Just hangs
  • Lazzie
    • Nov 2006
    • 11
    Just hangs
    Hi all.
    Please help me out here.My machine cannot load OS (winXP Pro), it goes as far as displaying the screen with options like 'start windows normaly' and others (I know u know that stage) and then it stays there forever...whether I leave it to do the countdown or I press the Enter key. When I try installing Windows, setup runs pretty well until a point where it says 'Setup is starting windows', then again it stays there forever. Tried two different installation CDs, two different HDDs and two different CD-Roms, got same results. Can be a motherboard problem? If so, what might be wrong with it? It's an MSI P4 motherboard, almost a year old.
    Thanx.
  • bgavin
    • Jan 2007
    • 1355
    Re: Just hangs
    Find a technician with a BART or WinPE disk in his kit. I've seen a number of occasions where a CHKDSK is required, and this prevents Windows from starting.
    If it gets really bad, your technician should have a copy of NTFSDOS, that he can use to do a NTFSCHK from a DOS boot diskette. Sometimes the system volume is such that BART and WinPE will not boot, or allow access to it. NTFSCHK gets around this problem.
    If you suspect hardware, create a Memtest86 boot CD and let it run for serveral complete passes. Note that tests 5,8 are prone to failure on earlier AMD boards such as ABit KG7.
    • starfury1
      • May 2006
      • 1256
      Re: Just hangs
      Why does this sound so familiar....
      since you say you have tried HDD CD and 2 winxp CD I'll bet it is a motherboard issue...not that the MB is stuffed...sound like windows is looking for something
      I'll leave this to the winxp Guru's here
      My thoughts are possibly BIOS, memory or Iam thinking some chip set driver issue.
      I assume you reset bios to default, maybe see if there is a bios update or issues with the version you got
      Maybe run that memtest proggie, doubt its it but cant hurt
      I have a vague memory of a MB that would do this but don't recall brand or the exact issue, think the fix was to build a custom install CD
      What is the exact model of MB?
      Really wish I could but, I can't help you further Lazzie.... no winxp Guru
      bgavin bet me here but yeah thats a possibility chkdsk
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: Just hangs
        what board is it exactly?
        are you formatting the disk during install?
        have you installed xp with this exact configuration before?
        what i would do in that case is remove anything you dont need to make the install eg all cards except the graphics card, remove all usb devices you have plugged in and disable in the bios any onboard audio or lan. then make the install and afterwards add each device until you have a problem.
        • Lazzie
          • Nov 2006
          • 11
          Re: Just hangs
          I will check the board again and post the full details of it as well as bios...but its an MSI board (V class or something lyk dat) with phoenix bios.
          Yah I do format during instal,tried both quick format and low level format.
          Its not the first time i instal using this MB, i'v done that before.
          Full Story
          There is an AMD PC that was attacked by a variant of brontok.It kept on restartin jus after log in.I slaved its HDD in my machine and successfully cleaned it.I took it back to its PC and then it failed to boot.Thinking dat the bootsector might have bin affected,I inserted an XP disk and tried repairing it (tried both fixboot and fixmbr).Then it talked about missing or corrupt hal.dll.Again I went to the repair console and replaced the dll file.When I reboot,thats when the current problem started.At that point removed my HDD from my machine and plugged into that AMD to c if will boot ok,it ddnt...the screen jus remained black atfta POST.I took my HDD bek to my PC and did exactly the same problem.Then I was puzzled coz afta removin the AMD HDD my machine was ok...i min i switched it on and it was all good.
          Sorry for such a long story.Should have posted this y'day but ddnt have time.
          Regards
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Re: Just hangs
            Use Darik's Boot and Nuke to really format everything on the HDD, be very very careful though, I'd remove any harddrive I do not want formatted because unlike a normal format this will be totally irreversible...
            http://dban.sourceforge.net/
            • PedroDaGr8
              • Oct 2006
              • 130
              Re: Just hangs
              hal.dll corrupt means you need to do a complete and fresh reinstall. It is the dll for the Hardware Abstraction Layer. it is VERY type dependent. A bad hal results in the exact thing that youmentioned. I had it before. The only way to fix it was a complete reinstall of windows FRESH not REPAIR. It tends to be very picky between AMD and Intel, multicore and single core, multiple CPU single CPU, mobile chip/nonmobile/tablet etc.
              • tungu
                • Dec 2006
                • 11
                Re: Just hangs
                During the process I also add more memory , changed cpu from Celeron 500MHz to PIII 550MHz but the machine was still hang untill video card changed . The mobo is GA 6BXC
                • spacemusicdaw
                  HP xw9400 hangs on gfx access - which bad caps ?
                  by spacemusicdaw
                  The operating system often hangs after any graphics operation like scroll/zoom/menu open/button click. It is the same after swapping all parts (CPUs: dual Opteron 2216 or 8435, RAM: 8x1GB or 8x4GB, power supply : 800W or 1000W, graphics card : original Quadro FX 3500 replaced with GeForce 7300 LE to decrease power) one at a time, and trying several operating systems (Windows 7/10, Linux, FreeBSD; 32 and 64 bit versions of all of them). But if the motherboard has been sleeping for months/years, the first few minutes are more stable before it warms up. This seems to come with...
                  05-30-2024, 10:20 AM
                • Hexel
                  Asus K513E mobo X513EA R5.4 hangs during OS load, item partno needed
                  by Hexel
                  Hello!
                  I need help identifying part name of IC in QFN16 packadge under SSD, near audio jack and 1206 capacitors (marked on photo). Unfortunatelly there is no refdes of that part so that is only info I can provide. I took boardview here on forum for revosion 2.0, but it doesn`t have this part at all, not just moved. Maybe someone have relevant schematic or BV.
                  Notebook was poured with coffee and someone already tried to fix it but as usual made jusy worse. I`ve restored all mobo defects and now it powers up, starts OS booting but hangs on OS logo. I believe missing part may...
                  10-04-2023, 04:26 AM
                • minhduc18
                  suface pro6 surface pr6 hangs logo
                  by minhduc18
                  surface pr6 hangs logo , please help me , thanks .
                  06-22-2022, 04:37 AM
                • Varon23
                  Acer Nitro 5 FH51M LA-J871P - Hangs when booting from USB/NVMe
                  by Varon23
                  Sorry. translator
                  Hello. patient after another service
                  FH51M LA-J871P REV 1B board
                  i5-10300H
                  Bios replaced, VBios also. Apart from KBC because I have SAS REV 2.5 and I don't think this version will work.
                  I did a Hybrid and Chipset Reflow. Without changes.
                  I turned off NVIDIA by desoldering the power coils.
                  And basic elements such as RAM were replaced.
                  The problem is that it starts. you can enter the BIOS. However, when booting from a USB or NVME disk, the loading "circle" immediately freezes and remains there. or spouts random...
                  01-13-2024, 03:01 AM
                • Z419nv2
                  Zyxel NBG-419n v2, hangs during the boot
                  by Z419nv2
                  The router hangs at bootloader stage without any error. This is the log from UART:
                  Code:
                  U-Boot 1.1.3 (Mar 6 2012 - 17:34:10)
                  Board: Ralink APSoC DRAM: 64 MB
                  relocate_code Pointer at: 83fb0000
                  spi_wait_nsec: 3c
                  spi device id: c2 20 17 c2 20 (2017c220)
                  find flash: MX25L6405D
                  raspi_read: from:30000 len:1000
                  .*** Warning - bad CRC, using default environment
                  Ralink UBoot Version: 3.6.0.1_a3
                  ASIC 3352_MP
                  01-24-2022, 11:17 AM
