What's happening here?!
  • stevo1210
    • Oct 2006
    • 4156
    Hello Everyone,
    I just got a replacement Gigabyte GA-8i848P-G motherboard and my floppy drive light stays on continuously?! The floppy drive is detected in windows but it wont read any disks. Did I install something wrongly again?
    Thanks.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: What's happening here?!
    You inserted the floppy cable upside down
    • gdement
      • Jan 2007
      • 690
      Unfortunately, you may have ruined every disk you put into it. Don't try any more until it's fixed.
      • stevo1210
        • Oct 2006
        • 4156
        Thanks Per Hansson, it seems that you are correct. It looks like rushing a computer installation is not the way to go. Luckily I didn't destroy my motherboard, Floppy drive or any disks that were inserted into the drive.
        After I flipped the cable around, my PC reads my floppy disks correctly.
        Thanks.
        • pentium
          • Mar 2006
          • 2778
          I have done this many times to my computers. usually I am halted at the bios with a floppy error or no POST. NEVER EVER do this to a dimension 4100.
          their drives are biult to fit the font panel son the drives are really hard to find replacements for. I reversed the ribbon cable and the drive gve a pop, fizzle and shut down hard.
          Find Nedry!
          Check the Vending machines!!
          • shadow
            • Feb 2007
            • 732
            Hmm I have done this too. I thought that most floppy cables are keyed these days . Although this did not stop me from putting it in upside down since I do not have any new floppy drives. Most of my floppy drives are not keyed, and many of my cables are not keyed either. The common rule to follow is that the stripe down any IDE or floppy cable faces closest to the power connector (this stripe represents the first wire that corresponds to pin 1 on any plug).
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              I'd be lying if I said I never did that either.... When that light doens't go out, you know what to do...
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • Rainbow
                • Aug 2005
                • 1375
                Sometimes, the cable is not reversed but plugged off-by-1-pin.
                • pentium
                  • Mar 2006
                  • 2778
                  I have seen drives with no keys, keys on both sides and even silkscreening that marks pin 1 on THE WRONG SIDE.
                  It makes me miss 5 1/4" drives, you can't possibly screw up connecting them unless you try really hard.
                  Find Nedry!
                  • stretch0069
                    Screwed Up Super Moderator
                    • Oct 2003
                    • 2658
                    • oooo ess aaaaaaaaa
                    And ya know....i never had problems reading the old 5.25" disks......now 3.5", thats another story.
                    "Its all about the boom....."
                    Guns kill people like spoons made Rosie O'Donnell fat.
                    We now return you to your regularly scheduled drinking.
                    "Fear accompanies the possibility of death.....calm shepherds its certainty"
                    Originally posted by Topcat
                    AWD is just training wheels for RWD.
                    • daRk_Kon
                      • Apr 2007
                      • 109
                      another possibility, even though the problem is fixed, is that the power supply isnt sending the voltage the drive needs, or the cable is in wrong to either end of the boards/drive.
                      • Maxxarcade
                        • Jul 2006
                        • 973
                        I've seen drives with the power connector on either side, there seems to be no standard to which side has pin 1. Though the newer drives are a bit better.
                        I still have my original Teac floppy in my current computer, from back when I had my 286. Before that I had an 8088 IBM PC that only used 360 5 1/4".
                        I remember paying over $50 for the Teac drive when I bought it, and $45 for a used 40MB Seagate hard drive
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Yea, with floppies there seems to be no standard as to which side the red stripe vs power lead goes
                          But I've never seen a harddrive not follow that standard...
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            i installed one recently where i had to break a tab in the pcb to put the floppy cable connector in the right way around.
                            I dont understand why the floppy drives with 7in1 card reader need the floppy cable at all...why doesnt it all work usb.
                            • Rainbow
                              • Aug 2005
                              • 1375
                              For compatibility.
                              • willawake
                                Super Modulator
                                • Nov 2003
                                • 8457
                                • Greece
                                you could work in an RMA department
                                • bgavin
                                  • Jan 2007
                                  • 1355
                                  One big reason is the F6 Driver Function when installing a fresh version of Windows.
                                  Uncle Bill's installer does not recognize USB floppy drives for driver installation. It has to be a Genuine Floppy Drive connected to a Genuine Floppy Drive Controller. USB, flash drives need not apply.
                                  Most of my clients new machines come without a floppy drive, so I bought a nice Sony USB model. It works great in DOS, works great with installed Windows, does not work at all during the F6 drive installation process.
