Dumpster Computer Find
Follow the white rabbit. -
Re: Dumpster Computer Find
I found a Toshiba Satellite A 50 laptop and faulty power supply last week near a sportsfield. Somebody has dumped lot of household stuff and this laptop caught my eye.
The power supply had broken DC plug which I cut off. Separated the wires and plugged in the mains power. It workedBut I needed to fit a new DC plug.
Toshiba uses 6.5 mm DC plug which are not easy to obtain. Went to local recycling shops but no luck, neither the electronics shop Jaycar had the plug.
Then I remembered that I have an universal laptop power supply in my van. Sure enough, I found all the plugs which came with this power supply.
To use this adaptor plug with the AC adapter without DC plug, I had to find couple connectors to fit into the adapter and solder other ends to the 15V DC output cable. Found a computer power supply with that Molex multipin plug and took two pins with short cables out of that cutting the off with a carpet knife. Easy job and used heat shrink tube to insulate and make it look tidy. Plugged in the cable with right polarity testing 3 times with my multimeter that positive was in the center pin as with original plug.
The laptop had 2 lights up but I did not hear the hdd starting up and nothing came on the screen.
In the meantime while I was wondering about pulling this laptop apart I bought exactly same model Toshiba Satellite A50 with different fault from Trademe, a local Ebay. This one was faulty too but different fault.
Testing showed that the screen came to life but Win XP did not load. I took the hdd from that dumped A50 and that got the laptop going : popcorn1:
The keyboard did miss a key and some screws are missing on the bottom but there are enough screws and good parts to make one good laptop and I can sell the rest for parts for more than $40 I paid for the second faulty laptop.
Pretty stoked as I was looking for a proper laptop to do stuff I need Windows OS and watch some movies in my van. I have already 2 tablets and now I can sell my Asus Transformer TF 101.Comment
i also have a Toshiba satellite that was given to me but the mouth in the Laptop did not work, i had to use an external mouth,story short i was walking on a street and i noticed on a garbage can on the side of the street ready to be picked up by the garbage truck, a Toshiba exactly like mine in pieces inside a plastic bag the only thing missing was the hard drive,i opened my Toshiba and checked why the mouth did not work and it was a missing cable tape, took cable tape of the found Toshiba put it in place and now i have a laptop fully working even have an extra battery,Thats Luck>Comment
There are six capacitors on the board that need changing. Three Chemicon caps (With the brown sleeve) by the CPU VRM (Near the back panel connectors) and three more left of the memory slots. The board is made by Foxconn, as is typical with Dell Vostros, and they're decent quality.
Vostros use LiteOn PSUs, but YMMV. They need to be re-capped as well, but you can use a different PSU if you want since Vostros are standard ATX computers.
BTW I have flash player for Linux downloaded, don't know if this helps or hurts.Have you ever stopped to think and then forget to start thinking again?
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."Comment
Channel: BIOS Requests ONLY!
by corrizeHello, I search this connector (oxydated).
It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
Do you know how to find this connector please ? What is the exact name for find it ?
by sam_sam_samThis Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...-
by ktmmotocrossEVGA 360AIO with LCD. Aio and lcd not work. Cannot find NUC1261NE4AE Nuvoton that have burn mark on it.
Anyone knows where to find it?08-02-2025, 06:40 AM -
by temythGreetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
...8 Photos - Loading...
