Old Pentium s Boot Up
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Ok hello i have an old asi 9000 PC (made in 1996) and i only paid like 6 dollars. I guess i needed a fuse for something because when i found it in a closet it didnt work so i just jumped the fuse and connected everything. It doesnt have a hard drive so when i turn it on it just says searching for main master and it detects my cd drive and when i press f1 to continue it says boot error even when i put in a live boot cd. my question is im wondering if a pentium-s processor can support cd booting
    any help will be apreciated.
    canadaboy25
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Old Pentium s Boot Up
    It's not the processor that controls from which media you can boot, it's the BIOS
    BIOS chips of Pentium-S vintage had a tiny capacity compared to today's, and this controlled how much could be done by the size of firmware stored in them
    That usually meant they could boot from a floppy disk, or a hard disk, or a CD-ROM in later model ones which perhaps yours is not
    Get into the BIOS settings, usually by pressing Delete during boot up, and check if there are options for CD-ROM boot
    If there aren't, you need to use a Boot Manager from a bootable floppy disk - Gujin is one I've used, but there are others
    Gujin is Linux command line oriented, and not that friendly to set up - I suggest:
    1. Get & install the 7-Zip utility
    2. Download a Gujin Install .tar.gz from http://sourceforge.net/projects/gujin/files/
    3. Use 7-Zip to extract the .tar from the .tar.gz
    4. Use 7-Zip to extract the Install folder from the .tar
    5. Get a copy of rawrite.exe and use it to write boot.144 from the Install folder to a 3.5" floppy disk
    6. Boot from that floppy disk and look for Gujin to present a F1/F2/F3/etc option corresponding to the CD-ROM
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • canadaboy25
      What is normal?
      • May 2013
      • 509
      Thanks for the reply i will try that tomorrow.
      canadaboy25
      canadaboy25
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        I haven't heard of ASI as a brand, but it may be proprietary rather than using a generic motherboard like Asus or Gigabyte or ??
        If it's proprietary, getting into BIOS may not be the Delete key, but F2 or F10 or ?? - look for messages during boot up, like "Press ?? to enter BIOS"
        "Press F1 to continue" sounds proprietary - probably the CMOS battery (if it has one) has gone flat - are there other options at this time, like F10 to enter BIOS ?
        I'd expect a PC built in 1996 would have a BIOS capable of booting from CD-ROM
        • luke10050
          • Mar 2013
          • 209
          i think a better boot manager is PLOP, its actually quite simple to use and will fit on a floppy. might not do all you want though
          http://www.plop.at/en/bootmanagers.html
          they have a floppy version... from memory theres some formatting magic in there (1.60MB floppy)
          • canadaboy25
            What is normal?
            • May 2013
            • 509
            I have no problem getting into the BIOS menu but when i go in there are only options for floppies not cd's.
            canadaboy25
            canadaboy25
            • canadaboy25
              What is normal?
              • May 2013
              • 509
              If the battery has gone flat what does that do to my system?
              Man i use a lot of adapters on this thing lol.
              canadaboy25
              canadaboy25
              • Uniballer
                • Jul 2013
                • 334
                It will not know the time and date, and you will need to run BIOS setup so it can be happy about floppy disk, CDROM, HDD (if you put one in), etc. Some systems from that era seem to have a supercapacitor rather than a battery, so that would presumably not need to be replaced. I also have a motherboard of similar vintage in my parts bin that has an ODIN OEC12C887A which could be replaced by the appropriate Dallas part, probably DS12C887A.
                FYI - I have a 1997 vintage Pentium 100 (P54C) that runs environmental controls in my kennel (my oldest computer system since I got rid of my PDP-11/73). No work has been done on it since it was new except the AT-style power supply has been replaced with one from another machine, and the operating system is now FreeBSD 6.4 (the last version the installed BIOS can boot). I have the same issue with being unable to boot from anything but a floppy or hard disk, and I have a PLOP floppy that I can use to boot from the CDROM drive.
                • euromatlox
                  • Mar 2013
                  • 60
                  • Finland
                  Found info of that mb using google and it seems to be pretty old one, 5 ISA slots and 3 PCI slots. I have about similar looking board (Asus), with Pentium 200Mhz processor. Finding a hard drive can be difficult, and if found, it's probably noisy one. I have succesfully used (Seagate) Microdrives (kinda CF card with miniature disc inside) as hard drive, and they work great. Since it's a CF card, it needs some editing (formatting) before it can be used as a hard drive. Google search should help for details. I think 2.5, 4 or 8 GB Microdrive is okay, using too big might not be compatible.
                  To use Microdrive as hdd, of course a Compact Flash CF to 3.5" IDE 40 Pin Converter Adapter is needed. Should not be a problem to find one (eBay).
                  About the battery, just replace it with new one. It might be CR2032 or 3.6V Akku (eBay: motherboard nimh 3.6v), in which case it needs soldering. You need to check/set BIOS settings next boot after replacement.
                  I think there are no separate cd options in BIOS, just IDE settings (for hard drives and CD drives). Usually auto/LBA should be enough.
