Grub Rescue?
  • ivtec
    • Dec 2008
    • 1967
    Grub Rescue?
    Hi guys:i have run into a problem with my Xubuntu12.04! the other day
    when i started up the PC,a Dell pentium4 with Xubuntu installed only OPS,
    i Had a black blank screen on boot with< Grub Rescue > tried to use the CD to boot no avail then i tried to reinstall Xubuntu No Avail,then since i keep many CDs different Distros around i tried Linux Mint 14 Nadia i struggled a little bit at first but at second try it booted up then it installed smoothly,
    today i was inquiring about this Grub Rescue problem and came across this Blog about the solution,since i did not try it and don't know if it works ,I'd like your opinion on this for a future problem of this arising in the future!
    http://xubuntu.wordpress.com/2008/01...the-grub-menu/
  • Time2Retire
    • Aug 2012
    • 256
    Re: Grub Rescue?
    First, your link to the blog article is bad. You can access it here:
    Howto: Fixing GRUB
    Now, that is about re-installing the GRUB bootloader after a fresh Windows install wipes it out. This doesn't seem to be what your problem was caused by.
    Did you add or change any hard drives in this system? Did you alter the boot order in the BIOS settings? If neither of these apply, then maybe your hard drive is bad, or maybe just the MBR (Master Boot Record) section of the drive is bad. Either of these mean you should toss it and get a new hard drive.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Re: Grub Rescue?
      Probable cause: Multiple drives installed (excluding optical drives) and the installer just went ahead and installed GRUB on the drive that don't have Xubuntu.
      This may occur if installing Xubuntu from a USB stick! You need to select another option to have the installer give you a choice where to install GRUB and when you do, make sure GRUB is configured to boot from the drive with Xubuntu installed.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • digge
        • Apr 2006
        • 296
        Re: Grub Rescue?
        http://www.supergrubdisk.org/
        Is a distribution specifically for repairing borked grub. Ive used it a few times when i messed up with grub
        • privato89
          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
          by privato89
          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
          Let's begin:
          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
          03-26-2024, 06:37 AM
        • hinisa
          Xiaomi router freezes at boot after re-capping
          by hinisa
          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
          07-08-2023, 05:58 AM
        • Luke Anders
          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
          by Luke Anders
          A few details about the laptop itself:
          Name: Lenovo Legion 5
          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
          BIOS Version: GKCN60WW
          EC Version: GKEC65WW
          Serial Number: PF39AQ7Z
          Board Model: NM-D562 Rev 3.0
          RAM: 16GB Installed, DDR4 (brand new)
          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
          I bought this laptop recently from eBay as a faulty device....
          10-12-2024, 05:13 AM
        • claws77
          FX553VE-DM318T(FX553v) not POSTING
          by claws77
          Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
          Gpu - nvidia geforce 1050ti
          Ssd orion o700
          Hdd hgst721010A9e630
          See images
          What's not working right?
          The system does not even POST, display is black,
          LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
          When did the problem happen?
          My laptop had dual boot setup, ubuntu and windows 10.
          It already had a moklist error, that would occur when i tried to boot ubuntu.
          05-17-2025, 04:09 PM
        • NolesFan
          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
          by NolesFan
          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
          10-24-2024, 06:36 PM
