HP 2000 screen shorting out
  • ttt9090
    • Apr 2013
    • 16
    • canada
    I do repairs to computers and have just come up against a new issue & wondered if anyone here has experienced this.
    Was about to replace a cracked screen on an HP 2000 laptop & before I did, I tried to power it up and had no response. Replaced battery with a known good charged one and same thing.
    Tried with known good power adapter, with and without battery, still nothing.
    Disassembled machine, unplugged video cable, and it powers up with either battery and/or power adapter.
    Plug screen back in, no power and seems to short out power adapter.
    Tried different known good screen and same thing... shorts out.
    I'm thinking maybe video cable is bad? But, not sure about ordering a new one in case it's a board issue.
    Anyone seen this before?
  • ivtec
    • Dec 2008
    • 1967
    Re: HP 2000 screen shorting out
    It has to be the tape cable connector ,on some machine there are some cheap connectors, i can state that I've come across some connectors that i easily disconnect but when connecting it i make a mess, a have a couple like that,
    • ttt9090
      • Apr 2013
      • 16
      • canada
      Hey ivtec, Thanks for the response.
      I can't imagine why I didn't plug it into an external monitor to test it first.
      Just did that and no video out either, so I guess it's in the GPU.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Is the power adapter making a rodent repeller sound?
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • spice_disc
          Vizio TV M50-C1 reboot cycle and static on screen
          by spice_disc
          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
          09-08-2024, 02:37 PM