                                  • dood
                                    Deputy dood
                                    • Mar 2004
                                    • 2462
                                    I bought a noname USB floppy from newegg ( http://www.newegg.com/Product/Produc...82E16821118001 )... works great with Windows F6 drivers.
                                    Ludicrous gibs!
                                    • Tom41
                                      • Oct 2005
                                      • 336
                                      • England
                                      I've put a floppy cable on upside down and one pin off before, also IDE cables. With a floppy drive, if you put the cable on wrong it actually corrupts any disk that's put in there. Why is this? Is the head putting out a constant magnetic field and erasing track 0?
                                      With IDE hard disks and ATAPI devices, most of the time if the cable's on wrong the PC won't boot. Either you'll get a beep code error from the BIOS, or it'll just stick on a black screen (perhaps with the case HDD light on steady).
                                      Oddly, I've never ruined an HDD by putting the cable on wrong - in theory, it should get corrupted just like the floppy disks do...
                                      You know there's something wrong when you open your PC and it has vented Rubycons...
                                      • Rainbow
                                        • Aug 2005
                                        • 1375
                                        No, you will not corrupt anything on the HDD as IDE interface is completely different than FDC. If you look at FDD connector pinout, you'll see logic signals that directly controls drive operation. IDE connector contains data lines - and commands are transferred through - you need a command to initiate any operation.
                                        Improperly connected IDE cable can cause unbootable PC because the system RESET signal is often connected to RESET signal on the IDE bus. Connecting the cable wrong way may pull the signal to be active.
                                        • eccerr0r
                                          It's 2025: do you know where your 5¼" floppy drives are?
                                          by eccerr0r
                                          Oh wow.
                                          As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                                          Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                                          Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                                          Weird. Seems the PC drive is having trouble clamping...
                                          07-07-2025, 12:49 AM
                                        • Topcat
                                          Need to find a 34-Pin Motherboard Floppy Header
                                          by Topcat
                                          Looking for some floppy headers.....searching the usual sources (digikey/mouser/etc) until my eyes bled, I couldn't seem to find such a beast. Yes, the silly 34 pin floppy header for a PC motherboard....
                                          Why? Well, I was given a bunch of Optiplex 330's, which are useless systems these days....and despite what some have said, they do not respond well to the E5450 c0 stepping LGA771 Xeon mod, tried several, it never worked. They're in a standard BTX case, so I tossed some $5 Optiplex 380 boards in them I picked up on ebay, which will run ANY 5400-series Xeon with hard mods + firmware........
                                          06-25-2020, 10:50 AM
                                        • Satdude
                                          Retro laptop floppy drive not working
                                          by Satdude
                                          Hi, I have a laptop with a Citizen W1D, an infamous drive in the retro computing hobby. They almost always have bad belts, such was the case with this one. However, after replacing the belt, the drive seeks and spins the disk, but the laptop still gives a "No bootable disk" error. Does anyone have any idea what could be wrong? The heads are clean and are able to move.
                                          05-24-2024, 02:32 PM
                                        • Byte_76
                                          Faulty memory slot on Tekram Slot 1 motherboard
                                          by Byte_76
                                          I have a Tekram P6PRO-A5 Rev. 1.01 which has an issue with one of the memory slots and with the floppy port.
                                          When a memory module is installed into the slot which is closest to the north bridge, the board will beep and won't post. The same memory module works in the two remaining slots.
                                          Also, the floppy drive does not work regardless of bios settings.
                                          Please help me to identify the possible cause of the faulty memory slot and the floppy drive port as well.
                                          I have examined the board under my digital microscope and did not find any broken traces....
                                          04-12-2025, 06:58 AM
                                          ThinkPad Thunderbolt 3 failure:What's happening,why it's happening,and how to fix
                                          by SMDFlea
                                          The thread title is from a recent news article (and a follow up) on notebookcheck about Thunderbolt 3 failures.
                                          Quote:
                                          Nearly 40 ThinkPad models have a problem - the Thunderbolt 3 ports in them randomly stop working. Lenovo has pushed out a fix to users, but what does it do? Does it actually solve the problem? If it doesn't, are the devices even repairable, and will Lenovo repair your device for free?
                                          Lenovo notes these symptoms on their knowledge base page:
                                          USB-C port not working
                                          Intel Thunderbolt controller not visible in the OS/Device Manager
                                          02-10-2020, 11:18 AM
