About Ground Loops & Oscillations - Stability
  • Logistics
    • Apr 2007
    • 721
    I'm defenitely no pro, but I've done alot of research when it comes to opamps, whether it be audio, video or just some other funky IC of special usage. One thing which has always been important in many application briefs and datasheets is the need to eliminate ground loops. There are tons of articles on grounding techniques. Ground loops are known to cause oscillations in IC's and noise problems, usually from one subsection of a PCB being forced to find another path to ground that it wasn't meant to use. This is known to cause audible distortion in audio IC's and visible distortion in video IC's. It seems reasonable to conclude that this can also cause instability issues.
    I'd like to see someone try to improve their overclocking results by eliminating ground loops in a PC. PC's are a gigantic mess of ground loops. You have earth ground coming into the PSU, being connected to the PSU's PCB and also usually tied to it's chassis. Naturally, you pass ground from the PSU's PCB to the motherboards PCB, but then you also have the chassis of the PSU being tied to the case. The case is tied to the motherboard and all it's add-on cards because they attach to the case. This can only be potential for something bad. This doesn't even take into account ground trying to pass out of or into all attaching cables, sound, video, etc., which throws even more fat on the fire; plus your add-on cards having potential for grounding through eachother. And since you obviously aren't going to lift ground from the spaghetti coming out of your PSU, it should be removed from the case.
    Any thoughts?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: About Ground Loops & Oscillations - Stability
    If you remove grounding from the case and the hot wire comes loose and touches it you will be dead when you touch your computer, maybe not all that fun?
    • Logistics
      • Apr 2007
      • 721
      Since the mains run inside the PSU chassis, as long as the PSU chassis is grounded internally, that eliminates that problem.
      • mutant
        • Mar 2006
        • 123
        I'm no pro either but I think you can get the results your looking for if you remove the case entirely. Like when you benchtest a new system to make sure everything works.
        Maybe get one of those clear acrylic cases.
        But would it really make any difference? What about EMI?
        Cooling might be better.
        • Logistics
          • Apr 2007
          • 721
          What about EMI?
          That's why I wanted to leave it in a normal case. You could breadboard everything, but it wouldn't have the case acting as a sort of RF trap. This is why it would actually be ideal to still have the case grounded, but not to anything except for the PSU chassis, so that as much of the mess in the air as possible hits the case and is passed to earth rather than ever trying to find it's way through the cards, drives or motherboard. I need to build a faraday cage for my PC.
          Mmm... how does cooling solve oscillations caused by ground loops?
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Isn't the negative DC plane in a PSU grounded though the PCB screws?
            • mutant
              • Mar 2006
              • 123
              I should have specified more clearly. What I meant was for the overclocking. Usually better cooling for most components.
              I like the faraday cage idea.
              I havent read anything about anyone trying what you suggest but I bet the military has hardware thats designed like that.
              • 999999999
                • Sep 2006
                • 774
                The answer is no. Do not think of a computer like you'd think of a power amp with vast differences in low level analog signal input versus high current ground returns from the load.
                There are many many different hypothetical ground loops in a PC and it is not feasible to try to eliminate them, and no scientific backing in it being useful to do so for overclocking purposes.
                On the other hand, if you wanted to apply a PC scenario to analog audio, it suggests the cleaner analog audio output is obtained by having a slight impedance from the ground plane to the audio card (instead of an integrated audio solution) and some LC filtration on that audio card.
                • Super Nade
                  • Jun 2006
                  • 294
                  A motherboard should not have those problems or it should be minimal at best if signals traces are routed well and if there is optimal use of ground planes. These are 6-8 layer boards, so ...
                  Q6700 @ 3.6 GHz
                  Zippy GSM-6600P
                  Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
                  Abit IP35Pro
                  ATi HD4870
                  • mkdj
                    Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                    by mkdj
                    Dear all,
                    I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                    I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                    Both N-Channel Mosfets: nothing odd
                    P-Channel MOSFET number 1:
                    source - drain : 117 kOhm
                    source - gate: 96 Ohm
                    gate - drain: 117 kOhm
                    P-Channel MOSFET...
                    08-20-2025, 06:08 AM
                  • barry101
                    Apple 820-3662 VCore shorted to ground.
                    by barry101
                    Hi, Would appreciate some help.
                    I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                    Get charger light but no fan spin or chime. No liquid damage.
                    Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                    Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                    With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                    Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                    06-24-2025, 07:34 AM
                  • Chaks
                    Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
                    by Chaks
                    TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
                    The specs says ...
                    High antenna efficiency 868MHz ISM Band
                    5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
                    The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
                    1. Should I Fix it with a glue.
                    2. Should I fix it with a double side adhesive tape
                    3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
                    12-09-2024, 11:06 AM
                  • rounin
                    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                    by rounin
                    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                    🛠 Original Issue
                    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                    04-19-2025, 01:18 AM
                  • Rolin
                    Dell Laptop - over 14V between Chassis Ground and Circuit Ground?
                    by Rolin
                    Someone brought me a Dell laptop that had a loose power jack inside (power jack on a cable, not soldered to motherboard). Once disassembled found one of the wires was broken off the power jack. I replaced the jack and it won't turn on, but the metal shell of the jack inadvertently touched the metal hinge and suddenly it got power. I checked voltage from the metal chassis ground and the circuit ground and I get over 14V ? Has anyone seen this before? Typically is it some kind of filter cap that shorted? Very strange...
                    10-30-2022, 10:18 PM
