Does anyone have comments or thoughts about the Ubuntu v6.10? Seems I remember hearing somewhere (here?) that a newer version was coming out and it was supposed to be better? Limit on a PC's age or hardware?
Ubuntu v6.10 - comments, thoughts?
Re: Ubuntu v6.10 - comments, thoughts?
I started using Linux with Fedora Core 1, and I have been using SuSE for about 2 years.
I just installed Ubuntu 6.10, I wanted to try out an add-on called Linux MCE. My thoughts on it are that it seems to hide a lot of things from the user. Programs that are installed are not available from the menus, by default. I finally found a config GUI where I could show all of the programs that were installed.
Ubuntu is an off-shoot of Debian, which I had never used before. Everything seems to work OK, or no better/worse than other Linux distros.
You download Ubuntu as a single CD (Fedora and SuSE take four or five CDs). You can run the CD as a "Live CD", Just boot into the CD. This usually only works well if you have a lot of memory. Otherwise the computer will be slow and unresponsive. Do this if you want to check it out first. You install from the live boot.
On the up side, Ubuntu seems to be very popular. So there is a lot of support out there.
Paul -
Hi Paul,
Thanks for the comments. I only started using computers on a regular basis in 1998 and then it was Win98 that just came out, so that was my introduction. After seeing Vista (on someone else's machine), I think that Vista is "pretty," but maybe that's it. I have XP Home on this machine and 98Lite on another. My son wants to install Ubuntu on the laptop he is using; maybe that would be a good place for me to learn. The laptop is running XP Pro right now; I think he's holding off because he is not sure about the Ubuntu gaming compatibility. Ya, memory would be an issue. This one I am on has 512 mb in one slot, and the old Dell is maxxed out at whatever little memory it has ;-).
Hearing that Ubuntu seems to hide programs makes me nervous. I am not at all familiar with Linux and would hate to feel like I couldn't navigate at all. Oh shoot, I get nervous on a Mac, because I am not used to them! LOL.
Again, Mahalo! Hope to hear some more input.Comment
I didn't mean to scare you off!
Memory would only be an issue for running the "Live" CD, as it totally runs off of the memory.
I have SuSE installed on my Dell Inspiron 1150 with 512mb RAM. Windows XP is also on it, although I rarely boot into it. You can have both on the same hard drive, they will be on different partitions. The Ubuntu installer should be able to make the Windows installation fit on a smaller section of the drive. It will then use the remaining space to install Ubuntu.
You should first run the defragment application in Windows. Also, run Disk Cleanup to remove unneeded files. You may want to go through the Windows files and remove any large files that really are not needed (like videos and music collections). Basically, do some spring house cleaning on the laptop.
Don't worry too much about the "hidden" programs. I think this is done to make things less cluttered and therefore easier for Linux newbies. Also, you can set it up to access your Windows partition, once you are comfortable with everything.Comment
I tried installing Ubuntu 6.10 on a 5-year old computer with onboard video and it won't do it - problem it seems is the lack of drivers for the old video hardware. I tried my older 5.10 Ubuntu (released October 2004 I believe) and yes, it completed the installation.Comment
Originally posted by doodI tried it and it STILL doesn't natively support the dell 1470 wireless that's in my Latitude d410..
Depending on the chip manufacturer, there are different ways to get wireless working. I have two wireless cards, both with Broadcom chips. Originally the only way to get these to work was by using a program called Ndiswrapper. It actually uses the Windows driver to make the wireless work. While Ndiswrapper is the best for Broadcom, a newer Linux driver is available in newer kernels. It is a module called bcm43xx. There is a different process to make this work, but it will only do 11mb/s, max. If you have a broadcom chip, you may actually have to disable the bcm43xx module before you can use Ndiswrapper.
I don't have much knowledge on the drivers for other chips, except that I know that there are other drivers. The key is to determine the chip used in your wireless. Type the following into a terminal window (as root):
Code:# lspci
Code:02:02.0 Network controller: Broadcom Corporation BCM4306 802.11b/g Wireless LAN Controller (rev 03)
Paul-
I've been through about 6 fresh re-installs and many different "how-to" guides on getting this chip to work with NDISwrapper. Needless to say... none of them worked. I've simply given up on it for now.Ludicrous gibs!
by Srdjan01Hi guys.
I'm working on my first board reballing.
It's iphone 12 pro max and I made a mistake(s), but now to learn something, I hope.
Either I overheated the board and two ics fell off on it's own, or I clumsily took of top board and knock them off. Adrenaline was high at that moment so I do not recall best.
I repaired the damage by putting these components back in place. In some moment I begin tinkering about my future steps and about the fact that I have used low melt solder (138C) to put those components back. My line of thoughts was something like, if I use same solder...1 Photo -
by tsavpynDear all,
I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
Now I have a problem that I am unable to dump my BIOS into bin file.
My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
I searched for FPT but there is no Linux version and none of them work.
I hereby request a copy of Intel Flash Programming Tool for Linux x64.
I would really appreciate it if anyone...-
Channel: BIOS Requests ONLY!
by abajorI've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...-
by jason123I can't find a forum to discuss "instrumentation Troubleshooting", but PS maybe the closest.
So, I'm having an issue with about 13 year old Agilent Function Generator. it works, passes self-test, but it has an annoying "audible" noise, that changes as I change the output frequency setting of the instrument. Prominent around 600 Hz and up (at least that's what my ears are picking up.) I saw on some forms that it could be fan, linear regulator, dried up caps,... I can't seem to find the source of audible noise. Here is what I tried:
1. Turn the output off - still... -
by ivtecHi folks i installed Win10 in 1 HDD and Unbuntu 22.04 in other HDD and installed Grub manager ,it has been working fine till i installed new updates. now it wont boot and doesn't make recovery either and stuck on initramfs ,i type blkid and get this see pic attac. bellow ,althou it boot in Win10 .Any help will be apreciated ....
- Loading...
