ISP blocking emails now?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8342
    Got something new. Recently I got trouble with receiving emails and syncing OneNote. Nothing else. I still can stream 24x7, VOIP, have full speed internet, but in the world cannot receive any emails nor sync OneNote. Take the computer somewhere else to a different internet location and no problems at all. Points to the router, right? NOPE! Hooked up my computer directly to the modem (which is in bridge mode) and have the same problems! Put all the network shit back together, start my VPN provider app, choose the closed VPN server to me and all the problems are gone! Is the ISP really blocking emails? Never seen this before. If someone would have told me this, I would have bitch slapped him all day!
    • 31265
    insist on a discout for "reduced service" just to get a response from the fuckers
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8342
      🤔 reduced service,.. I used something similar when we didn’t have any internet for a week, back something like 12 years ago. I think I am going to get them to let them fiddle with my modem so it gets a new IP address assigned and that hopefully takes care of the problem.
        • Jul 2011
        • 6070
        What provider do you have that is doing this nonsense
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8342
          It's a third party provider cable provider. Today the issue rectified itself and all is o.k. However a few days ago I saw fiber optic being installed along my road... Time for a healthy Mbit boost! :-)
            • 31265
            so they have redirected mail into a deep-packet-inspection system?
            troudou is a fucking communist for sure!
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8342
              Don’t even try to get me started with that guy. He is the worst Prime Minister Canada ever had.
              • jean luc ferre
                laptop hp g72 b52sf screen problems
                by jean luc ferre
                on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                06-07-2025, 03:27 PM
              • Hondaman
                USB problems?
                by Hondaman
                Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                08-12-2024, 03:26 PM
              • howardc64
                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                by howardc64
                Failure Symptom
                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                Where is the short?
                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                05-27-2025, 02:56 PM
              • clabr
                Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                by clabr
                Need help to solve some problems with this laptop.
                After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                Before this had happened I observed some other problems:
                When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                12-02-2021, 08:09 AM
              • ohren
                What problems could this blown cap cause in a Marantz SR5400?
                by ohren
                I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
                R533 right below it in the photo is charred, but measures the correct value.
                1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
                10-21-2025, 09:02 AM
