Back-UPS RS 800 Not charging
  • canadaboy25
    replied
    Re: Back-UPS RS 800 Not charging
    Originally posted by budm
    So at what test point that you are showing the 23VDC? How about the voltage on cap #3 which has 1.1V on it.
    I have retested the voltages on the capacitors that you pointed out in this picture. All of the voltage tests were done with the replacement fuse connected while the board is on and connected to AC power. The batteries are also connected. These are the voltages I got from testing the two terminals on each capacitor with my multimeter set on DC volts.
    1 - 22 vdc
    2 - 6 vdc
    3 - 3.8 vdc
    It may also be worthwhile to add that the battery drops by 0.4 volts and starts dropping a considerably large amount faster if I disconnect the jumpers that are holding the fuse. The voltage also goes up about 0.4 volts and the speed of voltage drop also slows after I reconnect the fuse.
    replied
  • canadaboy25
    replied
    Originally posted by stj
    you could have just soldered in the correct fuseholder.
    Yeah I know that but I live by a small town and I was searching to just find the correct rating. This is just for testing.
    replied
  • canadaboy25
    replied
    I got a fuse and soldered two wires to where the fuse came from and attached the fuse to the wires with cables so I could replace it if it blew.
    There was no change in performance even with the new fuse. The fuse did not blow and you can see where the voltage is in the picture and it is slowly dropping.
    replied
    You can use 2A 250V fuse in other from factor to test out the function first, this style of fuse can be found at Mouser or Digikey.
  • Agent24
    replied
    Originally posted by canadaboy25
    Yes I am in the process of getting my hands on an ESR meter so that is why I was wondering if that would be a fair enough test.
    Going for the capacitance test first is more suited to non-polarized capacitors.
    ESR measurement is a better test for electrolytics most of the time. But some can fail with reduced capacitance while the ESR stays OK! Also you can get excess leakage current problems too...
  • canadaboy25
    replied
    That is 2A 250V rating fuse. I am not sure yet as to where the charger circuit is, some of them use the SMPS for charging circuit, some of them use one of the winding on the inverter transformer (the transformer that is used for converting the switching 24VDC to 120VAC). I would try another fuse to see what happen, normally we would have used Ohm meter to check the resistance of each leg of the fuse (since we do not know which end of the fuse is the feeding side) to circuit ground, but we do not even know at this point which ground point is.
    So why is this fuse in such an odd formation? I haven't some across many fuses like this before.
    Would I be able to replace it with a "beaver tooth" fuse or one of those common cylindrical fuses to test the circuit?
  • canadaboy25
    replied
    Originally posted by Agent24
    Yes, but only IF the capacitance has dropped. The thing with electrolytic caapacitors is that most of the time they fail due to high ESR, so you really need an ESR meter to do a proper test.
  • Agent24
    replied
    Would I be able to find the bad one if I just took them all off and checked the capacitance?
    replied
  • canadaboy25
    replied
    Here is a picture of the fuse.
    The rest was about as clar as mud to me
    Both fuses are connected to the + battery terminal and from what I see they are connected to the 2 blue capacitors beside them. It looks loke the trace goes under the big transformer but I can't see where it goes. If it is nesicary I can take the transformer off and see where the traces go.
    replied
    It can be that the fuse may have blown due to in rush current. What is the value of that fuse?
    BTW, that yellow transformer is actually an inductor, L4.
    Those two green fuses, one end is connected to the + of the batteries, the other end of the fuses should be connected to charging circuit, you will have to trace that connection out, it should be connected to the Cathode of the blocking (or rectifier diode of the charging circuit) diode of the charging circuit.
  • canadaboy25
    replied
    I believe that fuse is for powering the SMPS for that small yellow transformer (not 100% sure), the secondary side winding of that transformer is connected to those two diode and that #3 filter cap. So there may shorted circuit in that area.
    Would that mean that the transformer is shorted?
    replied
  • canadaboy25
    replied
    Here are the voltages of the three caps with the board running and one lead on each cap terminal.
    1 - 23 vdc
    2 - 5.8 vdc
    3 - 1.1 vdc
    The green beaver tooth fuses are also good. The round brown f3 was blown. I removed it from the board to be certan.
    I am very sorry about the pics. Both of my good camera's were slightly knocked off a table. I hope these are better. If you need a picture of a very certain trace or something I will try my best.
    And why were the ends of 2 doides to the right of the green fuses circled?
    And the battey pack is 2 SLA's in series but they had shorted cells so now I just have some junker batteries with alligator clips on them
    replied
    Can you please get better focus pictures, I also need the pictures of the bottom side of the board. Check the red fuse and voltages on those caps.
    BTW, does it use two 12V batteries? From the spec it looks like just one 12V battery. And those two 30A green fuses are good, right?
  • canadaboy25
    replied
    chances are you would damage them during removal.
    i wouldnt use them again anyway.
    I removed 2 and they tested fine and I re-soldered them without a problem. The board is still working the way it was (useless).
    replied
  • canadaboy25
    replied
    Help is apreciated
  • carrzkiss
    Cyberpower cps1500avr not charging batteries
    by carrzkiss
    Hello, all.
    Cyberpower Battery Backup Unit.
    I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
    When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
    In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
    Checking the voltage, it was down to 22v.
    I quickly removed everything...
    06-15-2024, 02:10 PM
  • Thomasraud
    Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
    by Thomasraud
    i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
    QUOTED
    -It works on charger (without battery connected-only charger)
    -It works on battery (without charger connected-only battery)
    -& it also works when plugged in battery & charger, but it's not charging the battery
    //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
    and..
    QUOTE
    The IC cannot maintain the input current level
    06-28-2022, 06:47 PM
  • Scoff
    HP Probook 470 G4 - Power and Charging Problem
    by Scoff
    Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
    Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
    07-03-2023, 09:28 AM
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
  • Petr0x
    Bosch 12V and 18V chargers modification
    by Petr0x
    Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
    You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
    Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
    05-24-2024, 01:00 PM
