Dell E5440 no boot and disk led blinking
  • PainThonNen
    PainThonNen
    • Apr 2021
    • 8
    • Sénégal
    Hello guys how are you?
    I'm facing a Dell E5440 who don't to boot. When I push the power button, the power shows up for some seconds and goes down. After that, wireless and battery led show up (solid white) and the disk led start flashing. No short to ground detected, Tried to flash both U1 et U2 but nothing.
    Thank you for any help
  • jake-b
    • Jan 2024
    • 5
    good morning,
    i have dell e6540's and not e5440's so your mileage may vary. on the e6540 you can interrupt the boot process by pressing the f12 key after the power key and you will see an option on the resulting menu to run a pre-boot system assessment. it is a comprehensive hardware diagnostic. another option in the e6540 is to hold the "fn" key when powering on which runs hardware tests and produces a combination of led lights that identify possible hardware issues. the led combinations are defined in a table in the users manual. i didn't see the table of codes in the e5440 manual so that capability may not exist on a e5440 but if it does there is a table that maps combinations of leds (disk-battery-wireless) to possible system errors in the e6540 manual on page 54. hope those tests are of some use and best of luck in resolving.
    • Stanley1843
      Windows 11 disk no boot
      by Stanley1843
      I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
      I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
      DISM /Online /Cleanup-image /Restorehealth
      The DISM.... command shows me the error 87.
      sfc /scannow
      chkdsk
      bootrec /FixBoot
      bootrec /ScanOs
      bootrec /RebuildBcd
      For some reason it writes(Total identified installations 0) like there no...
      10-18-2025, 04:41 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • mamado mosa
      Slow boot dell latitude 5410 laptop issues
      by mamado mosa
      So i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
      The problem is it takes more than a minute to boot ..
      The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
      Can someone suggest something to fix
      06-19-2025, 06:55 AM
    • estabilito
      Swapped CPU from Fujitsu to Dell - boot guard?
      by estabilito
      Hello, i just swapped CPU(i5-8350u) from fujitsu lifebook e548 to Dell Latitude E7490 Board, all resistances are fine, laptop wants to boot but after 1 second draw of 0,3A its turning off, after pressing power on button same situation. I've cleaned ME region and same situation. Is it boot guard problem - and if it is, is it any chance to bypass this or this cpu just can't be used in Dell.
      05-27-2025, 05:26 PM
    • Calidebear
      Dell 3537 laptop doesn't boot without embedded display.
      by Calidebear
      I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
      So checked the schematics to bypass this issue.
      Found something but I don't know how to read this schematics.
      Dell 3537 mobo 9982p rev 3
      Schematics attached,...
      03-29-2025, 11:37 AM
