can try this one instead: https://mega.co.nz/#!5wo0AKQC!LJPnOn...TDTwP5-4C9Eh40
            • canadaboy25
              What is normal?
              • May 2013
              • 509
              That driver is too saying that it was unable to locate a compatible device??
              canadaboy25
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                Card is faulty or Bios is not enabling it.
                My pc
                CPU : AMD PHENOM II x4 @ 3.5Ghz
                MB : ASUS M4A89TD PRO USB3
                RAM : Kingston ValueRAM 16gb DDR3
                PSU : Cooler Master 850W Silent Pro
                GPU : ATI Radeon HD 6850
                • Towncivilian
                  • Jul 2014
                  • 22
                  • US
                  I have some spare X-Fi XtremeMusic SB0460 cards kicking around, do you want one for the cost of shipping?
                  • canadaboy25
                    What is normal?
                    • May 2013
                    • 509
                    The card is not faulty because it is working with the drivers I have. It just isn't configured properly as stated in my first post.
                    canadaboy25
                    • canadaboy25
                      What is normal?
                      • May 2013
                      • 509
                      No thanks, If I cant get this to work then I'll just use it how it is.
                      canadaboy25
                      • canadaboy25
                        What is normal?
                        • May 2013
                        • 509
                        Anyone else?
                        canadaboy25
                        • Logistics
                          • Apr 2007
                          • 721
                          I don't recall Windows 8 being supported by the kxProject.
                          Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
                            • 30978
                            test the hardware with a linux livedisk.
                            • canadaboy25
                              What is normal?
                              • May 2013
                              • 509
                              I don't think it is but its just kinda working.
                              I got the audio output on the front dock connector working. I was a fool and only connected the ribbon cable to one row of pins instead of two.
                              My only problem now is none of the mic inputs work.
                              canadaboy25
                                • 30978
                                check the mixer settings, on linux atleast, they are muted with the gain at zero by default to reduce noise in the card/chip
                                • canadaboy25
                                  What is normal?
                                  • May 2013
                                  • 509
                                  As stated in my first post the mixing software isn't working.
                                  canadaboy25
                                    • 30978
                                    o.k.
                                    i think you are screwed unless you dump that joke pretending to be an operating system.
                                    unless you can find a 3rd party mixer software that will work.
                                    there used to be a few that came with motherboards like asus and epox but i doubt they will work on win8 either.
                                    i presume you disabled the onboard audio in the bios and made sure it's not being allocated an interupt?
                                      • 30978
                                      http://sourceforge.net/directory/aud...=audio%20mixer
                                        • 30978
                                        http://audioswit.ch/er
                                        • FZG
                                          EVGA Nu Audio Sound Card - Not Working
                                          by FZG
                                          I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                                          The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                                          I found...
                                          03-07-2025, 11:44 AM
                                        • ex250
                                          Kenwood SW-505D no sound issue and pops from time to time when it works
                                          by ex250
                                          Hello mates,
                                          I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                                          It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                                          12-29-2024, 03:27 PM
                                        • paparazzo79
                                          sound card dead after graphics card installation
                                          by paparazzo79
                                          Hi guys.I own Z690 F Strix board in one of my PCs....everything was working fine with integrated graphics card.I turned off power from it, installed graphics card from another PC, connected all the peripheral cables, optical sound cable of course when everything was switched off.Then I powered on the machine and integrated soundcard is dead.How did this manage to happen and if there is a way to diagnose and replace damaged component?
                                          The new pci-e soundcard costs here 80 euros which is half of money I spent on motherboard.
                                          I still can not believe that I am such a looser and don't know...
                                          07-23-2024, 12:22 PM
                                          GeForce RTX2080 Super Aero video gaming card issues help need
                                          by sam_sam_sam
                                          This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                                          Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                                          05-07-2023, 08:12 AM
                                        • jjne
                                          Yamaha RX V675 sound issues
                                          by jjne
                                          I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                                          From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                                          At first I thought it was either a speaker relay or the DSP, but I don't think...
                                          06-24-2025, 07:01 AM
