Looking for some low profile hard drives
  • Maxxarcade
    • Jul 2006
    • 973
    I need some low-height hard drives for some games at work- they designed the system around the low profile (and failure prone) Maxtor Fireball 3 drives.
    I've been browsing Newegg for some cheap drives, but there is no mention of the height of any of them. A standard 1" high drive won't fit.
    Anyone know which ones are shorter? We used to buy the Samsung Spinpoint SPO411 drives, which fit perfect, but Newegg doesn't carry them anymore. They were also overkill, since the machine only needs a 6GB drive.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Looking for some low profile hard drives
    What about using notebook drives with ATA adapters??
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Maxxarcade
      • Jul 2006
      • 973
      That would work fine, as long as I can get the drives cheap enough (less than $50 each preferably), and find adapter brackets that are short enough.
      I'll have to get a pic of one of the games just so everyone can see how stupid the design is. They run so hot that they needed full recapping and new fans in less than 2 years. And they cost about $4,500 each
      I have a huge stack of bad hard drives, and a box of bad caps about 7" square from these games, just from the last year or two. Not to mention the fans and power supplies I've changed.
      • gg1978
        • Dec 2004
        • 431
        The ST3160811AS is a low profile drive, and i thought they had a 120G and 80G version that have different model numbers but still end in "811".. But they're Serial ATA..
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          we have been seeing seagate slim drives in the simple tech(walmart) 160gb external.
          again major overkill but maybee they made these in a 20 or 40
          • gg1978
            • Dec 2004
            • 431
            Just thought of another drive that's more like he's looking for.. The Seagate U series X.. I bought 3 or 4 of them from newegg a while back when they were $35 each for use in linux routers, they're 20GB, and 5400 RPM.. I think the model number for them is ST320014A or something like that.. I've also got a 40G one that's an HP system pull.. Some of the Microsoft Xbox's had a 10G U series X in them, later models mostly.. I think i've got one at home.. They have to be unlocked from the xbox before you can use them though..
            • Maxxarcade
              • Jul 2006
              • 973
              I've got a few of those Seagate Xbox drives, but they are not low profile. In fact one of them has been running in my DVR server for ages.
              I was so overjoyed when I found the unlocking utility for those drives, since the original Xbox motherboards were gone, and I thought they were going to be paperweights.
              I just measured one of the original drives I need to replace, and it is 5/8" high.
              • Rainbow
                • Aug 2005
                • 1375
                There were also low profile Maxtors. But you don't want them. Some of them still might be working so beware
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  there are 2 types of maxtor slimlines
                  dead and soon to be dead.
                  • Maxxarcade
                    • Jul 2006
                    • 973
                    Soon I'll get pics of the 14" high stack of dead Maxtor slimlines that I'm trying to replace And that's a fraction of the total amount...
                    If I had a dime every time one came up and the BIOS said Maxtor ARES C64 or Maxtor Athena, I could buy a new machine. That is assuming it would even spin up at all.
                    • gg1978
                      • Dec 2004
                      • 431
                      The ones you have are the old ones then.. They're the U series 5 version.. The one's i'm talking about are labeled U series X, and have the model number ST310014ACE. Like i said before, they come in later model Xboxen. At first they started out with the 10G Seagate U5 and the 8G WD Protege, with the 10G low profile Seagate U series X later..
                      • Maxxarcade
                        • Jul 2006
                        • 973
                        Oh, I remember now, those have the big white label on top of them... I've only seen two of those, and one didn't work, but those would be perfect for what I need. I don't have a tool to unlock those though, so it would have to come out of a working Xbox, such as after an upgrade to a larger drive.
                        I'll keep my eyes on ebay for some drives, now that I know a couple models that are small enough.
                        • gdement
                          • Jan 2007
                          • 690
                          I also bought one of those slim Seagate 20GB drives at Newegg. Mine was model ST320014A. Not sure if they have them anymore though. The problem is they're OEM, so your bare drive is at the mercy of newegg's packing skills.
                          The drive I ordered arrived poorly packed and did the click of death from the moment it was powered on. It had to be sent back for a replacement. That replacement has been running for a year now. The warranty on them is 5 years.
