Dumpster Computer Find
  • killian6pk
    • Apr 2010
    • 502
    In the County Electronic Recycle box found a Dell Vostro 200 with a motherboard & Core 2 Duo processor, a CD/DVD and a power supply. Is there anyway to test this without putting in memory and a hard drive? I have both, but hoping to find a way to not risk them if the mobo or ps is bad.
    My third computer, that I pay bills on, is very old and slow. Thinking if this Dell will run, it will be a good upgrade to what I am using now.
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
  • RJARRRPCGP
    • Jul 2004
    • 6301
    Re: Dumpster Computer Find
    It probably has a Delta with Ltec and Taicon caps.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      w/o RAM, not really.
      the HDD part can be averted with a live OS disc (like most flavors of linux).
      sigpic
      (Insert witty quote here)
      • killian6pk
        • Apr 2010
        • 502
        Thanks kind of what I thought. I will check the caps on the mobo. Is the ESR as important as it is in monitors etc.?
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Yeah, High ESR is a sign of failed caps. Especially in the VRM.
          sigpic
          • mockingbird
            • Dec 2008
            • 5484
            There are six capacitors on the board that need changing. Three Chemicon caps (With the brown sleeve) by the CPU VRM (Near the back panel connectors) and three more left of the memory slots. The board is made by Foxconn, as is typical with Dell Vostros, and they're decent quality.
            Vostros use LiteOn PSUs, but YMMV. They need to be re-capped as well, but you can use a different PSU if you want since Vostros are standard ATX computers.
            • killian6pk
              • Apr 2010
              • 502
              Do you mean as a matter of practice or only if the PS is not working?
              I will change the ones on the Mobo.
              • killian6pk
                • Apr 2010
                • 502
                I wanted to try Linux on this machine (if the computer will run). The reviews of Ubunto 13.10 do not appear to be great. Don't know if this is just real afficianado's not happy with something or if it really does not function correctly.
                What do you think I should install as my first foray into Linux (name and version), provided this computer works? I will need to download a live disc for whatever since I won't have an OS.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  [/COLOR]
                  practice. Junk caps will fail sooner or later.
                  sigpic
                  • mockingbird
                    • Dec 2008
                    • 5484
                    Agreed... And even it it works, it will kill your brand new caps with all that ripple it's letting through.
                    • RJARRRPCGP
                      • Jul 2004
                      • 6301
                      The Vostro 200 I had came with a Delta mini 250W PSU.
                      (model DPS-250A B-28 B)
                      Arc A770 16 GB
                      • ant3202
                        • Jun 2006
                        • 274
                        • Singapore
                        intel core2duo 775 2.8Ghz
                        asus manboard - toasted
                        2 X 2GB team DDR400RAM
                        Sapphire HD4770 - toasted
                        CoolerMaster Glite 330 Red Casing
                        Acbel Ipower 550W* IIRC PSU
                        found this PC at my stairway...
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Score!
                          Looks like you got a decent case and a CPU (may have been OC'd) for free... and a good (may need recapped) PSU as well. The RAM, meh, team is junk.
                          sigpic
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Score!
                            I don't agree.
                            OP, Try Elementary OS Better than Ubuntu but still based on Ubuntu so it'll run the same stuff.
                            • killian6pk
                              • Apr 2010
                              • 502
                              Thanks had not heard of that particular OS. I will look into it. Just looking for something that works without tons of bells and whistles. My normal use for this machine is getting on the net to pay bills and sometimes do some surfing. Yesterday I saw a good bit on Puppy Linux that made that look good as a possiblility. Anyone got any thoughts.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Manjaro Linux. Arch based, but easy to setup and use. Also gives access to arch's large repository of packages (a copy of it that is)... easy to use but still light and powerful. I personally prefer the gnome flavor (now discontinued officially by manjaro) but the default XFCE sounds more like what you're asking for.
                                sigpic
                                • killian6pk
                                  • Apr 2010
                                  • 502
                                  Originally posted by shovenose
                                  I don't agree.
                                  This looks like Puppy in that it seems to be lightweight, but it looks like it has more stuff that can be added on if you want. This looks like something that could be a real possibility. Thanks for the info on it.
                                  • cheapie
                                    null
                                    • Jul 2010
                                    • 849
                                    My favorite distro has to be Mint (I prefer the MATE version). It's yet another Ubuntu-based distro, but the MATE desktop environment is nice. I've never tried the Cinnamon option, though.
                                    • killian6pk
                                      • Apr 2010
                                      • 502
                                      Thanks I will look into this one also. Man there are a lot of variations on this OS. Lots of really busy people out there programming their little fingers off.
                                      • ivtec
                                        • Dec 2008
                                        • 1967
                                        Hi guys talking about Dumpsters computers,i also found this week a Dell dimention 4500 pentium4 intel i845,1023gb ram,2.26ghz processor,80gb hd,
                                        with Nvidia Geforce 4Ti 4200,it was runing with Win XP sp3,it started up but when it got to the dektop it would freeze, since i know Xp is not supported any more i went a head and i started to install linux distro and erased Win,but at first i couldn't run Debian wheezy7,Xubuntu12.04,lubuntu, mint14,
                                        Bu i thought of Changing the Nvidia card to an ATI 9600,and installed
                                        Debian Wheezy7 and it installed great, then since i like Xubuntu 1204 better
                                        went a head and installed it,this time it installed great and i have a great Extra PC, and it runs like a champ,
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • corrize
                                          Where to find a very small fpc connector 0.3mm between 2 pins ?
                                          by corrize
                                          Hello, I search this connector (oxydated).
                                          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                          Do you know how to find this connector please ? What is the exact name for find it ?
                                          08-06-2024, 05:25 PM
                                          Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                                          by sam_sam_sam
                                          This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                                          Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                                          07-07-2024, 02:34 PM
                                        • temyth
                                          Sentey ATX PSU - ERP650-PS - Trying to find out the right Standby IC
                                          by temyth
                                          Greetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
                                          The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
                                          01-07-2024, 04:50 PM
                                        • PizzaMan
                                          Macbook Air A2681 logic board, find this part
                                          by PizzaMan
                                          I am trying to find this part on the logic board. See pictures below. It might be CR812, not sure. Any help would be appreciated. And where could I find the part?
                                          05-24-2025, 12:34 PM