                  • euromatlox
                    • Mar 2013
                    • 60
                    • Finland
                    If I remember right, it was 'fixmbr' or something (recovery console), which turned CF Microdrive into hdd drive (cannot be used anymore in cameras). Fdisk also has /mbr option.
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      Just means you'll be prompted to do something about BIOS settings every time you boot
                      If you don't want/need permanent BIOS settings, means you'll have to press F1 every time you boot, to accept the defaults
                      Defaults are usually boot from floppy disk first, and if no floppy disk inserted, boot from hard disk second
                      • pfrcom
                        Oldbie
                        • Jun 2006
                        • 1230
                        I found PLOP could not do a more unusual task which Gujin was able to do
                        For a straightforward task like booting from a CD-ROM when the BIOS can't do it, PLOP may be a simpler option
                        • cheapie
                          null
                          • Jul 2010
                          • 849
                          Just pop it into a Linux box and use (g)parted. That's probably the easiest way to do it.
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Not proprietary, AFAIK. What would be proprietary is if it demanded a particular floppy to be inserted. Not likely on 1993 and later PCs.
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • pfrcom
                              Oldbie
                              • Jun 2006
                              • 1230
                              FWIW here's a couple of links I found
                              http://www.wincom.net/mission/seanix.htm
                              http://museum.ttrk.ee/th99/m/S-T/33120.htm
                              Judging by the second link, ASI 9000's motherboard has a Dallas-type module, not a CR2032 battery
                              If it's soldered to the board like mine was in this thread https://www.badcaps.net/forum/showthread.php?t=23718, would be a P.I.T.A. to replace it
                              I reckon OP might just as well continue pressing F1 to accept CMOS defaults each time he boots
                              • canadaboy25
                                What is normal?
                                • May 2013
                                • 509
                                Ok so I havent been posting for a while because ive been busy with other things but now I have a new, more importat problem.
                                I have a PC from 2002 with a AMD Athlon processor and has been stored in a shipping container for about 6 years with temps of plus 40 to minus 40 and just pulled it out yesterday. It boots up fine just gives a few outdated error messages but whenever i turn it off or reboot it it goes off fine but when it tries to come back on all the fans start running my disk drive lights up and searches for a disk and my hard drive spins up. But nothing comes up on the screen and the motherboard doesnt beep. The only way around this is to pull the main power cable and plug it back in then it works. What could be causing this?
                                canadaboy25
                                canadaboy25
                                • canadaboy25
                                  What is normal?
                                  • May 2013
                                  • 509
                                  It does have a little round battery that is dead.
                                  canadaboy25
                                  • pfrcom
                                    Oldbie
                                    • Jun 2006
                                    • 1230
                                    canadaboy25
                                    Seeing that dates from the height of the bad capacitors plague, perhaps bad capacitors
                                    Time to have a look inside that PC - at the motherboard and possibly its power supply as well
                                    If the motherboard does have bad capacitors, and you want help, start by searching this forum, using the motherboard's model number
                                    If nothing useful from searching, begin a new thread about the motherboard - in the appropriate "Motherboards with Bad Capacitors" section, having the board's model number in the title
                                    • canadaboy25
                                      What is normal?
                                      • May 2013
                                      • 509
                                      Could someone please give me some step by step instructions on creating a startup floppy?
                                      All of the ways I have tried just result in a disk boot faliure.
                                      canadaboy25
                                      canadaboy25
                                      • canadaboy25
                                        What is normal?
                                        • May 2013
                                        • 509
                                        Well I just got it running today!
                                        I had to reverse lots of cables on the mobo and made a plop floppy to boot from my windows 95 cd. I also needed a dvd drive not the cd drive.
                                        It was asking me to press f1 because the floppy drive was not being recognised.
                                        I used an old 30gb hard drive with bad sectors to install windows on
                                        Well now its working for old games at least.
                                        canadaboy25
                                        • DynaxSC
                                          ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                          by DynaxSC
                                          I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                          Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                          Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                          The behaviour is also really very strange, i.e.:
                                          • The disk shows always up in BIOS - so it is recognized, so far so good
                                          • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                          02-23-2025, 01:33 PM
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • PainThonNen
                                          Dell E5440 no boot and disk led blinking
                                          by PainThonNen
                                          Hello guys how are you?
                                          I'm facing a Dell E5440 who don't to boot. When I push the power button, the power shows up for some seconds and goes down. After that, wireless and battery led show up (solid white) and the disk led start flashing. No short to ground detected, Tried to flash both U1 et U2 but nothing.
                                          Thank you for any help
                                          11-27-2023, 07:03 PM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
                                        • Luke Anders
                                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                          by Luke Anders
                                          A few details about the laptop itself:
                                          Name: Lenovo Legion 5
                                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                          BIOS Version: GKCN60WW
                                          EC Version: GKEC65WW
                                          Serial Number: PF39AQ7Z
                                          Board Model: NM-D562 Rev 3.0
                                          RAM: 16GB Installed, DDR4 (brand new)
                                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                          I bought this laptop recently from eBay as a faulty device....
                                          10-12-2024, 05:13 AM