                          • Maxxarcade
                            • Jul 2006
                            • 973
                            Well, two more bad Maxtor slimlines today, now I have almost 20 bad ones in a stack. Time to find a few used drives, anything but Maxtor
                            Scary thing is, I have a couple Maxtors in my main PC. I hope they are better made than these slimline POS drives.
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              uuh i have maxtors in my DL380 G4 dont talk about that shit man
                              • Maxxarcade
                                • Jul 2006
                                • 973
                                Pretty soon I'm going to be able to do this:
                                http://www.youtube.com/watch?v=YocnQ0NMTUA
                                FYI most of the dead drives I have are 40GB Fireball 3, with firmware VAM51JJ0.
                                Another bad Maxtor series was the Fireball CX with the melting Philips spindle motor drive chips. No wonder they call them Fireball I also have a few of those, some still work so I just use them for test drives when I wanna play with Linux or something.
                                The Maxtors in my PC are all holding all my vital stuff, so knock on wood...
                                Funny thing is, I used to HATE Western Digital, now they seem pretty decent.
                                And too bad IBM had so many problems with the 75GXP and some others, and sold their shit to Hitachi, whole still makes the Deathstars. IBM invented the modern hard drive in the 1950's didn't they?
                                • willawake
                                  Super Modulator
                                  • Nov 2003
                                  • 8457
                                  • Greece
                                  seen it before.
                                  • Maxxarcade
                                    • Jul 2006
                                    • 973
                                    ah you got me before I was done editing
                                    • willawake
                                      Super Modulator
                                      • Nov 2003
                                      • 8457
                                      • Greece
                                      maxtors in the DL are Altas series
                                      i have seen enough quantum failures though
                                      the thing about wd is i never am able to recover anything from them. still i got a few recent ones. i would like to see how the seagate 7200.9 and 10 work out also. the difference is that i was able to recover all data from a maxtor when it started to get slow......
                                      its all voodoo anyway. take your pick. dont buy hdds on friday 13 etc......
                                      anyway google hdd study
                                      • Maxxarcade
                                        • Jul 2006
                                        • 973
                                        I have a 320GB Seagate ST3320620A in my NAS server, and it seems to be working ok, but I wish I knew why the SMART logs always report huge numbers for the "Raw Read Error Rate" and "Hardware ECC Recovered" values. I guess it's a Seagate thing. The two Western Digitals in the same box don't have that problem. BTW there is 2197 hours on the Seagate so far, and 4479/5684 on the WD's. Been running 24/7 since new, in a well cooled 4U rack case. I wonder why the WD's have different hour values
                                        • eccerr0r
                                          failing hard drives after sitting for years...
                                          by eccerr0r
                                          With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
                                          Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
                                          Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
                                          03-02-2023, 10:33 AM
                                        • abajor
                                          Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                                          by abajor
                                          I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                                          I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                                          The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                                          Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                                          04-23-2024, 11:43 PM
                                        • federalhouse
                                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                          by federalhouse
                                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                          **Background:**
                                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                          **What I've Tried So Far:**
                                          1. I accessed
                                          08-01-2024, 07:03 PM
                                        • ChaosLegionnaire
                                          what to do with faulty hard drives?
                                          by ChaosLegionnaire
                                          i have several dead/bricked (not detected, doesnt show up or making constant clicks of death) and faulty bad sector hard drives. im moving house soon and need to get rid of some dead weight.
                                          i thought of selling them for parts or not working but they are quite heavy and shipping each drive internationally via local post is US$23 each. im using some of the drives as gym strength training dumbells by putting 4 of them in a box to make a 3kg dumbell. but since im moving i cant carry the deadweight with me. any ideas what to do with them that is cost-effective for ppl like me...
                                          11-25-2021, 02:42 AM
                                        • NeedsPractice
                                          Best Overall Amazing Back Up Setup? 1K-4K Budget! Software + Hardware? Help!
                                          by NeedsPractice
                                          I remember a lot of people before when my hard drive failed told me that I could do a couple of amazing things with backing up data. What stuck out is two things...
                                          1. Software that will backup your data live via a cloud solution or over the internet without having a corporate cloud product.
                                          2. Get a storage tower with hard drives and load them up.
                                          What I mean is there software out there that you can install on your computer. You tell it which data you want backed up. Lets say your main PC with (2) hard drives and (8) hard drives connected to it via a tower....
                                          06-23-2023, 05:26 PM
