Sound Blaster Issues
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Re: Sound Blaster Issues
    Ok I got it working.
    The solution ended up being very simple. All I did was set the kxmixer software to compatibility mode for Windows 7 and then i was able to unmute the input.
    The simplest thinks are the biggest pains
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
    • FZG
      EVGA Nu Audio Sound Card - Not Working
      by FZG
      I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
      The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
      I found...
      03-07-2025, 11:44 AM
    • ex250
      Kenwood SW-505D no sound issue and pops from time to time when it works
      by ex250
      Hello mates,
      I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
      It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
      12-29-2024, 03:27 PM
    • paparazzo79
      sound card dead after graphics card installation
      by paparazzo79
      Hi guys.I own Z690 F Strix board in one of my PCs....everything was working fine with integrated graphics card.I turned off power from it, installed graphics card from another PC, connected all the peripheral cables, optical sound cable of course when everything was switched off.Then I powered on the machine and integrated soundcard is dead.How did this manage to happen and if there is a way to diagnose and replace damaged component?
      The new pci-e soundcard costs here 80 euros which is half of money I spent on motherboard.
      I still can not believe that I am such a looser and don't know...
      07-23-2024, 12:22 PM
      GeForce RTX2080 Super Aero video gaming card issues help need
      This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
      Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
      05-07-2023, 08:12 AM
    • jjne
      Yamaha RX V675 sound issues
      by jjne
      I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
      From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
      At first I thought it was either a speaker relay or the DSP, but I don't think...
      06-24-2025, 07:01 AM
